    Cannot find module "moment"
    98 Posts 2 Posters 68.6k Views 2 Watching
      sdetweil @uok825
      @uok825
      cd ~
      MagicMirror/installers/upgrade-script.sh apply
      U 1 Reply Last reply
      • U
        uok825 @sdetweil
        @sdetweil 0ac068d6-c12e-4b8a-8052-f77778b56ae2-image.pngAccess denied
        S 2 Replies Last reply
          sdetweil @uok825
          @uok825 ah, didn’t mark executable
          cd ~
          chmod +x MagicMirror/installers/upgrade-script.sh
          • U
            uok825 @sdetweil
            @sdetweil said in Cannot find module "moment":
              sdetweil @uok825
              @uok825 when I do the curl i get
              curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh
              #!/bin/bash
              # only DO npm installs when flag is set to  1
              # test when set to 0
              true=1
              plus all the rest of the script.
              u have a networking problem going on …
              warning, upgrade might fail as IT will try to download new files too
              yes, the upgrade uses curl to get the new package.json file to check the version
              remote_version=$(curl -s https://raw.githubusercontent.com/MichMich/MagicMirror/master/package.json
              and it also fails…
              SO… u need to solve that… are you using pihole somewhere?
              U 2 Replies Last reply
              • U
                uok825 @sdetweil
                @sdetweil AHHHHHHH! Just remembered my other raspberry is stuck on internet too. I change my router so my router adress is changed from 192.168.1.1 to 192.168.1.3 but in my /etc/dhcpcd.conf 37c38ff5-5fcd-4f9b-83c0-5dac86ded6f4-image.png still 192.168.1.1 here sorry for bother you. Trying again.
                • U
                  uok825 @sdetweil
                  Seems fine. Thanks now i rebooting machine and watch if there is a error.
                  pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetwe        il/MagicMirror_scripts/master/upgrade-script.sh)" apply
                  No LSB modules are available.
                  doing test run = false
                  saving custom.css
                  upgrading from version 2.12.0 to 2.16.0
                  fetching latest revisions
                  remote: Enumerating objects: 4413, done.
                  remote: Counting objects: 100% (3550/3550), done.
                  remote: Compressing objects: 100% (1006/1006), done.
                  remote: Total 2836 (delta 1962), reused 2490 (delta 1660), pack-reused 0
                  Receiving objects: 100% (2836/2836), 967.15 KiB | 156.00 KiB/s, done.
                  Resolving deltas: 100% (1962/1962), completed with 207 local objects.
                  From https://github.com/MichMich/MagicMirror
                     10dc315f..26a76f80  master     -> origin/master
                   * [new tag]           v2.16.0    -> v2.16.0
                   * [new tag]           v2.15.0    -> v2.15.0
                  npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@        1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my        best with it!
                  > core-js@3.15.1 postinstall /home/pi/MagicMirror/node_modules/core-js
                  > node -e "try{require('./postinstall')}catch(e){}"
                  Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfill        ing JavaScript standard library!
                  The project needs your help! Please consider supporting of core-js on Open Colle        ctive or Patreon:
                  > https://opencollective.com/core-js
                  > https://www.patreon.com/zloirock
                  Also, the author of core-js ( https://github.com/zloirock ) is looking for a goo        d job -)
                  > electron@11.4.9 postinstall /home/pi/MagicMirror/node_modules/electron
                  > node install.js
                  HTTPError: Response code 404 (Not Found) for https://github.com/electron/electro        n/releases/download/v11.4.9/electron-v11.4.9-linux-armv6l.zip
                      at EventEmitter.emitter.on.response (/home/pi/MagicMirror/node_modules/got/s        ource/as-stream.js:35:24)
                      at EventEmitter.emit (events.js:198:13)
                      at module.exports (/home/pi/MagicMirror/node_modules/got/source/get-response        .js:22:10)
                      at ClientRequest.handleResponse (/home/pi/MagicMirror/node_modules/got/sourc        e/request-as-event-emitter.js:155:5)
                      at Object.onceWrapper (events.js:286:20)
                      at ClientRequest.emit (events.js:203:15)
                      at ClientRequest.origin.emit.args [as emit] (/home/pi/MagicMirror/node_modul        es/@szmarczak/http-timer/source/index.js:37:11)
                      at HTTPParser.parserOnIncomingClient [as onIncoming] (_http_client.js:565:21        )
                      at HTTPParser.parserOnHeadersComplete (_http_common.js:111:17)
                      at TLSSocket.socketOnData (_http_client.js:451:20)
                  > magicmirror@2.16.0 install /home/pi/MagicMirror
                  " && cd vendor && npm install --loglevel=error
                  > @fortawesome/fontawesome-free@5.15.3 postinstall /home/pi/MagicMirror/vendor/n        ode_modules/@fortawesome/fontawesome-free
                  > node attribution.js
                  Font Awesome Free 5.15.3 by @fontawesome - https://fontawesome.com
                  License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL        1.1, Code: MIT License)
                  added 1 package from 1 contributor, removed 74 packages, updated 5 packages and        audited 9 packages in 83.089s
                  found 0 vulnerabilities
                  > magicmirror@2.16.0 postinstall /home/pi/MagicMirror
                  > npm run install-fonts && echo "MagicMirror installation finished successfully!
                  > magicmirror@2.16.0 install-fonts /home/pi/MagicMirror
                  > echo "Installing fonts ...
