    Cannot find module "moment"
    98 Posts 2 Posters 64.4k Views 2 Watching
      sdetweil @uok825
      @uok825 cool… didn’t need to reboot… I would have asked u to check the package.json file start line
      U 1 Reply Last reply Reply Quote 0
      • U Offline
        uok825 @sdetweil
        Now another module give an error
        0|MagicMir | [26.07.2021 00:57.11.255] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'uuid/v4'
        0|MagicMir | [26.07.2021 00:57.11.503] [ERROR] Whoops! There was an uncaught exception...
        0|MagicMir | [26.07.2021 00:57.11.562] [ERROR] { Error: Cannot find module 'uuid/v4'
        0|MagicMir |     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
        0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:562:25)
        0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
        0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
        0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/request/lib/auth.js:4:12)
        0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
        0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
        0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12) code: 'MODULE_NOT_FOUND' }
        0|MagicMir | [26.07.2021 00:57.11.573] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|MagicMir | [26.07.2021 00:57.11.584] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
        0|MagicMir | [26.07.2021 00:57.08.308] [LOG] Module helper loaded: newsfeed
        0|MagicMir | [26.07.2021 00:57.11.270] [LOG] Loading module helpers ...
        0|MagicMir | [26.07.2021 00:57.11.284] [LOG] No helper found for module: alert.
        0|MagicMir | [26.07.2021 00:57.11.294] [LOG] Initializing new module helper ...
        0|MagicMir | [26.07.2021 00:57.11.307] [LOG] Module helper loaded: updatenotification
        0|MagicMir | [26.07.2021 00:57.11.316] [LOG] No helper found for module: clock.
        0|MagicMir | [26.07.2021 00:57.11.330] [LOG] Initializing new module helper ...
        0|MagicMir | [26.07.2021 00:57.11.340] [LOG] Module helper loaded: calendar
        0|MagicMir | [26.07.2021 00:57.11.355] [LOG] Initializing new module helper ...
        0|MagicMir | [26.07.2021 00:57.11.361] [LOG] Module helper loaded: currentweather
        0|MagicMir | [26.07.2021 00:57.11.372] [LOG] Initializing new module helper ...
        0|MagicMir | [26.07.2021 00:57.11.382] [LOG] Module helper loaded: weatherforecast
        0|MagicMir | [26.07.2021 00:57.11.396] [LOG] Initializing new module helper ...
        0|MagicMir | [26.07.2021 00:57.11.405] [LOG] Module helper loaded: newsfeed
        0|MagicMir | Starting chromium browser now, have patience, it takes a minute
        Internet is fine.
        Package.json
          sdetweil @uok825
          @uok825 said in Cannot find module "moment":
          looks like a library under request
          npm install uuid
            request and any lib that used request was removed in 2.16 as there was a security problem never to be fixed… so module was deprecated (set end of life)
            MagicMirror removed
              but the internet is working!!
              • U Offline
                uok825 @sdetweil
                @sdetweil Yeah. I also solved the other Raspberry and I know how to solve it here. We would try less if I don’t realize later. I’m sorry to have been ranting. I’m currently installing Uuid if the problem I will write again. Thanks for your labor Sam.
                  sdetweil @uok825
                  @uok825 to shorten the path
                  pm2 stop all
                  then do
                  npm start
                  in the MagicMirror folder
                  alt-spacebar, n to minimize MM
                  then ctrl-c to stop
                  once good, then pm2 status to get the number and
                  pm2 start 0 or whatever number
                  • U Offline
                    uok825 @sdetweil
                    @sdetweil I am connected with SSH. I always did pm2 stop 0, pm2 flush, do my work and pm2 start 0. But PI0 is so slow still doing npm :D
                      sdetweil @uok825
                      @uok825 but don’t need to do pm2 start until its working correctly
                      why do you post screen shots if connected via ssh?/ just copy the text…
                        sdetweil @uok825
                        @uok825 pm2 calls npm same thing…
                        • U Offline
                          uok825 @sdetweil
                          @sdetweil Screenshot is a habit for me to take. easier than copying
                            sdetweil @uok825
                            @uok825 screen shots harder to read here, very tiny… impossible on phone
                            U 2 Replies Last reply Reply Quote 0
                            • U Offline
                              uok825 @sdetweil
                              @sdetweil Sorry to hear it. I try not to receive the screenshot sorry.
