    Problem install (and config)l new modules
    6 Posts 3 Posters 925 Views 3 Watching
      PierreSweden
      Im a noob, i cant for My life understand how to edit and and modules to My Mirror…
      Please help me out, i got a fresh installation and can only Enjoy the included standard modules that comes with the mm package…
      I Dont get it how to edit config.js and tell Mirror to loss new module… and not change it so it gets My locstion…
      Im pretty new att this as i told you…
      But IF someone could share a Little time with me to get Up My modules and runnin i Will certainly be gratefull…
      I Will be more than happy to even pay you for your time and effort…
      Tia
      Pierre
        DJBOOB66
        what modules do you wish to have on the mirror? I suggest starting with easy ones till you get the hang of things.
        most modules have a how-to install and the config that has to be placed in Config.js.
        [https://github.com/ckoutavas/MMM-PiTemp](link URL) is a easyone.
        happy to help if needed.
          sdetweil @PierreSweden
          @pierresweden use my new module MMM-Config
          last time u will edit config.js
          you will get a form to fill in for each module
          you clone
          see
          https://github.com/sdetweil/MMM-Config
          or read the two links in my signature below
            PierreSweden @DJBOOB66
            @djboob66
            well, in this beginning fase, i want to understand and learn how to config and making adjustments,
            i have been searching for hours and dont get a hang on it, it is much possible that my english is not that good, so i miss details…
            but i dont give up :)
              PierreSweden @sdetweil
              yeah, ive been looking several times on mykle1 description but dont get it to work… i will try your method…
              thanks
                @pierresweden said in Problem install (and config)l new modules:
                you should translate the pages. google translate does a decent job
