    MMM-GoogleAssistant help?
    17 Posts 3 Posters 4.2k Views 3 Watching
    • I Offline
      Infinity2437
      @sdetweil it says line 100 column 6 but i dont see anything wrong
        sdetweil @Infinity2437
        @infinity2437 because its on line 99
        unexpected token
        means the previous line did not have a trailing comma
        • I Offline
          Infinity2437 @sdetweil
          @sdetweil I fixed that one now it says unexpected token node on touch
            @infinity2437 there are 3 errors… all the same problem
              DJBOOB66
              Well you need to add " , " on a number of lines read WiKi config [http://wiki.bugsounet.fr/en/MMM-GoogleAssistant/Configuration](link url)
              and [http://wiki.bugsounet.fr/en/MMM-GoogleAssistant/ConfigurationStructure](link url)
                sdetweil @DJBOOB66
                @Infinity2437 @djboob66 the text config.js formatting rules are as follows
                the thing to the left of : only needs quotes if it contains special characters, like - or .
                if the thing to the right of : is a number or true or false, it should not be quoted
                otherwise, if the thing to the right contains letters or special chars then it must be quoted
                single or double doesn’t matter as long as both ends match
                if the thing on the next line starts with a word, see rule part1, then THIS line MUST have a comma at the end, signifying more is coming
                  DJBOOB66 @sdetweil
                  @sdetweil I meant he missing ( , )
                    sdetweil @DJBOOB66
                    @djboob66 yes, i said that before, and told him how to find them and fix them
                    • I Offline
                      @sdetweil ok now i have a new problem when trying to get MMM-Detection to work and now it says there is an error which is the : in module:
                        DJBOOB66
                        post config
                        • I Offline
                          Infinity2437 @DJBOOB66
                          @djboob66 line 140 column 10
                          /* Magic Mirror Config Sample
                           * By Michael Teeuw https://michaelteeuw.nl
                           * MIT Licensed.
                           * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                           * and https://docs.magicmirror.builders/modules/configuration.html
                          let config = {
                          	address: "localhost", 	// Address to listen on, can be:
                          	port: 8080,
                          	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                          	language: "en",
                          	locale: "en-US",
                          	timeFormat: 24,
                          	units: "metric",
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_left"
                          			header: "US Holidays",
                          						symbol: "calendar-check",
                          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                          			module: "compliments",
                          			position: "lower_third"
                          			module: "weather",
                          				type: "hourly",
                          				units: "imperial",
                          				locationID: "5098135", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                          				apiKey: "YOUR_OPENWEATHER_API_KEY"
                          			module: "weather",
                          			header: "Weather Forecast",
                          				type: "forecast",
                          				units: "imperial",
                          			module: "MMM-GoogleAssistant",
                          			position: "bottom_bar",
                          			configDeepMerge: true,
                          				assistantConfig: {
                          					lang: "en-US",
                          					latitude: 40.8614432,
                          					longitude: -73.9624286
                          				responseConfig: {
                          					useFullscreen: false,
                          					useResponseOutput: true,
                          					responseOutputCSS: "response_output.css",
                          					screenOutputTimer: 5000,
                          					activateDelay: 250,
                          					useAudioOutput: true,
                          					useChime: true,
                          					confirmationChime: true,
                          					useInformations: true
                          				Extended: {
                          					touch: {
                          						useTouch: true,
                          						mode: 2
                          					spotify: {
                          						usespotify: true,
                          						player: {
                          						type: "Raspotify",
                          						email: "",
                          						password:
                          						minVolume: 10,
                          						maxVolume: 90,
                          						usePause: true
                          					visual: {
                          						updateInterval: 1000,
                          						idleInterval: 10000,
                          						useBottomBar: false,
                          						CLIENT_ID: "",
                          						CLIENT_SECRET: "",
                          			module: "MMM-Detector",
                          				debug: false,
                              				autoStart: true,
                          				useLogos: true,
                          				micConfig: {
                          					recorder: "auto",
                          					device: "default",
                          					audioGain: 2.0,
                          					applyFrontend: true // When you use only `snowboy` and `smart_mirror`, `false` is better. But with other models, `true` is better.
                          			newLogos: {
                          				default: "default.png"
                          			detectors: [
                          				detector: "Snowboy",
                          				Model: "jarvis",
                          				Sensitivity: null,
                          				Logo: "google",
                          				autoRestart: false,
                          				onDetected: {
                          					notification: "GA_ACTIVATE"
                          				detector: "Porcupine",
                          				Model: "ok google",
                          				Sensitivity: null,
                          				Logo: "google",
                          				autoRestart: false,
                          				onDetected: {
                          				Model: "hey google",
                          				Sensitivity: null,
                          				Logo: "google",
                          				autoRestart: false,
                          				onDetected: {
                          			NPMCheck: {
                          				useChecker: true,
                          				delay: 10 * 60 * 1000,
                          				useAlert: true
                            DJBOOB66 @Infinity2437
                            @infinity2437 You should read the Wiki mate
                            you have
                            should be
                            • I Offline
                              @djboob66 thank you so much it finally works
