    Cannot find module "moment"
    98 Posts 2 Posters 68.6k Views 2 Watching
      sdetweil @uok825
      @uok825 when I do the curl i get
      curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh
      #!/bin/bash
      # only DO npm installs when flag is set to  1
      # test when set to 0
      true=1
      plus all the rest of the script.
      u have a networking problem going on …
      warning, upgrade might fail as IT will try to download new files too
      yes, the upgrade uses curl to get the new package.json file to check the version
      remote_version=$(curl -s https://raw.githubusercontent.com/MichMich/MagicMirror/master/package.json
      and it also fails…
      SO… u need to solve that… are you using pihole somewhere?
      U 2 Replies Last reply
      • U
        uok825 @sdetweil
        @sdetweil AHHHHHHH! Just remembered my other raspberry is stuck on internet too. I change my router so my router adress is changed from 192.168.1.1 to 192.168.1.3 but in my /etc/dhcpcd.conf 37c38ff5-5fcd-4f9b-83c0-5dac86ded6f4-image.png still 192.168.1.1 here sorry for bother you. Trying again.
        • U
          uok825 @sdetweil
          Seems fine. Thanks now i rebooting machine and watch if there is a error.
          pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetwe        il/MagicMirror_scripts/master/upgrade-script.sh)" apply
          No LSB modules are available.
          doing test run = false
          saving custom.css
          upgrading from version 2.12.0 to 2.16.0
          fetching latest revisions
          remote: Enumerating objects: 4413, done.
          remote: Counting objects: 100% (3550/3550), done.
          remote: Compressing objects: 100% (1006/1006), done.
          remote: Total 2836 (delta 1962), reused 2490 (delta 1660), pack-reused 0
          Receiving objects: 100% (2836/2836), 967.15 KiB | 156.00 KiB/s, done.
          Resolving deltas: 100% (1962/1962), completed with 207 local objects.
          From https://github.com/MichMich/MagicMirror
             10dc315f..26a76f80  master     -> origin/master
           * [new tag]           v2.16.0    -> v2.16.0
           * [new tag]           v2.15.0    -> v2.15.0
          npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@        1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my        best with it!
          > core-js@3.15.1 postinstall /home/pi/MagicMirror/node_modules/core-js
          > node -e "try{require('./postinstall')}catch(e){}"
          Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfill        ing JavaScript standard library!
          The project needs your help! Please consider supporting of core-js on Open Colle        ctive or Patreon:
          > https://opencollective.com/core-js
          > https://www.patreon.com/zloirock
          Also, the author of core-js ( https://github.com/zloirock ) is looking for a goo        d job -)
          > electron@11.4.9 postinstall /home/pi/MagicMirror/node_modules/electron
          > node install.js
          HTTPError: Response code 404 (Not Found) for https://github.com/electron/electro        n/releases/download/v11.4.9/electron-v11.4.9-linux-armv6l.zip
              at EventEmitter.emitter.on.response (/home/pi/MagicMirror/node_modules/got/s        ource/as-stream.js:35:24)
              at EventEmitter.emit (events.js:198:13)
              at module.exports (/home/pi/MagicMirror/node_modules/got/source/get-response        .js:22:10)
              at ClientRequest.handleResponse (/home/pi/MagicMirror/node_modules/got/sourc        e/request-as-event-emitter.js:155:5)
              at Object.onceWrapper (events.js:286:20)
              at ClientRequest.emit (events.js:203:15)
              at ClientRequest.origin.emit.args [as emit] (/home/pi/MagicMirror/node_modul        es/@szmarczak/http-timer/source/index.js:37:11)
              at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:565:21        )
              at HTTPParser.parserOnHeadersComplete (_http_common.js:111:17)
              at TLSSocket.socketOnData (_http_client.js:451:20)
          > magicmirror@2.16.0 install /home/pi/MagicMirror
          " && cd vendor && npm install --loglevel=error
          > @fortawesome/fontawesome-free@5.15.3 postinstall /home/pi/MagicMirror/vendor/n        ode_modules/@fortawesome/fontawesome-free
          > node attribution.js
          Font Awesome Free 5.15.3 by @fontawesome - https://fontawesome.com
          License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL        1.1, Code: MIT License)
          added 1 package from 1 contributor, removed 74 packages, updated 5 packages and        audited 9 packages in 83.089s
          found 0 vulnerabilities
          > magicmirror@2.16.0 postinstall /home/pi/MagicMirror
          > npm run install-fonts && echo "MagicMirror installation finished successfully!
