    MMM-GoogleAssistant help?
    17 Posts 3 Posters 3.5k Views 3 Watching
    • I Offline
      Infinity2437
      Any time i try to start up magic mirror i get syntax errors all coming from the config file, can anyone help me correct it? I’ll put it below```
      code_text
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/getting-started/configuration.html#general
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-US",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      			module: "compliments",
      			position: "lower_third"
      			module: "weather",
      				type: "hourly",
      				units: "imperial",
      				locationID: "5098135", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				apiKey: "YOUR_OPENWEATHER_API_KEY"
      			module: "weather",
      			header: "Weather Forecast",
      				type: "forecast",
      				units: "imperial",
      			module: "MMM-GoogleAssistant",
      			position: "bottom_bar",
      			configDeepMerge: true,
      				assistantConfig: {
      					lang: "en-US"
      					latitude: 40.8614432,
      					longitude: -73.9624286
      				responseConfig: {
      					useFullscreen: false,
      					useResponseOutput: true,
      					responseOutputCSS: "response_output.css",
      					screenOutputTimer: 5000,
      					activateDelay: 250,
      					useAudioOutput: true,
      					useChime: true,
      					confirmationChime: true,
      					useInformations: true
      				Extended: {
      					touch: {
      						useTouch: true
      						mode: 2
      					spotify: {
      						usespotify: true
      						player: {
      						type: "Raspotify",
      						email: "",
      						password: "",
      						minVolume: 10,
      						maxVolume: 90,
      						usePause: true
      					visual: {
      						updateInterval: 1000,
      						idleInterval: 10000,
      						useBottomBar: false,
      						CLIENT_ID: "d828e1b4937642de97567e8b5ab12e17",
      						CLIENT_SECRET: "b373ef6ad60440ba8fc4e7452a2a0033",
        sdetweil @Infinity2437
        @infinity2437 you are missing a few trailing commas
        in the MagicMirror folder do
        npm run config:check
        it will report an error
        check the line before the reported line for a trailing comma
        (ie, if it says 150, check line 149)
        do this until the errors are gone
          DJBOOB66
          what GA are you trying to get to work if GAv3 did you read the WiKi?
          I’m happy to help im just installing GAv3 to another pi now.
          • I Offline
            Infinity2437 @DJBOOB66
            @djboob66 yes it is v3 and i checked and followed the wiki
            • I Offline
              Infinity2437
              @sdetweil it says line 100 column 6 but i dont see anything wrong
                @infinity2437 because its on line 99
                unexpected token
                means the previous line did not have a trailing comma
                • I Offline
                  Infinity2437 @sdetweil
                  @sdetweil I fixed that one now it says unexpected token node on touch
                    @infinity2437 there are 3 errors… all the same problem
                      DJBOOB66
                      Well you need to add " , " on a number of lines read WiKi config [http://wiki.bugsounet.fr/en/MMM-GoogleAssistant/Configuration](link url)
                      and [http://wiki.bugsounet.fr/en/MMM-GoogleAssistant/ConfigurationStructure](link url)
                        sdetweil @DJBOOB66
                        @Infinity2437 @djboob66 the text config.js formatting rules are as follows
                        the thing to the left of : only needs quotes if it contains special characters, like - or .
                        if the thing to the right of : is a number or true or false, it should not be quoted
                        otherwise, if the thing to the right contains letters or special chars then it must be quoted
                        single or double doesn’t matter as long as both ends match
                        if the thing on the next line starts with a word, see rule part1, then THIS line MUST have a comma at the end, signifying more is coming
