    How to add custom birthdays to the calendar module?
    27 Posts 4 Posters 10.2k Views 5 Watching
      sdetweil @doogy_rev
      @doogy_rev fixed double date on same day and count plus 1
      git pull
        doogy_rev @sdetweil
        Unless I have done something dumb (which is entirely possible) this is whatI get, Count +1 seems to work (I am 1 entry less) but double date just removed the date not adding entry to a new table line.
          sdetweil @doogy_rev
          @doogy_rev correct, the second person on the same birthday doesn’t get the date.
            sdetweil @doogy_rev
            @doogy_rev does this look better…age and date split into separate columns
            names in one column,
            age in next
            and date in next (only if dateformat is specified)
            no changes to css
              doogy_rev @sdetweil
              @sdetweil that looks awesome, exactly how I was wanting it to look
                doogy_rev @doogy_rev
                although, thinking about it would it look better if of the age was directly following the name, and the date is fixed to the far right . .
                doogyrev (47)___________Oct 12th
                Dave (26)________________Jan 1st
                vs
                doogyrev______(47) Oct 12th
                Dave
                _____(26)______Jan 1st
                If that ^^ makes sense?
                  sdetweil @doogy_rev
                  @doogy_rev I didn’t change the css, but the age is now in a separate td, also sep from the date
                  so try this
                  git pull
                  also ACTUALLY fixed the count… I was counting things that wouldn’t display… oops…
                    doogy_rev @sdetweil
                    @sdetweil This is what I have now…
                    just wondering if this makes more sense? (quick photoshop)
                    Sorry if I am being a PITA
                      sdetweil @doogy_rev
                      @doogy_rev i understand… i am thinking if there is a way to fix this and still get this functionality, which I like better…
                        doogy_rev @sdetweil
                        @sdetweil If it was set back to 2 tables columns
                        Column 1 = Name + Age + Align Left
                        Column 2 = Date + Align right
                        Would that work? Guess it depends if you can put Name + Age in the same cell space
                          sdetweil @doogy_rev
                          @doogy_rev I know HOW it should be done. question is what can I do to THIS code, without rewriting it
