    Cannot find module "moment"
    98 Posts 2 Posters 68.3k Views 2 Watching
    • U
      uok825 @sdetweil
      @sdetweil said in Cannot find module "moment":
      MagicMirror/installers/upgrade-script.sh apply
        sdetweil @uok825
        @uok825 when I do the curl i get
        curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh
        #!/bin/bash
        # only DO npm installs when flag is set to  1
        # test when set to 0
        true=1
        plus all the rest of the script.
        u have a networking problem going on …
        warning, upgrade might fail as IT will try to download new files too
        yes, the upgrade uses curl to get the new package.json file to check the version
        remote_version=$(curl -s https://raw.githubusercontent.com/MichMich/MagicMirror/master/package.json
        and it also fails…
        SO… u need to solve that… are you using pihole somewhere?
        U 2 Replies Last reply
        • U
          uok825 @sdetweil
          @sdetweil AHHHHHHH! Just remembered my other raspberry is stuck on internet too. I change my router so my router adress is changed from 192.168.1.1 to 192.168.1.3 but in my /etc/dhcpcd.conf 37c38ff5-5fcd-4f9b-83c0-5dac86ded6f4-image.png still 192.168.1.1 here sorry for bother you. Trying again.
          • U
            uok825 @sdetweil
            Seems fine. Thanks now i rebooting machine and watch if there is a error.
            pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetwe        il/MagicMirror_scripts/master/upgrade-script.sh)" apply
            No LSB modules are available.
            doing test run = false
            saving custom.css
            upgrading from version 2.12.0 to 2.16.0
            fetching latest revisions
            remote: Enumerating objects: 4413, done.
            remote: Counting objects: 100% (3550/3550), done.
            remote: Compressing objects: 100% (1006/1006), done.
            remote: Total 2836 (delta 1962), reused 2490 (delta 1660), pack-reused 0
            Receiving objects: 100% (2836/2836), 967.15 KiB | 156.00 KiB/s, done.
            Resolving deltas: 100% (1962/1962), completed with 207 local objects.
            From https://github.com/MichMich/MagicMirror
               10dc315f..26a76f80  master     -> origin/master
             * [new tag]           v2.16.0    -> v2.16.0
             * [new tag]           v2.15.0    -> v2.15.0
            npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@        1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my        best with it!
            > core-js@3.15.1 postinstall /home/pi/MagicMirror/node_modules/core-js
            > node -e "try{require('./postinstall')}catch(e){}"
            Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfill        ing JavaScript standard library!
            The project needs your help! Please consider supporting of core-js on Open Colle        ctive or Patreon:
            > https://opencollective.com/core-js
            > https://www.patreon.com/zloirock
            Also, the author of core-js ( https://github.com/zloirock ) is looking for a goo        d job -)
            > electron@11.4.9 postinstall /home/pi/MagicMirror/node_modules/electron
            > node install.js
            HTTPError: Response code 404 (Not Found) for https://github.com/electron/electro        n/releases/download/v11.4.9/electron-v11.4.9-linux-armv6l.zip
                at EventEmitter.emitter.on.response (/home/pi/MagicMirror/node_modules/got/s        ource/as-stream.js:35:24)
                at EventEmitter.emit (events.js:198:13)
                at module.exports (/home/pi/MagicMirror/node_modules/got/source/get-response        .js:22:10)
                at ClientRequest.handleResponse (/home/pi/MagicMirror/node_modules/got/sourc        e/request-as-event-emitter.js:155:5)
                at Object.onceWrapper (events.js:286:20)
                at ClientRequest.emit (events.js:203:15)
                at ClientRequest.origin.emit.args [as emit] (/home/pi/MagicMirror/node_modul        es/@szmarczak/http-timer/source/index.js:37:11)
                at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:565:21        )
                at HTTPParser.parserOnHeadersComplete (_http_common.js:111:17)
                at TLSSocket.socketOnData (_http_client.js:451:20)
            > magicmirror@2.16.0 install /home/pi/MagicMirror
            " && cd vendor && npm install --loglevel=error
            > @fortawesome/fontawesome-free@5.15.3 postinstall /home/pi/MagicMirror/vendor/n        ode_modules/@fortawesome/fontawesome-free
            > node attribution.js
            Font Awesome Free 5.15.3 by @fontawesome - https://fontawesome.com
            License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL        1.1, Code: MIT License)
            added 1 package from 1 contributor, removed 74 packages, updated 5 packages and        audited 9 packages in 83.089s
            found 0 vulnerabilities
            > magicmirror@2.16.0 postinstall /home/pi/MagicMirror
            > npm run install-fonts && echo "MagicMirror installation finished successfully!