          > magicmirror@2.16.0 install-fonts /home/pi/MagicMirror
          > echo "Installing fonts ...
          " && cd fonts && npm install --loglevel=error
          audited 1 package in 7.24s
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 (node_modules/el        ectron):
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 postinstall: `no        de install.js`
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
          added 67 packages from 88 contributors, removed 489 packages, updated 98 package        s and audited 923 packages in 621.679s
          34 packages are looking for funding
            run `npm fund` for details
          processing for module MMM-MyPrayerTimes please wait
          npm notice created a lockfile as package-lock.json. You should commit this file.
          added 2 packages from 6 contributors and audited 2 packages in 16.096s
          processing complete for module MMM-MyPrayerTimes
          processing for module MMM-LICE please wait
          added 64 packages from 69 contributors and audited 64 packages in 71.651s
          13 packages are looking for funding
          processing complete for module MMM-LICE
          processing for module MMM-PIR please wait
          > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
          > node-gyp rebuild
          make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
            CXX(target) Release/obj.target/epoll/src/epoll.o
            SOLINK_MODULE(target) Release/obj.target/epoll.node
            COPY Release/epoll.node
          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
          added 6 packages from 9 contributors and audited 6 packages in 72.078s
          processing complete for module MMM-PIR
          restoring custom.css
            sdetweil @uok825
            @uok825 cool… didn’t need to reboot… I would have asked u to check the package.json file start line
            U 1 Reply Last reply
            • U
              uok825 @sdetweil
              Now another module give an error
              0|MagicMir | [26.07.2021 00:57.11.255] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'uuid/v4'
              0|MagicMir | [26.07.2021 00:57.11.503] [ERROR] Whoops! There was an uncaught exception...
              0|MagicMir | [26.07.2021 00:57.11.562] [ERROR] { Error: Cannot find module 'uuid/v4'
              0|MagicMir |     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
              0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
              0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:562:25)
              0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
              0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
              0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/request/lib/auth.js:4:12)
              0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
              0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
              0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
              0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12) code: 'MODULE_NOT_FOUND' }
              0|MagicMir | [26.07.2021 00:57.11.573] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
              0|MagicMir | [26.07.2021 00:57.11.584] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
              0|MagicMir | [26.07.2021 00:57.08.308] [LOG] Module helper loaded: newsfeed
              0|MagicMir | [26.07.2021 00:57.11.270] [LOG] Loading module helpers ...
              0|MagicMir | [26.07.2021 00:57.11.284] [LOG] No helper found for module: alert.
              0|MagicMir | [26.07.2021 00:57.11.294] [LOG] Initializing new module helper ...
              0|MagicMir | [26.07.2021 00:57.11.307] [LOG] Module helper loaded: updatenotification
              0|MagicMir | [26.07.2021 00:57.11.316] [LOG] No helper found for module: clock.
              0|MagicMir | [26.07.2021 00:57.11.330] [LOG] Initializing new module helper ...
              0|MagicMir | [26.07.2021 00:57.11.340] [LOG] Module helper loaded: calendar
              0|MagicMir | [26.07.2021 00:57.11.355] [LOG] Initializing new module helper ...
              0|MagicMir | [26.07.2021 00:57.11.361] [LOG] Module helper loaded: currentweather
              0|MagicMir | [26.07.2021 00:57.11.372] [LOG] Initializing new module helper ...
              0|MagicMir | [26.07.2021 00:57.11.382] [LOG] Module helper loaded: weatherforecast
              0|MagicMir | [26.07.2021 00:57.11.396] [LOG] Initializing new module helper ...
              0|MagicMir | [26.07.2021 00:57.11.405] [LOG] Module helper loaded: newsfeed
              0|MagicMir | Starting chromium browser now, have patience, it takes a minute
              Internet is fine.
              Package.json
                sdetweil @uok825
                @uok825 said in Cannot find module "moment":
                looks like a library under request
                npm install uuid
                  request and any lib that used request was removed in 2.16 as there was a security problem never to be fixed… so module was deprecated (set end of life)
                  MagicMirror removed
                    but the internet is working!!
                    • U
                      uok825 @sdetweil
                      @sdetweil Yeah. I also solved the other Raspberry and I know how to solve it here. We would try less if I don’t realize later. I’m sorry to have been ranting. I’m currently installing Uuid if the problem I will write again. Thanks for your labor Sam.
