    Making persistent and smooth visual timer
    7 Posts 2 Posters 1.2k Views 2 Watching
    • K Offline
      Kiina @sdetweil
      @sdetweil Yeah I just realized I had the setInterval to update the DOM in there and never questioned why I put it there and had kinda forgotten about it. Maybe I should refactor so it only updates the dom when it really gets new information, it has been 4 years since I wrote that part of the module…
      Another small issue
      getScripts: function() {
      		return [ "node_modules/progressbar.js/dist/progressbar.min.js"];
      doesn’t seem to load. The file exists, I have it in my package.json. When i do like a cp node_modules/progressbar.js/dist/progressbar.min.js ./
      and
      		return [ "progressbar.min.js"];
      it works fine, but not when it’s in the node_modules folder? It tries to load the upper node_modules folder I think so
      		return ["modules/moduleName/node_modules/progressbar.js/dist/progressbar.min.js"];
      works fine but is probably not the best solution in case the module name changes.
      Plus it doesn’t seem like the domUpdate has a callback when it finished. Would be nice so I can load the progressbar when the dom container exists, instead of relying on setTimeout and praying for the best.
        sdetweil @Kiina
        @kiina this.file(node-modules…/filename) will give you the total path
        please explain a little better,… load the progressbar when the dom container exists
        u can use
        document.getElementByClassName(className)
        or
        document.getElementById(id)
        so u can know if it exists…
        it won’t til you pass thru getdom once probably
        K 1 Reply Last reply Reply Quote 1
          sdetweil @Kiina
          @kiina said in Making persistent and smooth visual timer:
          pairing code for the oauth only has a 10 minute lifetim
          and, why couldn’t you refresh under the cover for them???
          I do that for some apps that have refresh tokens… timer for time_to_live -5 or 10 seconds
          refresh
          restart timer
          • K Offline
            Kiina @sdetweil
            @sdetweil said in Making persistent and smooth visual timer:
            u can use
            or
            so u can know it it exists…
            That’s what im doing. The issue is that without a callback from the getDOM you would probably have to loop that part.
            Following flow: The node_helper sends the socketnotification with the code for authentification. The dom updates to show this auth code and adds the div for the timer. When I call
            this.updateDom();
            initializeTimer();
            I will get that the current element with the id doesn’t exist since the initializeTimer executes before the dom is ready. So I would need to loop that until the dom is ready to add the timer onto it. Which is obviously a terrible idea. So having a callback or a promise would make that a lot easier. Because currently I would need to do something like that:
            this.updateDom();
            setTimeout(function() {
            initializeTimer();
            }, 1000);
            And pray that the dom changes already happened.
              sdetweil @Kiina
              @kiina create the timer in getDom() when u create the div, after updateDom() says content is available… u can save the div element in global and then have access to it from other places too…
              when the global is not null… then u know it was created
