    Cannot find module "moment"
    98 Posts 2 Posters 68.6k Views 2 Watching
    • U
      uok825 @sdetweil
      @sdetweil Now im doing the npm install request cheerio --save . Should I continue or cancel?
        sdetweil @uok825
        @uok825 continue
        might not create a package.json if not one
        redo after the npm init
        U 1 Reply Last reply
        • U
          uok825 @sdetweil
          Still same
          pi@raspberrypi:~/MagicMirror/modules/MMM-LICE $ pm2 logs
          /home/pi/.pm2/pm2.log last 15 lines:
          PM2        | 2021-07-26T02:05:51: PM2 log: App [MagicMirror:0] starting in -fork mode-
          PM2        | 2021-07-26T02:05:52: PM2 log: App [MagicMirror:0] online
          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
          0|MagicMir | [26.07.2021 02:06.21.033] [WARN]  The module 'currentweather' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
          0|MagicMir | [26.07.2021 02:06.21.065] [WARN]  The module 'weatherforecast' is deprecated in favor of the 'weather'-module, please refer to the documentation for a migration path
          /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
          0|MagicMir | [26.07.2021 02:06.21.048] [LOG] Connecting socket for: weatherforecast
          0|MagicMir | [26.07.2021 02:06.21.074] [LOG] Connecting socket for: newsfeed
          0|MagicMir | [26.07.2021 02:06.21.090] [LOG] Starting node helper for: newsfeed
          0|MagicMir | [26.07.2021 02:06.21.102] [LOG] Connecting socket for: MMM-cryptocurrency
          0|MagicMir | [26.07.2021 02:06.21.112] [LOG] Cryptocurrency module loaded!
          0|MagicMir | [26.07.2021 02:06.21.128] [LOG] Connecting socket for: MMM-MyPrayerTimes
          0|MagicMir | [26.07.2021 02:06.21.144] [LOG] Starting node_helper for: MMM-MyPrayerTimes
          0|MagicMir | [26.07.2021 02:06.21.159] [LOG] Connecting socket for: MMM-LICE
          0|MagicMir | [26.07.2021 02:06.21.174] [LOG] Starting node_helper for: MMM-LICE
          0|MagicMir | [26.07.2021 02:06.21.187] [LOG] Connecting socket for: MMM-PIR
          0|MagicMir | [26.07.2021 02:06.21.202] [LOG] Starting module helper: MMM-PIR
          0|MagicMir | [26.07.2021 02:06.21.211] [LOG] Sockets connected & modules started ...
          0|MagicMir | [26.07.2021 02:06.21.221] [LOG]
          0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
          0|MagicMir | Starting chromium browser now, have patience, it takes a minute
          0|MagicMirror  | [26.07.2021 02:08.03.737] [LOG]
          0|MagicMirror  | Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/10s0ee0h3tb1ko7fqhpf71sfgs%40group.calendar.google.com/private-d3794e10c136ecfea3ad72fe63078acd/basic.ics - Interval: 300000
          0|MagicMirror  | [26.07.2021 02:08.05.785] [LOG]
          0|MagicMirror  | Create new newsfetcher for url: https://www.cnnturk.com/feed/rss/turkiye/news - Interval: 300000
          0|MagicMirror  | [26.07.2021 02:08.07.210] [LOG]
          0|MagicMirror  | Create new newsfetcher for url: https://www.birgun.net/xml/rss.xml - Interval: 300000
          0|MagicMirror  | [26.07.2021 02:08.15.652] [ERROR]
          0|MagicMirror  | Whoops! There was an uncaught exception...