            > magicmirror@2.16.0 install-fonts /home/pi/MagicMirror
            > echo "Installing fonts ...
            " && cd fonts && npm install --loglevel=error
            audited 1 package in 7.24s
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 (node_modules/el        ectron):
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 postinstall: `no        de install.js`
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
            added 67 packages from 88 contributors, removed 489 packages, updated 98 package        s and audited 923 packages in 621.679s
            34 packages are looking for funding
              run `npm fund` for details
            processing for module MMM-MyPrayerTimes please wait
            npm notice created a lockfile as package-lock.json. You should commit this file.
            added 2 packages from 6 contributors and audited 2 packages in 16.096s
            processing complete for module MMM-MyPrayerTimes
            processing for module MMM-LICE please wait
            added 64 packages from 69 contributors and audited 64 packages in 71.651s
            13 packages are looking for funding
            processing complete for module MMM-LICE
            processing for module MMM-PIR please wait
            > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
            > node-gyp rebuild
            make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
              CXX(target) Release/obj.target/epoll/src/epoll.o
              SOLINK_MODULE(target) Release/obj.target/epoll.node
              COPY Release/epoll.node
            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
            added 6 packages from 9 contributors and audited 6 packages in 72.078s
            processing complete for module MMM-PIR
            restoring custom.css
              sdetweil @uok825
              @uok825 cool… didn’t need to reboot… I would have asked u to check the package.json file start line
              U 1 Reply Last reply
              • U
                uok825 @sdetweil
                Now another module give an error
                0|MagicMir | [26.07.2021 00:57.11.255] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'uuid/v4'
                0|MagicMir | [26.07.2021 00:57.11.503] [ERROR] Whoops! There was an uncaught exception...
                0|MagicMir | [26.07.2021 00:57.11.562] [ERROR] { Error: Cannot find module 'uuid/v4'
                0|MagicMir |     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
                0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
                0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/request/lib/auth.js:4:12)
                0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
                0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
                0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12) code: 'MODULE_NOT_FOUND' }
                0|MagicMir | [26.07.2021 00:57.11.573] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                0|MagicMir | [26.07.2021 00:57.11.584] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                0|MagicMir | [26.07.2021 00:57.08.308] [LOG] Module helper loaded: newsfeed
                0|MagicMir | [26.07.2021 00:57.11.270] [LOG] Loading module helpers ...
                0|MagicMir | [26.07.2021 00:57.11.284] [LOG] No helper found for module: alert.
                0|MagicMir | [26.07.2021 00:57.11.294] [LOG] Initializing new module helper ...
                0|MagicMir | [26.07.2021 00:57.11.307] [LOG] Module helper loaded: updatenotification
                0|MagicMir | [26.07.2021 00:57.11.316] [LOG] No helper found for module: clock.
                0|MagicMir | [26.07.2021 00:57.11.330] [LOG] Initializing new module helper ...
                0|MagicMir | [26.07.2021 00:57.11.340] [LOG] Module helper loaded: calendar
                0|MagicMir | [26.07.2021 00:57.11.355] [LOG] Initializing new module helper ...
                0|MagicMir | [26.07.2021 00:57.11.361] [LOG] Module helper loaded: currentweather
                0|MagicMir | [26.07.2021 00:57.11.372] [LOG] Initializing new module helper ...
                0|MagicMir | [26.07.2021 00:57.11.382] [LOG] Module helper loaded: weatherforecast
                0|MagicMir | [26.07.2021 00:57.11.396] [LOG] Initializing new module helper ...
                0|MagicMir | [26.07.2021 00:57.11.405] [LOG] Module helper loaded: newsfeed
                0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                Internet is fine.
                Package.json
                  sdetweil @uok825
                  @uok825 said in Cannot find module "moment":
                  looks like a library under request
                  npm install uuid
                    request and any lib that used request was removed in 2.16 as there was a security problem never to be fixed… so module was deprecated (set end of life)
                    MagicMirror removed
                      but the internet is working!!
