    How to add custom birthdays to the calendar module?
    27 Posts 4 Posters 9.9k Views 5 Watching
      doogy_rev
      @sdetweil said in How to add custom birthdays to the calendar module?:
      https://devhints.io/moment
      That sounds great and yes that’s kinda what I was looking for, the month cross over sounds good, This is how I have the default where it will only show the next 5 holidays so have the birthdays work the same way (or as near as), then past birthdays for the month drop off the list
        sdetweil @doogy_rev
        @doogy_rev ok, git pull , review the README
        by default it operates on current month only
          doogy_rev
          Installed and working :-) Thanks for looking at this for me!
          I am going to play with the CSS and change some of the colours a bit. I did notice the following . .
          • If birthdays are shared date, then the second/third entry is in bold (see screen shot Aug 12th)
          • when you specify number of entires it adds additional, I specified 5, but 6 are showing
          • is it possible to have date aligned right and keep age after the name “doogyrev Birthday [45] Oct 1st”
          • where do I change font to not be all uppercase?
            sdetweil @doogy_rev
            @doogy_rev all the stuff is in css.
            body has a transform uppercase
            this is built as a table.
            also read this
            https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1625955346969
            and if u change the css file, just hit f5 or ctrl-r
              doogy_rev
              Thanks Again, I appreciate the help and assistance!!
              I will check that out. I am what I class as a non-technical-technical . . . i.e I know a small amount, probably enough to be dangerous . .TBH, I am just chuffed I have managed to maintain my Mirror for the last 5years . . lol
              I might be back if I can’t work it out :-)
                sdetweil @doogy_rev
                @doogy_rev no problem…
                this last with the date next to the age, they are in teh same table cell, so I might have to make another column
                I didn’t do the css for this.
                  doogy_rev
                  I figured they were in the same cell since the colours are linked, but that’s beyond my feeble abilities …haha
                  This is where I am at, going to make some new icons to match the default, I found the one used, so just need to change the colours.
                  how do I change the cell height? I removed the existing icon and the cell height stayed the same? even changing the vertical height in the css made no difference. Also I assume the “Aug 12th” double entry’s are in the same cell, is it possible to put them in individual?
                    sdetweil @doogy_rev
                    @doogy_rev yeh, two on the same day, should only have the date once…
                    for width I would look at google table cell width via css.
                      sdetweil @doogy_rev
                      @doogy_rev fixed double date on same day and count plus 1
                      git pull
                        doogy_rev @sdetweil
                        Unless I have done something dumb (which is entirely possible) this is whatI get, Count +1 seems to work (I am 1 entry less) but double date just removed the date not adding entry to a new table line.
                          sdetweil @doogy_rev
                          @doogy_rev correct, the second person on the same birthday doesn’t get the date.
                            sdetweil @doogy_rev
                            @doogy_rev does this look better…age and date split into separate columns
                            names in one column,
                            age in next
                            and date in next (only if dateformat is specified)
                            no changes to css
                              doogy_rev @sdetweil
                              @sdetweil that looks awesome, exactly how I was wanting it to look
                                doogy_rev @doogy_rev
                                although, thinking about it would it look better if of the age was directly following the name, and the date is fixed to the far right . .
                                doogyrev (47)___________Oct 12th
                                Dave (26)________________Jan 1st
                                vs
                                doogyrev______(47) Oct 12th
                                Dave
                                _____(26)______Jan 1st
                                If that ^^ makes sense?
                                  sdetweil @doogy_rev
                                  @doogy_rev I didn’t change the css, but the age is now in a separate td, also sep from the date
                                  so try this
                                  git pull
                                  also ACTUALLY fixed the count… I was counting things that wouldn’t display… oops…
                                    doogy_rev @sdetweil
                                    @sdetweil This is what I have now…
                                    just wondering if this makes more sense? (quick photoshop)
                                    Sorry if I am being a PITA
                                      sdetweil @doogy_rev
                                      @doogy_rev i understand… i am thinking if there is a way to fix this and still get this functionality, which I like better…
                                        doogy_rev @sdetweil
                                        @sdetweil If it was set back to 2 tables columns
                                        Column 1 = Name + Age + Align Left
                                        Column 2 = Date + Align right
                                        Would that work? Guess it depends if you can put Name + Age in the same cell space
                                          sdetweil @doogy_rev
                                          @doogy_rev I know HOW it should be done. question is what can I do to THIS code, without rewriting it