                              • U Offline
                                uok825 @sdetweil
                                @sdetweil Bad news
                                npm install log
                                pi@raspberrypi:~/MagicMirror $ npm install uuid
                                > husky@4.2.5 preuninstall /home/pi/MagicMirror/node_modules/husky
                                > node husky uninstall
                                internal/modules/cjs/loader.js:638
                                    throw err;
                                Error: Cannot find module 'please-upgrade-node'
                                    at Object.<anonymous> (/home/pi/MagicMirror/node_modules/husky/husky.js:3:27)
                                npm WARN lifecycle husky@4.2.5~preuninstall: continuing anyway husky@4.2.5 preuninstall: `node husky uninstall`
                                npm WARN lifecycle Exit status 1
                                > electron-chromedriver@11.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                                > node ./download-chromedriver.js
                                (node:1464) UnhandledPromiseRejectionWarning: HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.0.0/chromedriver-v11.0.0-linux-armv6l.zip
                                    at EventEmitter.emitter.on.response (/home/pi/MagicMirror/node_modules/got/source/as-stream.js:35:24)
                                    at EventEmitter.emit (events.js:198:13)
                                    at module.exports (/home/pi/MagicMirror/node_modules/got/source/get-response.js:22:10)
                                    at ClientRequest.handleResponse (/home/pi/MagicMirror/node_modules/got/source/request-as-event-emitter.js:155:5)
                                    at Object.onceWrapper (events.js:286:20)
                                    at ClientRequest.emit (events.js:203:15)
                                    at ClientRequest.origin.emit.args [as emit] (/home/pi/MagicMirror/node_modules/@szmarczak/http-timer/source/index.js:37:11)
                                    at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:565:21)
                                    at HTTPParser.parserOnHeadersComplete (_http_common.js:111:17)
                                    at TLSSocket.socketOnData (_http_client.js:451:20)
                                (node:1464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                                (node:1464) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                > electron@11.4.9 postinstall /home/pi/MagicMirror/node_modules/electron
                                > node install.js
                                HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.4.9/electron-v11.4.9-linux-armv6l.zip
                                > spectron@13.0.0 postinstall /home/pi/MagicMirror/node_modules/spectron
                                > node lib/rpath-fix.js
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 (node_modules/electron):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 postinstall: `node install.js`
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                + uuid@8.3.2
                                added 334 packages from 707 contributors, updated 144 packages and audited 924 packages in 1278.767s
                                110 packages are looking for funding
                                  run `npm fund` for details
                                found 0 vulnerabilities
                                MM Log
                                /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                0|MagicMir | [26.07.2021 01:29.53.118] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                0|MagicMir | [26.07.2021 01:29.53.151] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                0|MagicMir | [26.07.2021 01:29.53.135] [LOG] Connecting socket for: weatherforecast
                                0|MagicMir | [26.07.2021 01:29.53.160] [LOG] Connecting socket for: newsfeed
                                0|MagicMir | [26.07.2021 01:29.53.172] [LOG] Starting node helper for: newsfeed
                                0|MagicMir | [26.07.2021 01:29.53.185] [LOG] Connecting socket for: MMM-cryptocurrency
                                0|MagicMir | [26.07.2021 01:29.53.202] [LOG] Cryptocurrency module loaded!
                                0|MagicMir | [26.07.2021 01:29.53.214] [LOG] Connecting socket for: MMM-MyPrayerTimes
                                0|MagicMir | [26.07.2021 01:29.53.223] [LOG] Starting node_helper for: MMM-MyPrayerTimes
                                0|MagicMir | [26.07.2021 01:29.53.236] [LOG] Connecting socket for: MMM-LICE
                                0|MagicMir | [26.07.2021 01:29.53.251] [LOG] Starting node_helper for: MMM-LICE
                                0|MagicMir | [26.07.2021 01:29.53.263] [LOG] Connecting socket for: MMM-PIR
                                0|MagicMir | [26.07.2021 01:29.53.280] [LOG] Starting module helper: MMM-PIR
                                0|MagicMir | [26.07.2021 01:29.53.289] [LOG] Sockets connected & modules started ...