                      • U
                        uok825 @sdetweil
                        @sdetweil Yeah. I also solved the other Raspberry and I know how to solve it here. We would try less if I don’t realize later. I’m sorry to have been ranting. I’m currently installing Uuid if the problem I will write again. Thanks for your labor Sam.
                          sdetweil @uok825
                          @uok825 to shorten the path
                          pm2 stop all
                          then do
                          npm start
                          in the MagicMirror folder
                          alt-spacebar, n to minimize MM
                          then ctrl-c to stop
                          once good, then pm2 status to get the number and
                          pm2 start 0 or whatever number
                          • U
                            uok825 @sdetweil
                            @sdetweil I am connected with SSH. I always did pm2 stop 0, pm2 flush, do my work and pm2 start 0. But PI0 is so slow still doing npm :D
                            S 2 Replies Last reply
                              sdetweil @uok825
                              @uok825 but don’t need to do pm2 start until its working correctly
                              why do you post screen shots if connected via ssh?/ just copy the text…
                                sdetweil @uok825
                                @uok825 pm2 calls npm same thing…
                                • U
                                  uok825 @sdetweil
                                  @sdetweil Screenshot is a habit for me to take. easier than copying
                                    sdetweil @uok825
                                    @uok825 screen shots harder to read here, very tiny… impossible on phone
                                    • U
                                      uok825 @sdetweil
                                      @sdetweil Sorry to hear it. I try not to receive the screenshot sorry.
                                      • U
                                        uok825 @sdetweil
                                        @sdetweil Bad news
                                        npm install log
                                        pi@raspberrypi:~/MagicMirror $ npm install uuid
                                        > husky@4.2.5 preuninstall /home/pi/MagicMirror/node_modules/husky
                                        > node husky uninstall
                                        internal/modules/cjs/loader.js:638
                                            throw err;
                                        Error: Cannot find module 'please-upgrade-node'
                                            at Object.<anonymous> (/home/pi/MagicMirror/node_modules/husky/husky.js:3:27)
                                        npm WARN lifecycle husky@4.2.5~preuninstall: continuing anyway husky@4.2.5 preuninstall: `node husky uninstall`
                                        npm WARN lifecycle Exit status 1
                                        > electron-chromedriver@11.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                                        > node ./download-chromedriver.js
                                        (node:1464) UnhandledPromiseRejectionWarning: HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.0.0/chromedriver-v11.0.0-linux-armv6l.zip
                                            at EventEmitter.emitter.on.response (/home/pi/MagicMirror/node_modules/got/source/as-stream.js:35:24)
                                            at module.exports (/home/pi/MagicMirror/node_modules/got/source/get-response.js:22:10)
                                            at ClientRequest.handleResponse (/home/pi/MagicMirror/node_modules/got/source/request-as-event-emitter.js:155:5)
                                            at ClientRequest.origin.emit.args [as emit] (/home/pi/MagicMirror/node_modules/@szmarczak/http-timer/source/index.js:37:11)
                                            at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:565:21)
                                        (node:1464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                                        (node:1464) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                        > node install.js
                                        HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.4.9/electron-v11.4.9-linux-armv6l.zip
                                        > spectron@13.0.0 postinstall /home/pi/MagicMirror/node_modules/spectron
                                        > node lib/rpath-fix.js
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                                        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 (node_modules/electron):
                                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 postinstall: `node install.js`
                                        + uuid@8.3.2
                                        added 334 packages from 707 contributors, updated 144 packages and audited 924 packages in 1278.767s
                                        110 packages are looking for funding
                                        MM Log
                                        /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                        0|MagicMir | [26.07.2021 01:29.53.118] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                        0|MagicMir | [26.07.2021 01:29.53.151] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                                        0|MagicMir | [26.07.2021 01:29.53.135] [LOG] Connecting socket for: weatherforecast
                                        0|MagicMir | [26.07.2021 01:29.53.160] [LOG] Connecting socket for: newsfeed
                                        0|MagicMir | [26.07.2021 01:29.53.172] [LOG] Starting node helper for: newsfeed
                                        0|MagicMir | [26.07.2021 01:29.53.185] [LOG] Connecting socket for: MMM-cryptocurrency
                                        0|MagicMir | [26.07.2021 01:29.53.202] [LOG] Cryptocurrency module loaded!