                        sdetweil @uok825
                        @uok825 to shorten the path
                        pm2 stop all
                        then do
                        npm start
                        in the MagicMirror folder
                        alt-spacebar, n to minimize MM
                        then ctrl-c to stop
                        once good, then pm2 status to get the number and
                        pm2 start 0 or whatever number
                        • U
                          uok825 @sdetweil
                          @sdetweil I am connected with SSH. I always did pm2 stop 0, pm2 flush, do my work and pm2 start 0. But PI0 is so slow still doing npm :D
                          S 2 Replies Last reply
                            sdetweil @uok825
                            @uok825 but don’t need to do pm2 start until its working correctly
                            why do you post screen shots if connected via ssh?/ just copy the text…
                              sdetweil @uok825
                              @uok825 pm2 calls npm same thing…
                              • U
                                uok825 @sdetweil
                                @sdetweil Screenshot is a habit for me to take. easier than copying
                                  sdetweil @uok825
                                  @uok825 screen shots harder to read here, very tiny… impossible on phone
                                  • U
                                    uok825 @sdetweil
                                    @sdetweil Sorry to hear it. I try not to receive the screenshot sorry.
                                    • U
                                      uok825 @sdetweil
                                      @sdetweil Bad news
                                      npm install log
                                      pi@raspberrypi:~/MagicMirror $ npm install uuid
                                      > husky@4.2.5 preuninstall /home/pi/MagicMirror/node_modules/husky
                                      > node husky uninstall
                                      internal/modules/cjs/loader.js:638
                                          throw err;
                                      Error: Cannot find module 'please-upgrade-node'
                                          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/husky/husky.js:3:27)
                                      npm WARN lifecycle husky@4.2.5~preuninstall: continuing anyway husky@4.2.5 preuninstall: `node husky uninstall`
                                      npm WARN lifecycle Exit status 1
                                      > electron-chromedriver@11.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                                      > node ./download-chromedriver.js
                                      (node:1464) UnhandledPromiseRejectionWarning: HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.0.0/chromedriver-v11.0.0-linux-armv6l.zip
                                          at EventEmitter.emitter.on.response (/home/pi/MagicMirror/node_modules/got/source/as-stream.js:35:24)
                                          at module.exports (/home/pi/MagicMirror/node_modules/got/source/get-response.js:22:10)
                                          at ClientRequest.handleResponse (/home/pi/MagicMirror/node_modules/got/source/request-as-event-emitter.js:155:5)
                                          at ClientRequest.origin.emit.args [as emit] (/home/pi/MagicMirror/node_modules/@szmarczak/http-timer/source/index.js:37:11)
                                          at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:565:21)
                                      (node:1464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                                      (node:1464) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                      > node install.js
                                      HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.4.9/electron-v11.4.9-linux-armv6l.zip
                                      > spectron@13.0.0 postinstall /home/pi/MagicMirror/node_modules/spectron
                                      > node lib/rpath-fix.js
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 (node_modules/electron):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 postinstall: `node install.js`
                                      + uuid@8.3.2
                                      added 334 packages from 707 contributors, updated 144 packages and audited 924 packages in 1278.767s
                                      110 packages are looking for funding
                                      MM Log
                                      /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                      0|MagicMir | [26.07.2021 01:29.53.118] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                      0|MagicMir | [26.07.2021 01:29.53.151] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                      0|MagicMir | [26.07.2021 01:29.53.135] [LOG] Connecting socket for: weatherforecast
                                      0|MagicMir | [26.07.2021 01:29.53.160] [LOG] Connecting socket for: newsfeed
                                      0|MagicMir | [26.07.2021 01:29.53.172] [LOG] Starting node helper for: newsfeed
                                      0|MagicMir | [26.07.2021 01:29.53.185] [LOG] Connecting socket for: MMM-cryptocurrency
                                      0|MagicMir | [26.07.2021 01:29.53.202] [LOG] Cryptocurrency module loaded!