          0|MagicMirror  | [26.07.2021 02:08.15.761] [ERROR]
          0|MagicMirror  | TypeError: $ is not a function
          0|MagicMirror  |     at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-LICE/node_helper.js:27:27)
          0|MagicMirror  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:185:22)
          0|MagicMirror  |     at Request.emit (events.js:198:13)
          0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1154:10)
          0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-LICE/node_modules/request/request.js:1076:12)
          0|MagicMirror  |     at Object.onceWrapper (events.js:286:20)
          0|MagicMirror  |     at IncomingMessage.emit (events.js:203:15)
          0|MagicMirror  |     at endReadableNT (_stream_readable.js:1145:12)
          0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:19)
          0|MagicMirror  | [26.07.2021 02:08.15.803] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
          0|MagicMirror  | [26.07.2021 02:08.15.842] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            sdetweil @uok825
            @uok825 did cheerio get installed?
            cd ~/MagicMirror/modules/MMM-LICE
            ls node_modules/cheerio
            • U
              uok825 @sdetweil
              pi@raspberrypi:~ $ cd ~/MagicMirror/modules/MMM-LICE
              pi@raspberrypi:~/MagicMirror/modules/MMM-LICE $ ls node_modules/cheerio
              LICENSE  lib  package.json  Readme.md
              S 2 Replies Last reply
                sdetweil @uok825
                @uok825 hm… I use it so it should be easy…
                  sdetweil @uok825
                  @uok825 do u need that set of parents in front of $
                  • U
                    uok825 @sdetweil
                    @sdetweil Deleted parents but still same.
                    0|MagicMirror  | [26.07.2021 13:25.47.639] [ERROR]
                    0|MagicMirror  | [26.07.2021 13:25.47.741] [ERROR]
                    0|MagicMirror  |     at Request.request [as _callback] (/home/pi/MagicMirror/mod        ules/MMM-LICE/node_helper.js:27:26)
                    0|MagicMirror  |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-        LICE/node_modules/request/request.js:185:22)
                    0|MagicMirror  |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-LI        CE/node_modules/request/request.js:1154:10)
                    0|MagicMirror  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/module        s/MMM-LICE/node_modules/request/request.js:1076:12)
                    0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:        19)
                    0|MagicMirror  | [26.07.2021 13:25.47.770] [ERROR]
                    0|MagicMirror  | MagicMirror will not quit, but it might be a good idea to check        why this happened. Maybe no internet connection?
                    0|MagicMirror  | [26.07.2021 13:25.47.788] [ERROR] If you think this really is a        n issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror        /issues
                      sdetweil @uok825
                      @uok825 weird. never seen such a thing
                      can u try changing the $ to zz
                      in the require and where used.
                      $ is usually used for jQuery
                      • U
                        uok825 @sdetweil
                        @sdetweil I just rebuild the module without using request.
                          sdetweil @uok825
                          @uok825 ok, but THAT also make no sense…
                          • U
                            uok825 @sdetweil
                            @sdetweil Hi there! Problem solved. New code:
                            /* Magic Mirror
                             * Module: MMM-LICE
                             * By Mykle1
                            const NodeHelper = require('node_helper');
                            const request = require('request');
                            const cheerio = require('cheerio');
                                start: function() {
                                    console.log("Starting node_helper for: " + this.name);
                                getLICE: function(url) {
                                request({
                                    url: 'https://kur.altin.in/banka',
                                    method: 'GET'
                                }, (error, response, body) => {
                                    if (!error && response.statusCode == 200) {
                                        const $ = cheerio.load(body);
                            			var arr = []
                                        var result = $('.fiyat');
                                        result.each((_id,el) =>  (arr.push(el.children[0]['data'])))
                                        var result = $('h2[id=gfiy]');
                                        this.sendSocketNotification('LICE_RESULT', arr);
                                    if (notification === 'GET_LICE') {
                                        this.getLICE(payload);
                            But i have an another problem. Turkish characters in the news seem broken. I think there is a utf-8 error but it doesn’t write anything in the logs.
                            Edit: The news site is broken, it’s not a mistake about us.
                              sdetweil @uok825
                              @uok825 maybe u have to pass a header in the request for utf8 formated response, or encoded…
                              • 5 / 5
