    exec error: Error: Command failed: ?!
    15 Posts 2 Posters 5.2k Views 2 Watching
      sdetweil @stoffel
      @stoffel yes, my config module is pretty good…
      waiting for more error reports from users …
      because you are launching the program (bash) … the console comes to your program not to the log…
      in my uploadPics module I just console.log() whatever comes back from my shell pgm…
      then it shows in the MM log
      S 2 Replies Last reply
        stoffel @sdetweil
        fine, i will test it at WE.
        Now its time to sleep. i test tomorrow with sh … and without bash/sh
          stoffel @sdetweil
          i’v test the exec command without bash… thats not work, i have a
          /bin/sh: 1: …/MagicMirror/config/test.sh: Permission denied
          with bash it works now, but the filename is a bit crazy
          thats at ssh console. in filezilla the filename is correct but says no such file or directory
          i have no idea what gos wrong
            sdetweil @stoffel
            @stoffel us the file marked excecutable?
            ls -laF ../MagicMirror/config/test.sh
            if the file starts with the shebang, then u don’t need to use bash either
            #!/bin/bash
            rest of script
            chmod +x ../MagicMirror/config/test.sh
            it is really in the config folder?
              stoffel @sdetweil
              look at my first post, its a simple text-file with the extension .sh and its executable -rw-r–r–
              the test.sh is not the problem, the file ist found and execute it. the problem was the cp command. but now i soved the problem.
              cp -a -v ../MagicMirror/config/config.js ../MagicMirror/config/config_1.js 1>> ./log_erfolgreich.txt 2>> ./log_fehlgeschlagen.txt
              pm2 restart all
              i add the option -a . now its work !!
              the log_erfolgreich.txt and log_fehlgeschlagen.txt are found in the MagicMirror dir, so cp starts at this dir.
              the
              ../MagicMirror/
              are needed, maybe mm starts from the .pm2 dir?!
              i play around with it and other files (txt, png…)
              i am lucky :-)
              thanks very much for your help.
              at WE i test your config-module and post it
                sdetweil @stoffel
                @stoffel said in exec error: Error: Command failed: ?!:
                is NOT executable
                it needs the x flag
                now its executable xrwxr–xr–
                there are 3 bits each
                for the user themselves
                for others in the same group as the user
                and for ‘others’
                sometimes shortened to UGA
                u can set the flags with
                chmod the numbers 7 is all bits (777)
                or just for the user 766
                or read only for anyone except the user 744
                to turn on the execute flag for any and all its +x
                (to turn it off is -x)
                r and w are read and write
                  sdetweil @stoffel
                  unix is cool… ANYTHING can be executable… and a ‘script’ is just a text file with the executable flag on
                  the .sh means nothing (just convention to say shell script)
                  I dson’t use .sh in most of my scripts, cause its just another thing the user has to type and doesn’t help
                  also, in unix, if the 1st line of the executable text file
                  starts with shebang #!
                  then the program to execute this ‘script’ is specified next
                  #!/bin/bash
                  means bash will execute this program, so bash (/bin/bash) is launched and passed this script
                    stoffel @sdetweil
                    ok, i am not a linux erpert. i think the exec command execute a script, and its work with this file-attributes. you can test it. maybe its read the file and exec the commands in it. i’v checked the attributes with filezilla, was 644, not executable but it works.
                    the file-attributes are for the security of RPI & MM importend. thats is for later.
                    at the moment ist works without errors. i can send you my files for test !?
                      sdetweil @stoffel
                      @stoffel not needed… exec should fail if the execute bit is not on…(it would be a security exposure to allow ‘anything’ to execute) but not my job
                        stoffel @sdetweil
                        ok, what can i say. i’v test it with other config und it works also. its overide the old config with the new config and restart mm.
                        i not understand why, but it works. realy
                          sdetweil @stoffel
                          @stoffel I do this in MMM-Config, node_helper
                            exec("pm2 restart " + pm2_id);
                          after I get the id from pm2 info and find the entry that matches the path we are running under
                            stoffel @sdetweil
                            i have test a lot with file attributes. not needed. magicMirror is not linux, its javascript. only the copy command and pm2 command in the exec function must linux conform. in the pm2 log you have sometimes error messages, but that comes from linux. so you have right, without x-flag its not executable, but MagicMirror ignore file attributes.
                            now i can cange all my configs with remote-control. for the moment i am finished this module. maybe later i have a new idea, ha,ha.
