    How to add custom birthdays to the calendar module?
    27 Posts 4 Posters 10.4k Views 5 Watching
      sdetweil @doogy_rev
      @doogy_rev ok, git pull , review the README
      by default it operates on current month only
        doogy_rev
        Installed and working :-) Thanks for looking at this for me!
        I am going to play with the CSS and change some of the colours a bit. I did notice the following . .
        • If birthdays are shared date, then the second/third entry is in bold (see screen shot Aug 12th)
        • when you specify number of entires it adds additional, I specified 5, but 6 are showing
        • is it possible to have date aligned right and keep age after the name “doogyrev Birthday [45] Oct 1st”
        • where do I change font to not be all uppercase?
        S 2 Replies Last reply
          sdetweil @doogy_rev
          @doogy_rev all the stuff is in css.
          body has a transform uppercase
          this is built as a table.
          also read this
          https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1625955346969
          and if u change the css file, just hit f5 or ctrl-r
            doogy_rev
            Thanks Again, I appreciate the help and assistance!!
            I will check that out. I am what I class as a non-technical-technical . . . i.e I know a small amount, probably enough to be dangerous . .TBH, I am just chuffed I have managed to maintain my Mirror for the last 5years . . lol
            I might be back if I can’t work it out :-)
              sdetweil @doogy_rev
              @doogy_rev no problem…
              this last with the date next to the age, they are in teh same table cell, so I might have to make another column
              I didn’t do the css for this.
                doogy_rev
                I figured they were in the same cell since the colours are linked, but that’s beyond my feeble abilities …haha
                This is where I am at, going to make some new icons to match the default, I found the one used, so just need to change the colours.
                how do I change the cell height? I removed the existing icon and the cell height stayed the same? even changing the vertical height in the css made no difference. Also I assume the “Aug 12th” double entry’s are in the same cell, is it possible to put them in individual?
                  sdetweil @doogy_rev
                  @doogy_rev yeh, two on the same day, should only have the date once…
                  for width I would look at google table cell width via css.
                    sdetweil @doogy_rev
                    @doogy_rev fixed double date on same day and count plus 1
                    git pull
                    D 1 Reply Last reply
                      doogy_rev @sdetweil
                      Unless I have done something dumb (which is entirely possible) this is whatI get, Count +1 seems to work (I am 1 entry less) but double date just removed the date not adding entry to a new table line.
                        sdetweil @doogy_rev
                        @doogy_rev correct, the second person on the same birthday doesn’t get the date.
                          sdetweil @doogy_rev
                          @doogy_rev does this look better…age and date split into separate columns
                          names in one column,
                          age in next
                          and date in next (only if dateformat is specified)
                          no changes to css
                            doogy_rev @sdetweil
                            @sdetweil that looks awesome, exactly how I was wanting it to look
                              doogy_rev @doogy_rev
                              although, thinking about it would it look better if of the age was directly following the name, and the date is fixed to the far right . .
                              doogyrev (47)___________Oct 12th
                              Dave (26)________________Jan 1st
                              vs
                              doogyrev______(47) Oct 12th
                              Dave
                              _____(26)______Jan 1st
                              If that ^^ makes sense?
                                sdetweil @doogy_rev
                                @doogy_rev I didn’t change the css, but the age is now in a separate td, also sep from the date
                                so try this
                                git pull
                                also ACTUALLY fixed the count… I was counting things that wouldn’t display… oops…
                                  doogy_rev @sdetweil
                                  @sdetweil This is what I have now…
                                  just wondering if this makes more sense? (quick photoshop)
                                  Sorry if I am being a PITA
                                    sdetweil @doogy_rev
                                    @doogy_rev i understand… i am thinking if there is a way to fix this and still get this functionality, which I like better…
                                      doogy_rev @sdetweil
                                      @sdetweil If it was set back to 2 tables columns
                                      Column 1 = Name + Age + Align Left
                                      Column 2 = Date + Align right
                                      Would that work? Guess it depends if you can put Name + Age in the same cell space
                                        sdetweil @doogy_rev
                                        @doogy_rev I know HOW it should be done. question is what can I do to THIS code, without rewriting it
