    MMM-Ring: Module error
    7 Posts 2 Posters 1.9k Views 2 Watching
    • KanosticK Offline
      Kanostic
      MMM-Ring: Module, is giving me this error when running pm2 logs, this is the only module failing. It was working good until I updated npm I think and now I can’t figure it out.
      0|MagicMirror | [17.07.2021 00:33.49.258] [ERROR]
      0|MagicMirror | 2021-07-17T00:33:49 (node:3641) UnhandledPromiseRejectionWarning: TypeError: Cannot read property ‘subscribe’ of undefined
      0|MagicMirror | at Class.monitorRingActivity (/home/pi/MagicMirror/modules/MMM-Ring/node_helper.js:84:40)
      0|MagicMirror | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Ring/node_helper.js:61:12)
      0|MagicMirror | (/home/pi/MagicMirror/internal/process/warning.js:32 writeOut)
      0|MagicMirror | [17.07.2021 00:33.49.260] [ERROR]
      0|MagicMirror | 2021-07-17T00:33:49 (node:3641) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1) (/home/pi/MagicMirror/internal/process/warning.js:32 writeOut)
      0|MagicMirror | [17.07.2021 00:33.49.261] [ERROR]
      0|MagicMirror | 2021-07-17T00:33:49 (node:3641) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:32 writeOut)
      pi@mm:~/MagicMirror/modules/MMM-Ring $ npm list
      MMM-Ring@1.0.0 /home/pi/MagicMirror/modules/MMM-Ring
      ├── chokidar@3.5.1
      ├── dotenv@8.6.0
      ├── hls.js@0.13.2
      ├── latest-version@5.1.0
      ├── ring-client-api@4.2.3
      └── rxjs@6.6.7
      pi@mm:~/MagicMirror/modules/MMM-Ring $ npm install latest-version
      up to date, audited 105 packages in 3s
      1 package is looking for funding
      run npm fund for details
      2 high severity vulnerabilities
      To address all issues (including breaking changes), run:
      npm audit fix --force
      Run npm audit for details.
      Forgot to include npm version
      pi@mm:~/MagicMirror $ npm -v
      7.19.1
        sdetweil @Kanostic
        @kanostic yes, we’ve seen some errors on npm 7. I would fall back to v6.
        KanosticK 1 Reply Last reply Reply Quote 0
        • KanosticK Offline
          Kanostic @sdetweil
          @sdetweil Thanks I downgraded npm to 6.14.13
          $ npm -v
          6.14.13
          Restarted mm and I’m still getting the same error in the logs, do I need to reinstall MMM-Ring and all it’s dependencies?
            sdetweil @Kanostic
            @kanostic maybe just npm install in the module folder
            • KanosticK Offline
              Kanostic @sdetweil
              @sdetweil Thank you doing a npm install and npm audit fix --force did the trick, apologies for all the basic questions, I am pretty new to Magic Mirror.
              S KanosticK 2 Replies Last reply Reply Quote 1
                sdetweil @Kanostic
                @kanostic said in MMM-Ring: Module error:
                careful on that, many times it causes more problems than it fixes…
                generally recommend to ignore the messages (and we can’t hide them)
                • KanosticK Offline
                  Kanostic @Kanostic
                  Good to know, thank you again.
