    How to add custom birthdays to the calendar module?
    27 Posts 4 Posters 10.4k Views 5 Watching
      sdetweil @doogy_rev
      @doogy_rev all the stuff is in css.
      body has a transform uppercase
      this is built as a table.
      also read this
      https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1625955346969
      and if u change the css file, just hit f5 or ctrl-r
        doogy_rev
        Thanks Again, I appreciate the help and assistance!!
        I will check that out. I am what I class as a non-technical-technical . . . i.e I know a small amount, probably enough to be dangerous . .TBH, I am just chuffed I have managed to maintain my Mirror for the last 5years . . lol
        I might be back if I can’t work it out :-)
          sdetweil @doogy_rev
          @doogy_rev no problem…
          this last with the date next to the age, they are in teh same table cell, so I might have to make another column
          I didn’t do the css for this.
            doogy_rev
            I figured they were in the same cell since the colours are linked, but that’s beyond my feeble abilities …haha
            This is where I am at, going to make some new icons to match the default, I found the one used, so just need to change the colours.
            how do I change the cell height? I removed the existing icon and the cell height stayed the same? even changing the vertical height in the css made no difference. Also I assume the “Aug 12th” double entry’s are in the same cell, is it possible to put them in individual?
              sdetweil @doogy_rev
              @doogy_rev yeh, two on the same day, should only have the date once…
              for width I would look at google table cell width via css.
                sdetweil @doogy_rev
                @doogy_rev fixed double date on same day and count plus 1
                git pull
                D 1 Reply Last reply
                  doogy_rev @sdetweil
                  Unless I have done something dumb (which is entirely possible) this is whatI get, Count +1 seems to work (I am 1 entry less) but double date just removed the date not adding entry to a new table line.
                  S 2 Replies Last reply
                    sdetweil @doogy_rev
                    @doogy_rev correct, the second person on the same birthday doesn’t get the date.
                      sdetweil @doogy_rev
                      @doogy_rev does this look better…age and date split into separate columns
                      names in one column,
                      age in next
                      and date in next (only if dateformat is specified)
                      no changes to css
                        doogy_rev @sdetweil
                        @sdetweil that looks awesome, exactly how I was wanting it to look
                          doogy_rev @doogy_rev
                          although, thinking about it would it look better if of the age was directly following the name, and the date is fixed to the far right . .
                          doogyrev (47)___________Oct 12th
                          Dave (26)________________Jan 1st
                          vs
                          doogyrev______(47) Oct 12th
                          Dave
                          _____(26)______Jan 1st
                          If that ^^ makes sense?
                            sdetweil @doogy_rev
                            @doogy_rev I didn’t change the css, but the age is now in a separate td, also sep from the date
                            so try this
                            git pull
                            also ACTUALLY fixed the count… I was counting things that wouldn’t display… oops…
                              doogy_rev @sdetweil
                              @sdetweil This is what I have now…
                              just wondering if this makes more sense? (quick photoshop)
                              Sorry if I am being a PITA
                                sdetweil @doogy_rev
                                @doogy_rev i understand… i am thinking if there is a way to fix this and still get this functionality, which I like better…
                                  doogy_rev @sdetweil
                                  @sdetweil If it was set back to 2 tables columns
                                  Column 1 = Name + Age + Align Left
                                  Column 2 = Date + Align right
                                  Would that work? Guess it depends if you can put Name + Age in the same cell space
                                    sdetweil @doogy_rev
                                    @doogy_rev I know HOW it should be done. question is what can I do to THIS code, without rewriting it