                                      0|MagicMir | [26.07.2021 01:29.53.214] [LOG] Connecting socket for: MMM-MyPrayerTimes
                                      0|MagicMir | [26.07.2021 01:29.53.223] [LOG] Starting node_helper for: MMM-MyPrayerTimes
                                      0|MagicMir | [26.07.2021 01:29.53.236] [LOG] Connecting socket for: MMM-LICE
                                      0|MagicMir | [26.07.2021 01:29.53.251] [LOG] Starting node_helper for: MMM-LICE
                                      0|MagicMir | [26.07.2021 01:29.53.263] [LOG] Connecting socket for: MMM-PIR
                                      0|MagicMir | [26.07.2021 01:29.53.280] [LOG] Starting module helper: MMM-PIR
                                      0|MagicMir | [26.07.2021 01:29.53.289] [LOG] Sockets connected & modules started ...
                                      0|MagicMir | [26.07.2021 01:29.53.303] [LOG]
                                      0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
                                      0|MagicMirror  | [26.07.2021 01:31.55.275] [LOG]
                                      0|MagicMirror  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
                                      0|MagicMirror  | [26.07.2021 01:31.57.499] [LOG]
                                      0|MagicMirror  | Create new newsfetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
                                      0|MagicMirror  | [26.07.2021 01:31.58.207] [LOG]
                                      0|MagicMirror  | Create new newsfetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
                                      0|MagicMirror  | [26.07.2021 01:31.58.335] [LOG]
                                      0|MagicMirror  | Create new newsfetcher for url: https://tr.cointelegraph.com/google.xml - Interval: 300000
                                      0|MagicMirror  | [26.07.2021 01:32.08.343] [ERROR]
                                      0|MagicMirror  | Newsfeed Error. Could not fetch newsfeed:  https://tr.cointelegraph.com/google.xml Error: Feed type not recognized
                                      0|MagicMirror  |     at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:99:38)
                                      0|MagicMirror  |     at SAXStream.emit (events.js:198:13)
                                      0|MagicMirror  |     at SAXStream._parser.parser.emit.args [as emit] (/home/pi/MagicMirror/node_modules/feedme/dist/feedme.js:24:24)
                                      0|MagicMirror  |     at SAXParser.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
                                      0|MagicMirror  |     at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:624:35)
                                      0|MagicMirror  |     at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:629:5)
                                      0|MagicMirror  |     at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:825:5)
                                      0|MagicMirror  |     at SAXParser.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1391:13)
                                      0|MagicMirror  |     at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
                                      0|MagicMirror  |     at XMLFeedParser._write (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:159:21)
                                      0|MagicMirror  | [26.07.2021 01:32.08.796] [ERROR]
                                      0|MagicMirror  | Whoops! There was an uncaught exception...
                                      0|MagicMirror  | [26.07.2021 01:32.08.851] [ERROR]
                                      0|MagicMirror  | TypeError: $ is not a function
                                      0|MagicMirror  |     at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-LICE/node_helper.js:27:27)
                                      0|MagicMirror  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:185:22)
                                      0|MagicMirror  |     at Request.emit (events.js:198:13)
                                      0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1154:10)
                                      0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1076:12)
                                      0|MagicMirror  |     at Object.onceWrapper (events.js:286:20)
                                      0|MagicMirror  |     at IncomingMessage.emit (events.js:203:15)
                                      0|MagicMirror  |     at endReadableNT (_stream_readable.js:1145:12)
                                      0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:19)
                                      0|MagicMirror  | [26.07.2021 01:32.08.884] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMirror  | [26.07.2021 01:32.08.907] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|MagicMirror  | [26.07.2021 01:32.09.574] [LOG]
                                      0|MagicMirror  | 200[object Object]
                                      0|MagicMirror  | [26.07.2021 01:32.45.860] [ERROR]
                                      0|MagicMirror  | [26.07.2021 01:32.45.891] [ERROR] TypeError: $ is not a function
                                      0|MagicMirror  | [26.07.2021 01:32.45.904] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMirror  | [26.07.2021 01:32.45.926] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      But the good side is now i can see screen. Waiting for loading other modules. Maybe it will working.
                                        sdetweil @uok825
                                        Cannot find module ‘please-upgrade-node’
                                        for every cannot find module, repeat
                                        npm install missing_name
                                        not sure on the rss feed thing… I see the output, but it doesn’t look like a normal xml feed doc
                                        • U
                                          uok825 @sdetweil
                                          @sdetweil I’ll delete cointelegraph. Now i am working on LICE module. I am changed that module code.
                                            sdetweil @uok825
                                            ok, I was looking at the original code and couldn’t find a useful line 27
                                            typically $ is jquery
                                            but the module doesn’t say it needs it…
                                            no package.json for dependencies and the node_helper doesn’t require it
                                            • 4 / 5
