    Cannot find module "moment"
    98 Posts 2 Posters 67.0k Views 2 Watching
      sdetweil @uok825
      @uok825 said in Cannot find module "moment":
      /home/pi/MagicMirror/node_modules/request/lib/auth.js
      looks like a library under request
      npm install uuid
        request and any lib that used request was removed in 2.16 as there was a security problem never to be fixed… so module was deprecated (set end of life)
        MagicMirror removed
          but the internet is working!!
          U 1 Reply Last reply Reply Quote 0
          • U
            uok825 @sdetweil
            @sdetweil Yeah. I also solved the other Raspberry and I know how to solve it here. We would try less if I don’t realize later. I’m sorry to have been ranting. I’m currently installing Uuid if the problem I will write again. Thanks for your labor Sam.
              sdetweil @uok825
              @uok825 to shorten the path
              pm2 stop all
              then do
              npm start
              in the MagicMirror folder
              alt-spacebar, n to minimize MM
              then ctrl-c to stop
              once good, then pm2 status to get the number and
              pm2 start 0 or whatever number
              • U
                uok825 @sdetweil
                @sdetweil I am connected with SSH. I always did pm2 stop 0, pm2 flush, do my work and pm2 start 0. But PI0 is so slow still doing npm :D
                  sdetweil @uok825
                  @uok825 but don’t need to do pm2 start until its working correctly
                  why do you post screen shots if connected via ssh?/ just copy the text…
                    sdetweil @uok825
                    @uok825 pm2 calls npm same thing…
                    • U
                      uok825 @sdetweil
                      @sdetweil Screenshot is a habit for me to take. easier than copying
                        sdetweil @uok825
                        @uok825 screen shots harder to read here, very tiny… impossible on phone
                        U 2 Replies Last reply Reply Quote 0
                        • U
                          uok825 @sdetweil
                          @sdetweil Sorry to hear it. I try not to receive the screenshot sorry.
                          • U
                            uok825 @sdetweil
                            @sdetweil Bad news
                            npm install log
                            pi@raspberrypi:~/MagicMirror $ npm install uuid
                            > husky@4.2.5 preuninstall /home/pi/MagicMirror/node_modules/husky
                            > node husky uninstall
                            internal/modules/cjs/loader.js:638
                                throw err;
                            Error: Cannot find module 'please-upgrade-node'
                                at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                at Module.require (internal/modules/cjs/loader.js:692:17)
                                at require (internal/modules/cjs/helpers.js:25:18)
                                at Object.<anonymous> (/home/pi/MagicMirror/node_modules/husky/husky.js:3:27)
                            npm WARN lifecycle husky@4.2.5~preuninstall: continuing anyway husky@4.2.5 preuninstall: `node husky uninstall`
                            npm WARN lifecycle Exit status 1
                            > electron-chromedriver@11.0.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                            > node ./download-chromedriver.js
                            (node:1464) UnhandledPromiseRejectionWarning: HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.0.0/chromedriver-v11.0.0-linux-armv6l.zip
                                at EventEmitter.emitter.on.response (/home/pi/MagicMirror/node_modules/got/source/as-stream.js:35:24)
                                at EventEmitter.emit (events.js:198:13)
                                at module.exports (/home/pi/MagicMirror/node_modules/got/source/get-response.js:22:10)
                                at ClientRequest.handleResponse (/home/pi/MagicMirror/node_modules/got/source/request-as-event-emitter.js:155:5)
                                at Object.onceWrapper (events.js:286:20)
                                at ClientRequest.emit (events.js:203:15)
                                at ClientRequest.origin.emit.args [as emit] (/home/pi/MagicMirror/node_modules/@szmarczak/http-timer/source/index.js:37:11)
                                at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:565:21)
                                at HTTPParser.parserOnHeadersComplete (_http_common.js:111:17)
                                at TLSSocket.socketOnData (_http_client.js:451:20)
                            (node:1464) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                            (node:1464) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                            > electron@11.4.9 postinstall /home/pi/MagicMirror/node_modules/electron
                            > node install.js
