    Updated to 2.15 but now have a random cursor
    11 Posts 5 Posters 3.9k Views 6 Watching
      scumbelly
      @TDMPro2K
      Autohiding the Mouse Pointer
      Install unclutter:
      sudo apt-get install unclutter
      You can create an .xinitrc script to run the tool.
      See https://wiki.archlinux.org/index.php/Unclutter
      But a simpler option is to add a line to the end of the file:
      $ nano ~/.config/lxsession/LXDE-pi/autostart
      @unclutter -display :0 -idle 3 -root -noevents
      This will add a 3 second delay, before the pointer disappears from the screen when not using it.
      T S 2 Replies Last reply Reply Quote 0
      • T Offline
        TDMPro2K @scumbelly
        @scumbelly Thanks I shall give it a try and see what happens
          sdetweil @scumbelly
          @scumbelly that’s interesting. the css hides the cursor typically.
            scumbelly @sdetweil
            FYI
            My ‘dev’ system hasn’t had unclutter installed. It has a mouse and keyboard attached. If my mouse is turned off (wireless) the pointer appears centered on the screen. When I turn the mouse on the pointer disappears.
            Unclutter is installed on ‘playroompi’ and ‘garagepi’ systems with no pointer issues.
            To verify if installed,
            $ apt-cache policy unclutter
            unclutter:
            Installed: 8-21
            Candidate: 8-21
            Version table:
            *** 8-21 500
            500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
            100 /var/lib/dpkg/status
            If not,
            unclutter:
            Installed: (none)
            Candidate: 8-21
            Version table:
            8-21 500
            Cheers
              sdetweil @scumbelly
              @scumbelly weird. most of my systems do not have a keyboard/mouse and do not have unclutter installed.
              no mouse appears over mm.
              if I plug in a mouse, no mouse appears over mm
              if I change the css, then the mouse appears
              main.css
              html {
                cursor: none
              comment out the cursor :none;
                scumbelly @sdetweil
                Your solution is certainly easier.
                Thanks for the information.
                Regards.
                • T Offline
                  TDMPro2K
                  HI Guys, Yeah it only showed since doing the update to the latest. I had no issue before.
                  The unclutter worked and its not showing once again.
                  @scumbelly Thanks for your help…
                  • W Offline
                    Wenike @TDMPro2K
                    So, unclutter worked for me to hide the cursor but now I don’t have the normal RaspPi desktop and instead I’m in some Openbox thing. After some panic, I was able to figure out that I needed to right-click to bring up the menus (I use a Chromebook to VNC on and have a bluetooth keyboard/mouse combo that I use rarely if the Chromebook doesn’t work and the Chromebook has long-press to be right-click, which doesn’t translate very well outside of it). I’ve killed that autostart command and uninstalled unclutter (sudo apt-get --purge remove uncluter). How do I get it to stop going into Openbox and go back to using the desktop that I’m used to?
                    • W Offline
                      Wenike @Wenike
                      @wenike Apparently, deleting that autostart file (or in my case, renaming it) caused it to be recreated and get the normal desktop back.
                        MajorC Project Sponsor @sdetweil
                        @sdetweil since updated to v2.15 I have the cursor, too.
                        The main.css looks like:
                        html {
                          cursor: none;
                          overflow: hidden;
                          background: #000;
                          user-select: none;
                        Not sure what to do.
