    MMM-GoogleAssistant help?
    17 Posts 3 Posters 4.3k Views 3 Watching
      sdetweil @Infinity2437
      @infinity2437 you are missing a few trailing commas
      in the MagicMirror folder do
      npm run config:check
      it will report an error
      check the line before the reported line for a trailing comma
      (ie, if it says 150, check line 149)
      do this until the errors are gone
        DJBOOB66
        what GA are you trying to get to work if GAv3 did you read the WiKi?
        I’m happy to help im just installing GAv3 to another pi now.
        I 1 Reply Last reply
        • I
          Infinity2437 @DJBOOB66
          @djboob66 yes it is v3 and i checked and followed the wiki
          • I
            Infinity2437
            @sdetweil it says line 100 column 6 but i dont see anything wrong
              @infinity2437 because its on line 99
              unexpected token
              means the previous line did not have a trailing comma
              • I
                Infinity2437 @sdetweil
                @sdetweil I fixed that one now it says unexpected token node on touch
                  @infinity2437 there are 3 errors… all the same problem
                    DJBOOB66
                    Well you need to add " , " on a number of lines read WiKi config [http://wiki.bugsounet.fr/en/MMM-GoogleAssistant/Configuration](link url)
                    and [http://wiki.bugsounet.fr/en/MMM-GoogleAssistant/ConfigurationStructure](link url)
                      sdetweil @DJBOOB66
                      @Infinity2437 @djboob66 the text config.js formatting rules are as follows
                      the thing to the left of : only needs quotes if it contains special characters, like - or .
                      if the thing to the right of : is a number or true or false, it should not be quoted
                      otherwise, if the thing to the right contains letters or special chars then it must be quoted
                      single or double doesn’t matter as long as both ends match
                      if the thing on the next line starts with a word, see rule part1, then THIS line MUST have a comma at the end, signifying more is coming
                      D 1 Reply Last reply
                        DJBOOB66 @sdetweil
                        @sdetweil I meant he missing ( , )
                          sdetweil @DJBOOB66
                          @djboob66 yes, i said that before, and told him how to find them and fix them
                          • I
                            @sdetweil ok now i have a new problem when trying to get MMM-Detection to work and now it says there is an error which is the : in module:
                              DJBOOB66
                              post config
                              • I
                                @djboob66 line 140 column 10
                                /* Magic Mirror Config Sample
                                 * By Michael Teeuw https://michaelteeuw.nl
                                 * MIT Licensed.
                                 * see https://docs.magicmirror.builders/getting-started/configuration.html#general
                                 * and https://docs.magicmirror.builders/modules/configuration.html
                                let config = {
                                	address: "localhost", 	// Address to listen on, can be:
                                	port: 8080,
                                	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                                	language: "en",
                                	locale: "en-US",
                                	timeFormat: 24,
                                	units: "metric",
                                			module: "alert",
                                			module: "updatenotification",
                                			position: "top_bar"
                                			module: "clock",
                                			position: "top_left"
                                			header: "US Holidays",
                                						symbol: "calendar-check",
                                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                			module: "compliments",
                                			position: "lower_third"
                                			module: "weather",
                                				type: "hourly",
                                				units: "imperial",
                                				locationID: "5098135", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                				apiKey: "YOUR_OPENWEATHER_API_KEY"
                                			module: "weather",
                                			header: "Weather Forecast",
                                				type: "forecast",
                                				units: "imperial",
                                			module: "MMM-GoogleAssistant",
                                			position: "bottom_bar",
                                			configDeepMerge: true,
                                				assistantConfig: {
                                					lang: "en-US",
                                					latitude: 40.8614432,
                                					longitude: -73.9624286
                                				responseConfig: {
                                					useFullscreen: false,
                                					useResponseOutput: true,
                                					responseOutputCSS: "response_output.css",
                                					screenOutputTimer: 5000,
                                					activateDelay: 250,
                                					useAudioOutput: true,
                                					useChime: true,
                                					confirmationChime: true,
                                					useInformations: true
                                				Extended: {
                                					touch: {
                                						useTouch: true,
                                						mode: 2
                                					spotify: {
                                						usespotify: true,
                                						player: {
                                						type: "Raspotify",
                                						email: "",
                                						password:
                                						minVolume: 10,
                                						maxVolume: 90,
                                						usePause: true
                                					visual: {
                                						updateInterval: 1000,
                                						idleInterval: 10000,
                                						useBottomBar: false,
                                						CLIENT_ID: "",
                                						CLIENT_SECRET: "",
                                			module: "MMM-Detector",
                                				debug: false,
                                    				autoStart: true,
                                				useLogos: true,
                                				micConfig: {
                                					recorder: "auto",
                                					device: "default",
                                					audioGain: 2.0,
                                					applyFrontend: true // When you use only `snowboy` and `smart_mirror`, `false` is better. But with other models, `true` is better.
                                			newLogos: {
                                				default: "default.png"
                                			detectors: [
                                				detector: "Snowboy",
                                				Model: "jarvis",
                                				Sensitivity: null,
                                				Logo: "google",
                                				autoRestart: false,
                                				onDetected: {
                                					notification: "GA_ACTIVATE"
                                				detector: "Porcupine",
                                				Model: "ok google",
                                				Sensitivity: null,
                                				Logo: "google",
                                				autoRestart: false,
                                				onDetected: {
                                				Model: "hey google",
                                				Sensitivity: null,
                                				Logo: "google",
                                				autoRestart: false,
                                				onDetected: {
                                			NPMCheck: {
                                				useChecker: true,
                                				delay: 10 * 60 * 1000,
                                				useAlert: true
                                  DJBOOB66 @Infinity2437
                                  @infinity2437 You should read the Wiki mate
                                  you have
                                  should be
                                  • I
                                    @djboob66 thank you so much it finally works