                            HTTPError: Response code 404 (Not Found) for https://github.com/electron/electron/releases/download/v11.4.9/electron-v11.4.9-linux-armv6l.zip
                            > spectron@13.0.0 postinstall /home/pi/MagicMirror/node_modules/spectron
                            > node lib/rpath-fix.js
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 (node_modules/electron):
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 postinstall: `node install.js`
                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                            + uuid@8.3.2
                            added 334 packages from 707 contributors, updated 144 packages and audited 924 packages in 1278.767s
                            110 packages are looking for funding
                              run `npm fund` for details
                            found 0 vulnerabilities
                            MM Log
                            /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                            0|MagicMir | [26.07.2021 01:29.53.118] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                            0|MagicMir | [26.07.2021 01:29.53.151] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
                            /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                            0|MagicMir | [26.07.2021 01:29.53.135] [LOG] Connecting socket for: weatherforecast
                            0|MagicMir | [26.07.2021 01:29.53.160] [LOG] Connecting socket for: newsfeed
                            0|MagicMir | [26.07.2021 01:29.53.172] [LOG] Starting node helper for: newsfeed
                            0|MagicMir | [26.07.2021 01:29.53.185] [LOG] Connecting socket for: MMM-cryptocurrency
                            0|MagicMir | [26.07.2021 01:29.53.202] [LOG] Cryptocurrency module loaded!
                            0|MagicMir | [26.07.2021 01:29.53.214] [LOG] Connecting socket for: MMM-MyPrayerTimes
                            0|MagicMir | [26.07.2021 01:29.53.223] [LOG] Starting node_helper for: MMM-MyPrayerTimes
                            0|MagicMir | [26.07.2021 01:29.53.236] [LOG] Connecting socket for: MMM-LICE
                            0|MagicMir | [26.07.2021 01:29.53.251] [LOG] Starting node_helper for: MMM-LICE
                            0|MagicMir | [26.07.2021 01:29.53.263] [LOG] Connecting socket for: MMM-PIR
                            0|MagicMir | [26.07.2021 01:29.53.280] [LOG] Starting module helper: MMM-PIR
                            0|MagicMir | [26.07.2021 01:29.53.289] [LOG] Sockets connected & modules started ...
                            0|MagicMir | [26.07.2021 01:29.53.303] [LOG]
                            0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
                            0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                            0|MagicMirror  | [26.07.2021 01:31.55.275] [LOG]
                            0|MagicMirror  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
                            0|MagicMirror  | [26.07.2021 01:31.57.499] [LOG]
                            0|MagicMirror  | Create new newsfetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
                            0|MagicMirror  | [26.07.2021 01:31.58.207] [LOG]
                            0|MagicMirror  | Create new newsfetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
                            0|MagicMirror  | [26.07.2021 01:31.58.335] [LOG]
                            0|MagicMirror  | Create new newsfetcher for url: https://tr.cointelegraph.com/google.xml - Interval: 300000
                            0|MagicMirror  | [26.07.2021 01:32.08.343] [ERROR]
                            0|MagicMirror  | Newsfeed Error. Could not fetch newsfeed:  https://tr.cointelegraph.com/google.xml Error: Feed type not recognized
                            0|MagicMirror  |     at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:99:38)
                            0|MagicMirror  |     at SAXStream.emit (events.js:198:13)
                            0|MagicMirror  |     at SAXStream._parser.parser.emit.args [as emit] (/home/pi/MagicMirror/node_modules/feedme/dist/feedme.js:24:24)
                            0|MagicMirror  |     at SAXParser.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
                            0|MagicMirror  |     at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:624:35)
                            0|MagicMirror  |     at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:629:5)
                            0|MagicMirror  |     at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:825:5)
                            0|MagicMirror  |     at SAXParser.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1391:13)
                            0|MagicMirror  |     at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
                            0|MagicMirror  |     at XMLFeedParser._write (/home/pi/MagicMirror/node_modules/feedme/dist/xmlfeedparser.js:159:21)
                            0|MagicMirror  | [26.07.2021 01:32.08.796] [ERROR]
                            0|MagicMirror  | Whoops! There was an uncaught exception...