                                0|MagicMir | [26.07.2021 01:29.53.303] [LOG]
                                0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
                                0|MagicMirror  | [26.07.2021 01:31.55.275] [LOG]
                                0|MagicMirror  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
                                0|MagicMirror  | [26.07.2021 01:31.57.499] [LOG]
                                0|MagicMirror  | Create new newsfetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
                                0|MagicMirror  | [26.07.2021 01:31.58.207] [LOG]
                                0|MagicMirror  | Create new newsfetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
                                0|MagicMirror  | [26.07.2021 01:31.58.335] [LOG]
                                0|MagicMirror  | Create new newsfetcher for url: https://tr.cointelegraph.com/google.xml - Interval: 300000
                                0|MagicMirror  | [26.07.2021 01:32.08.343] [ERROR]
                                0|MagicMirror  | Newsfeed Error. Could not fetch newsfeed:  https://tr.cointelegraph.com/google.xml Error: Feed type not recognized
                                0|MagicMirror  |     at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:99:38)
                                0|MagicMirror  |     at SAXStream.emit (events.js:198:13)
                                0|MagicMirror  |     at SAXStream._parser.parser.emit.args [as emit] (/home/pi/MagicMirror/node_modules/feedme/dist/feedme.js:24:24)
                                0|MagicMirror  |     at SAXParser.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
                                0|MagicMirror  |     at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:624:35)
                                0|MagicMirror  |     at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:629:5)
                                0|MagicMirror  |     at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:825:5)
                                0|MagicMirror  |     at SAXParser.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1391:13)
                                0|MagicMirror  |     at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
                                0|MagicMirror  |     at XMLFeedParser._write (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:159:21)
                                0|MagicMirror  | [26.07.2021 01:32.08.796] [ERROR]
                                0|MagicMirror  | Whoops! There was an uncaught exception...
                                0|MagicMirror  | [26.07.2021 01:32.08.851] [ERROR]
                                0|MagicMirror  | TypeError: $ is not a function
                                0|MagicMirror  |     at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-LICE/node_helper.js:27:27)
                                0|MagicMirror  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:185:22)
                                0|MagicMirror  |     at Request.emit (events.js:198:13)
                                0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1154:10)
                                0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1076:12)
                                0|MagicMirror  |     at Object.onceWrapper (events.js:286:20)
                                0|MagicMirror  |     at IncomingMessage.emit (events.js:203:15)
                                0|MagicMirror  |     at endReadableNT (_stream_readable.js:1145:12)
                                0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:19)
                                0|MagicMirror  | [26.07.2021 01:32.08.884] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                0|MagicMirror  | [26.07.2021 01:32.08.907] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                0|MagicMirror  | [26.07.2021 01:32.09.574] [LOG]
                                0|MagicMirror  | 200[object Object]
                                0|MagicMirror  | [26.07.2021 01:32.45.860] [ERROR]
                                0|MagicMirror  | [26.07.2021 01:32.45.891] [ERROR] TypeError: $ is not a function
                                0|MagicMirror  | [26.07.2021 01:32.45.904] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                0|MagicMirror  | [26.07.2021 01:32.45.926] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                But the good side is now i can see screen. Waiting for loading other modules. Maybe it will working.
                                  sdetweil @uok825
                                  Cannot find module ‘please-upgrade-node’
                                  for every cannot find module, repeat
                                  npm install missing_name
                                  not sure on the rss feed thing… I see the output, but it doesn’t look like a normal xml feed doc
                                  • U Offline
                                    uok825 @sdetweil
                                    @sdetweil I’ll delete cointelegraph. Now i am working on LICE module. I am changed that module code.
                                      sdetweil @uok825
                                      ok, I was looking at the original code and couldn’t find a useful line 27
                                      typically $ is jquery
                                      but the module doesn’t say it needs it…
                                      no package.json for dependencies and the node_helper doesn’t require it
                                      • U Offline
                                        uok825 @sdetweil
                                        /* Magic Mirror
                                         * Module: MMM-LICE
                                         * By Mykle1
                                        const NodeHelper = require('node_helper');
                                        const request = require('request');
                                        const $ = require('cheerio');
                                            start: function() {
                                                console.log("Starting node_helper for: " + this.name);
                                            getLICE: function(url) {
                                            request({
                                                url: 'https://kur.altin.in/banka',
                                                method: 'GET'
                                            }, (error, response, body) => {
                                                if (!error && response.statusCode == 200) {
                                        			var arr = []
                                                    var result = ($('.fiyat',body));
                                                    result.each((_id,el) =>  (arr.push(el.children[0]['data'])))
                                                    var result = ($('h2[id=gfiy]',body));
                                                    this.sendSocketNotification('LICE_RESULT', arr);
                                                if (notification === 'GET_LICE') {
                                                    this.getLICE(payload);
                                          sdetweil @uok825
                                          @uok825 yep, that’ll do it…
                                          npm install cheerio
                                          my updater would have fixed all this IF there was a package.json file that documented the dependencies
                                          npm install request cheerio --save
                                          • U Offline
                                            uok825 @sdetweil
                                            @sdetweil Thanks man. You are the best. https://github.com/uok825/MagicMirror/tree/master/modules/MMM-LICE
                                            • 4 / 5
