    MMM-GoogleAssistant help?
    17 Posts 3 Posters 4.1k Views 3 Watching
      sdetweil @Infinity2437
      @infinity2437 there are 3 errors… all the same problem
        DJBOOB66
        Well you need to add " , " on a number of lines read WiKi config [http://wiki.bugsounet.fr/en/MMM-GoogleAssistant/Configuration](link url)
        and [http://wiki.bugsounet.fr/en/MMM-GoogleAssistant/ConfigurationStructure](link url)
          sdetweil @DJBOOB66
          @Infinity2437 @djboob66 the text config.js formatting rules are as follows
          the thing to the left of : only needs quotes if it contains special characters, like - or .
          if the thing to the right of : is a number or true or false, it should not be quoted
          otherwise, if the thing to the right contains letters or special chars then it must be quoted
          single or double doesn’t matter as long as both ends match
          if the thing on the next line starts with a word, see rule part1, then THIS line MUST have a comma at the end, signifying more is coming
            DJBOOB66 @sdetweil
            @sdetweil I meant he missing ( , )
              sdetweil @DJBOOB66
              @djboob66 yes, i said that before, and told him how to find them and fix them
              • I Offline
                Infinity2437 @sdetweil
                @sdetweil ok now i have a new problem when trying to get MMM-Detection to work and now it says there is an error which is the : in module:
                  DJBOOB66
                  post config
                  • I Offline
                    Infinity2437 @DJBOOB66
                    @djboob66 line 140 column 10
                    /* Magic Mirror Config Sample
                     * By Michael Teeuw https://michaelteeuw.nl
                     * MIT Licensed.
                     * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                     * and https://docs.magicmirror.builders/modules/configuration.html
                    let config = {
                    	address: "localhost", 	// Address to listen on, can be:
                    	port: 8080,
                    	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                    	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                    	language: "en",
                    	locale: "en-US",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "US Holidays",
                    						symbol: "calendar-check",
                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "weather",
                    				type: "hourly",
                    				units: "imperial",
                    				locationID: "5098135", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    				apiKey: "YOUR_OPENWEATHER_API_KEY"
                    			module: "weather",
                    			header: "Weather Forecast",
                    				type: "forecast",
                    				units: "imperial",
                    			module: "MMM-GoogleAssistant",
                    			position: "bottom_bar",
                    			configDeepMerge: true,
                    				assistantConfig: {
                    					lang: "en-US",
                    					latitude: 40.8614432,
                    					longitude: -73.9624286
                    				responseConfig: {
                    					useFullscreen: false,
                    					useResponseOutput: true,
                    					responseOutputCSS: "response_output.css",
                    					screenOutputTimer: 5000,
                    					activateDelay: 250,
                    					useAudioOutput: true,
                    					useChime: true,
                    					confirmationChime: true,
                    					useInformations: true
                    				Extended: {
                    					touch: {
                    						useTouch: true,
                    						mode: 2
                    					spotify: {
                    						usespotify: true,
                    						player: {
                    						type: "Raspotify",
                    						email: "",
                    						password:
                    						minVolume: 10,
                    						maxVolume: 90,
                    						usePause: true
                    					visual: {
                    						updateInterval: 1000,
                    						idleInterval: 10000,
                    						useBottomBar: false,
                    						CLIENT_ID: "",
                    						CLIENT_SECRET: "",
                    			module: "MMM-Detector",
                    				debug: false,
                        				autoStart: true,
                    				useLogos: true,
                    				micConfig: {
                    					recorder: "auto",
                    					device: "default",
                    					audioGain: 2.0,
                    					applyFrontend: true // When you use only `snowboy` and `smart_mirror`, `false` is better. But with other models, `true` is better.
                    			newLogos: {
                    				default: "default.png"
                    			detectors: [
                    				detector: "Snowboy",
                    				Model: "jarvis",
                    				Sensitivity: null,
                    				Logo: "google",
                    				autoRestart: false,
                    				onDetected: {
                    					notification: "GA_ACTIVATE"
                    				detector: "Porcupine",
                    				Model: "ok google",
                    				Sensitivity: null,
                    				Logo: "google",
                    				autoRestart: false,
                    				onDetected: {
                    				Model: "hey google",
                    				Sensitivity: null,
                    				Logo: "google",
                    				autoRestart: false,
                    				onDetected: {
                    			NPMCheck: {
                    				useChecker: true,
                    				delay: 10 * 60 * 1000,
                    				useAlert: true
                      DJBOOB66 @Infinity2437
                      @infinity2437 You should read the Wiki mate
                      you have
                      should be
                      • I Offline
                        @djboob66 thank you so much it finally works