                            0|MagicMirror  | [26.07.2021 01:32.08.851] [ERROR]
                            0|MagicMirror  | TypeError: $ is not a function
                            0|MagicMirror  |     at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-LICE/node_helper.js:27:27)
                            0|MagicMirror  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:185:22)
                            0|MagicMirror  |     at Request.emit (events.js:198:13)
                            0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1154:10)
                            0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1076:12)
                            0|MagicMirror  |     at Object.onceWrapper (events.js:286:20)
                            0|MagicMirror  |     at IncomingMessage.emit (events.js:203:15)
                            0|MagicMirror  |     at endReadableNT (_stream_readable.js:1145:12)
                            0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:19)
                            0|MagicMirror  | [26.07.2021 01:32.08.884] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            0|MagicMirror  | [26.07.2021 01:32.08.907] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            0|MagicMirror  | [26.07.2021 01:32.09.574] [LOG]
                            0|MagicMirror  | 200[object Object]
                            0|MagicMirror  | [26.07.2021 01:32.45.860] [ERROR]
                            0|MagicMirror  | [26.07.2021 01:32.45.891] [ERROR] TypeError: $ is not a function
                            0|MagicMirror  | [26.07.2021 01:32.45.904] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                            0|MagicMirror  | [26.07.2021 01:32.45.926] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                            But the good side is now i can see screen. Waiting for loading other modules. Maybe it will working.
                              sdetweil @uok825
                              Cannot find module ‘please-upgrade-node’
                              for every cannot find module, repeat
                              npm install missing_name
                              not sure on the rss feed thing… I see the output, but it doesn’t look like a normal xml feed doc
                              • U
                                uok825 @sdetweil
                                @sdetweil I’ll delete cointelegraph. Now i am working on LICE module. I am changed that module code.
                                  sdetweil @uok825
                                  ok, I was looking at the original code and couldn’t find a useful line 27
                                  typically $ is jquery
                                  but the module doesn’t say it needs it…
                                  no package.json for dependencies and the node_helper doesn’t require it
                                  • U
                                    uok825 @sdetweil
                                    /* Magic Mirror
                                     * Module: MMM-LICE
                                     * By Mykle1
                                    const NodeHelper = require('node_helper');
                                    const request = require('request');
                                    const $ = require('cheerio');
                                        start: function() {
                                            console.log("Starting node_helper for: " + this.name);
                                        getLICE: function(url) {
                                        request({
                                            url: 'https://kur.altin.in/banka',
                                            method: 'GET'
                                        }, (error, response, body) => {
                                            if (!error && response.statusCode == 200) {
                                    			var arr = []
                                                var result = ($('.fiyat',body));
                                                result.each((_id,el) =>  (arr.push(el.children[0]['data'])))
                                                var result = ($('h2[id=gfiy]',body));
                                                this.sendSocketNotification('LICE_RESULT', arr);
                                            if (notification === 'GET_LICE') {
                                                this.getLICE(payload);
                                      sdetweil @uok825
                                      @uok825 yep, that’ll do it…
                                      npm install cheerio
                                      my updater would have fixed all this IF there was a package.json file that documented the dependencies
                                      npm install request cheerio --save
                                      • U
                                        uok825 @sdetweil
                                        @sdetweil Thanks man. You are the best. https://github.com/uok825/MagicMirror/tree/master/modules/MMM-LICE
                                          sdetweil @uok825
                                          @uok825 in the module folder do
                                          npm init
                                          answer the questions as best u can, ignore them if u can’t
                                          then
                                          then update your git repo with the new package.json file
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil Now im doing the npm install request cheerio --save . Should I continue or cancel?
                                            • 4 / 5