                                        0|MagicMir | [26.07.2021 01:29.53.214] [LOG] Connecting socket for: MMM-MyPrayerTimes
                                        0|MagicMir | [26.07.2021 01:29.53.223] [LOG] Starting node_helper for: MMM-MyPrayerTimes
                                        0|MagicMir | [26.07.2021 01:29.53.236] [LOG] Connecting socket for: MMM-LICE
                                        0|MagicMir | [26.07.2021 01:29.53.251] [LOG] Starting node_helper for: MMM-LICE
                                        0|MagicMir | [26.07.2021 01:29.53.263] [LOG] Connecting socket for: MMM-PIR
                                        0|MagicMir | [26.07.2021 01:29.53.280] [LOG] Starting module helper: MMM-PIR
                                        0|MagicMir | [26.07.2021 01:29.53.289] [LOG] Sockets connected & modules started ...
                                        0|MagicMir | [26.07.2021 01:29.53.303] [LOG]
                                        0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
                                        0|MagicMirror  | [26.07.2021 01:31.55.275] [LOG]
                                        0|MagicMirror  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
                                        0|MagicMirror  | [26.07.2021 01:31.57.499] [LOG]
                                        0|MagicMirror  | Create new newsfetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
                                        0|MagicMirror  | [26.07.2021 01:31.58.207] [LOG]
                                        0|MagicMirror  | Create new newsfetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
                                        0|MagicMirror  | [26.07.2021 01:31.58.335] [LOG]
                                        0|MagicMirror  | Create new newsfetcher for url: https://tr.cointelegraph.com/google.xml - Interval: 300000
                                        0|MagicMirror  | [26.07.2021 01:32.08.343] [ERROR]
                                        0|MagicMirror  | Newsfeed Error. Could not fetch newsfeed:  https://tr.cointelegraph.com/google.xml Error: Feed type not recognized
                                        0|MagicMirror  |     at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:99:38)
                                        0|MagicMirror  |     at SAXStream.emit (events.js:198:13)
                                        0|MagicMirror  |     at SAXStream._parser.parser.emit.args [as emit] (/home/pi/MagicMirror/node_modules/feedme/dist/feedme.js:24:24)
                                        0|MagicMirror  |     at SAXParser.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
                                        0|MagicMirror  |     at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:624:35)
                                        0|MagicMirror  |     at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:629:5)
                                        0|MagicMirror  |     at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:825:5)
                                        0|MagicMirror  |     at SAXParser.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1391:13)
                                        0|MagicMirror  |     at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
                                        0|MagicMirror  |     at XMLFeedParser._write (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:159:21)
                                        0|MagicMirror  | [26.07.2021 01:32.08.796] [ERROR]
                                        0|MagicMirror  | Whoops! There was an uncaught exception...
                                        0|MagicMirror  | [26.07.2021 01:32.08.851] [ERROR]
                                        0|MagicMirror  | TypeError: $ is not a function
                                        0|MagicMirror  |     at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-LICE/node_helper.js:27:27)
                                        0|MagicMirror  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:185:22)
                                        0|MagicMirror  |     at Request.emit (events.js:198:13)
                                        0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1154:10)
                                        0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1076:12)
                                        0|MagicMirror  |     at Object.onceWrapper (events.js:286:20)
                                        0|MagicMirror  |     at IncomingMessage.emit (events.js:203:15)
                                        0|MagicMirror  |     at endReadableNT (_stream_readable.js:1145:12)
                                        0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:19)
                                        0|MagicMirror  | [26.07.2021 01:32.08.884] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        0|MagicMirror  | [26.07.2021 01:32.08.907] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        0|MagicMirror  | [26.07.2021 01:32.09.574] [LOG]
                                        0|MagicMirror  | 200[object Object]
                                        0|MagicMirror  | [26.07.2021 01:32.45.860] [ERROR]
                                        0|MagicMirror  | [26.07.2021 01:32.45.891] [ERROR] TypeError: $ is not a function
                                        0|MagicMirror  | [26.07.2021 01:32.45.904] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        0|MagicMirror  | [26.07.2021 01:32.45.926] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        But the good side is now i can see screen. Waiting for loading other modules. Maybe it will working.
                                          sdetweil @uok825
                                          Cannot find module ‘please-upgrade-node’
                                          for every cannot find module, repeat
                                          npm install missing_name
                                          not sure on the rss feed thing… I see the output, but it doesn’t look like a normal xml feed doc
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil I’ll delete cointelegraph. Now i am working on LICE module. I am changed that module code.
                                            • 4 / 5