                  " && cd fonts && npm install --loglevel=error
                  audited 1 package in 7.24s
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 (node_modules/el        ectron):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@11.4.9 postinstall: `no        de install.js`
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  added 67 packages from 88 contributors, removed 489 packages, updated 98 package        s and audited 923 packages in 621.679s
                  34 packages are looking for funding
                    run `npm fund` for details
                  processing for module MMM-MyPrayerTimes please wait
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  added 2 packages from 6 contributors and audited 2 packages in 16.096s
                  processing complete for module MMM-MyPrayerTimes
                  processing for module MMM-LICE please wait
                  added 64 packages from 69 contributors and audited 64 packages in 71.651s
                  13 packages are looking for funding
                  processing complete for module MMM-LICE
                  processing for module MMM-PIR please wait
                  > epoll@2.0.10 install /home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll
                  > node-gyp rebuild
                  make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                    CXX(target) Release/obj.target/epoll/src/epoll.o
                    SOLINK_MODULE(target) Release/obj.target/epoll.node
                    COPY Release/epoll.node
                  make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR/node_modules/epoll/build'
                  added 6 packages from 9 contributors and audited 6 packages in 72.078s
                  processing complete for module MMM-PIR
                  restoring custom.css
                    sdetweil @uok825
                    @uok825 cool… didn’t need to reboot… I would have asked u to check the package.json file start line
                    • U
                      uok825 @sdetweil
                      Now another module give an error
                      0|MagicMir | [26.07.2021 00:57.11.255] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'uuid/v4'
                      0|MagicMir | [26.07.2021 00:57.11.503] [ERROR] Whoops! There was an uncaught exception...
                      0|MagicMir | [26.07.2021 00:57.11.562] [ERROR] { Error: Cannot find module 'uuid/v4'
                      0|MagicMir |     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                      0|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      0|MagicMir |     at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                      0|MagicMir |     at Module.require (internal/modules/cjs/loader.js:692:17)
                      0|MagicMir |     at require (internal/modules/cjs/helpers.js:25:18)
                      0|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/node_modules/request/lib/auth.js:4:12)
                      0|MagicMir |     at Module._compile (internal/modules/cjs/loader.js:778:30)
                      0|MagicMir |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                      0|MagicMir |     at Module.load (internal/modules/cjs/loader.js:653:32)
                      0|MagicMir |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12) code: 'MODULE_NOT_FOUND' }
                      0|MagicMir | [26.07.2021 00:57.11.573] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      0|MagicMir | [26.07.2021 00:57.11.584] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                      0|MagicMir | [26.07.2021 00:57.08.308] [LOG] Module helper loaded: newsfeed
                      0|MagicMir | [26.07.2021 00:57.11.270] [LOG] Loading module helpers ...
                      0|MagicMir | [26.07.2021 00:57.11.284] [LOG] No helper found for module: alert.
                      0|MagicMir | [26.07.2021 00:57.11.294] [LOG] Initializing new module helper ...
                      0|MagicMir | [26.07.2021 00:57.11.307] [LOG] Module helper loaded: updatenotification
                      0|MagicMir | [26.07.2021 00:57.11.316] [LOG] No helper found for module: clock.
                      0|MagicMir | [26.07.2021 00:57.11.330] [LOG] Initializing new module helper ...
                      0|MagicMir | [26.07.2021 00:57.11.340] [LOG] Module helper loaded: calendar
                      0|MagicMir | [26.07.2021 00:57.11.355] [LOG] Initializing new module helper ...
                      0|MagicMir | [26.07.2021 00:57.11.361] [LOG] Module helper loaded: currentweather
                      0|MagicMir | [26.07.2021 00:57.11.372] [LOG] Initializing new module helper ...
                      0|MagicMir | [26.07.2021 00:57.11.382] [LOG] Module helper loaded: weatherforecast
                      0|MagicMir | [26.07.2021 00:57.11.396] [LOG] Initializing new module helper ...
                      0|MagicMir | [26.07.2021 00:57.11.405] [LOG] Module helper loaded: newsfeed
                      0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                      Internet is fine.
                      Package.json
                        sdetweil @uok825
                        @uok825 said in Cannot find module "moment":
                        looks like a library under request
                        npm install uuid
                          request and any lib that used request was removed in 2.16 as there was a security problem never to be fixed… so module was deprecated (set end of life)
                          MagicMirror removed
                            but the internet is working!!
                            • U
                              uok825 @sdetweil
                              @sdetweil Yeah. I also solved the other Raspberry and I know how to solve it here. We would try less if I don’t realize later. I’m sorry to have been ranting. I’m currently installing Uuid if the problem I will write again. Thanks for your labor Sam.
                                sdetweil @uok825
                                @uok825 to shorten the path
                                pm2 stop all
                                then do
                                npm start
                                in the MagicMirror folder
                                alt-spacebar, n to minimize MM
                                then ctrl-c to stop
                                once good, then pm2 status to get the number and
                                pm2 start 0 or whatever number
                                • U
                                  uok825 @sdetweil
                                  @sdetweil I am connected with SSH. I always did pm2 stop 0, pm2 flush, do my work and pm2 start 0. But PI0 is so slow still doing npm :D
                                    sdetweil @uok825
                                    @uok825 but don’t need to do pm2 start until its working correctly
                                    why do you post screen shots if connected via ssh?/ just copy the text…
                                      sdetweil @uok825
                                      @uok825 pm2 calls npm same thing…
                                      • U
                                        uok825 @sdetweil
                                        @sdetweil Screenshot is a habit for me to take. easier than copying
                                          sdetweil @uok825
                                          @uok825 screen shots harder to read here, very tiny… impossible on phone
                                          • U
                                            uok825 @sdetweil
                                            @sdetweil Sorry to hear it. I try not to receive the screenshot sorry.
                                            • 4 / 5
