    Update from 2.15 to 2.16
    35 Posts 5 Posters 13.0k Views 5 Watching
      andyyy
      I do have an issue updating to 2.16. As usual I needed to reset the repro (git reset --hard), but few files are there they prevent updating:
      Updating 491f5aa7..26a76f80
      error: The following untracked working tree files would be overwritten by merge:
              .github/codecov.yml
              .husky/.gitignore
              .husky/pre-commit
              css/custom.css.sample
              modules/default/weather/providers/envcanada.js
              tests/configs/data/calendar_test_recurring.ics
              tests/configs/data/weatherforecast_data.json
              tests/configs/modules/alert/default.js
              tests/configs/modules/calendar/recurring.js
              tests/configs/modules/weather/forecastweather_units.js
              tests/e2e/ipWhitelist_spec.js
              tests/e2e/modules/alert_spec.js
              tests/unit/mocks/logger.js
      Please move or remove them before you merge.
      Just removing them wasn’t a good idea. Eventually the update went through but I did end up with black screen even with npm install on all modules.
      Unfortunately your update script didn’t work either.
      Any advice?
      Thanks!
        sdetweil @andyyy
        @andyyy black screen is probably because of the removed request and other libs in 2.16
        look at the messages where start mm
        if npm start, that window
        if pm2, the pm2 logs --lines=100
        u should see a module not found message
          sdetweil @andyyy
          @andyyy my script won’t help if u do it manually.
          but it does give u the chance to save the files so you can continue ( using git stash )
          A 2 Replies Last reply Reply Quote 0
            andyyy @sdetweil
            I did revert to the last working backup and tried your update script. And here it failed updating with same error message in the log file.
            Should I delete all the files in the error file as I did?
            S 3 Replies Last reply Reply Quote 0
              sdetweil @andyyy
              @andyyy I’ll check out my script
              untracked may be the cause.
              wonder how u got the files, but not in git…
              but the black screen isn’t because of those
                sdetweil @andyyy
                @andyyy just do git stash
                or delete them if u don’t know what they are.
                then try again
                  sdetweil @andyyy
                  @andyyy can u send me the ~/MagiMirror/installers/upgrade.log
                  | doah, not install , upgrade log… yeesh
                  my email is the same user ID at gmail
                    I can recreate the problem in my script
                    I bet u tried the develop branch. and switched back to master, and these files aren’t in master on 2.15, but the final versions are different than the develop versions.
                      andyyy @sdetweil
                      Solved for now :)
                      I did:
                      sudo git fetch --all
                      sudo git reset --hard origin/master
                      sudo git pull origin master
                      My system is still very fragile. When do npm install after that, the screen turn black after reboot.
                        sdetweil @andyyy
                        @andyyy said in Update from 2.15 to 2.16:
                        again, this si because libraries in 2.15 were removed in 2.16 and some modules didn’t document their requirements properly…
                        find the MM startup messages (npm start or pm2 logs)
                        and look for ‘module not found’
                        I REALLY hate reset --hard…
                          sdetweil @andyyy
                          @andyyy I uploaded fixes to the upgrade script to handle this…
                          A 2 Replies Last reply Reply Quote 1
                            bdream
                            Hi!
                            I did the upgrade to my system to 2.16
                            Uploading upgrade.log with 600 lines is not possible… because of file format.
                            After reboot I have only the mouse in the middle of the screen but MM is not working.
                            Also I’m not able to get a connection wit ma Web-Browser.
                            Raspberry itself is accessible via SSH.
                            Any idea?
                            cheers, bdream
                            S FoziF 2 Replies Last reply Reply Quote 0
                              sdetweil @bdream
                              @bdream yes look at the mm startup messages
                              we call this the black screen
                                bdream
                                @sdetweil does it mean I have to do in MagicMirror folder?
                                cheers, bdream
                                  sdetweil @bdream
                                  @bdream no. u are probably missing some modules that mm removed
                                  read the startup messages
                                  npm start
                                  or
                                  if using pm2
                                  • FoziF Offline
                                    Fozi Project Sponsor @bdream
                                    @bdream I strongly guess that one of the 3rd party modules is not compatible vith MM2.16.0. I had the same issues with MMM-MyCalendar, which caused a black screen after starting MM. My approach is to disable all 3rd party modules by adding the line
                                    disabled: true;
                                    for each module and enable it one after the other by setting it to
                                    disabled: false;
                                    Taht might discover quicker, which module is the culprit instead of poking in logs (that is my personal approach!).
                                    When you found the module, that causes issues, contact the developer on github, or look for an alternative fork which seems to be maintained.
                                    Regarding the above mentioned MMM-MyCalendar module, I reverted to the default calendar module, which works just fine and delivers the same features.
                                      sdetweil @Fozi
                                      @fozi come on, this is easy. get the messages. it will tell you which lib to install
                                        bdream @sdetweil
                                        @sdetweil okay, I’m going to try with messages.
                                        pi@MagicMirror:~ $ pm2 logs --lines=100
                                        0|mm       | Require stack:
                                        0|mm       | - /home/pi/MagicMirror/modules/MMM-DWD-Pollen/node_helper.js
                                        0|mm       | - /home/pi/MagicMirror/js/app.js
                                        0|mm       | - /home/pi/MagicMirror/js/electron.js
                                        0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                                        0|mm       | -
                                        0|mm       |     at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                                        0|mm       |     at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                                        0|mm       |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                        0|mm       |     at Module._load (internal/modules/cjs/loader.js:848:27)
                                        0|mm       |     at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
                                        0|mm       |     at Module.require (internal/modules/cjs/loader.js:1032:19)
                                        0|mm       |     at require (internal/modules/cjs/helpers.js:72:18)
                                        0|mm       |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-DWD-Pollen/node_helper.js:7:15)
                                        0|mm       |     at Module._compile (internal/modules/cjs/loader.js:1152:30)
                                        0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
                                        0|mm       | [31.07.2021 03:30.08.854] [ERROR] Whoops! There was an uncaught exception...
                                        0|mm       | [31.07.2021 03:30.08.865] [ERROR] Error: Cannot find module 'request'
                                        0|mm       | -
                                        0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10) {
                                        0|mm       |   code: 'MODULE_NOT_FOUND',
                                        0|mm       |   requireStack: [
                                        0|mm       |     '/home/pi/MagicMirror/modules/MMM-DWD-Pollen/node_helper.js',
                                        0|mm       |     '/home/pi/MagicMirror/js/app.js',
                                        0|mm       |     '/home/pi/MagicMirror/js/electron.js',
                                        0|mm       |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                        0|mm       |     undefined
                                        0|mm       |   ]
                                        0|mm       | }
                                        0|mm       | [31.07.2021 03:30.08.868] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        0|mm       | [31.07.2021 03:30.08.869] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                                        0|mm       | [02.08.2021 08:40.08.979] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
                                        0|mm       | -
                                        0|mm       | [02.08.2021 08:40.09.001] [ERROR] App threw an error during load
                                        0|mm       | [02.08.2021 08:40.09.005] [ERROR] Error: Cannot find module 'request'
                                        0|mm       | -
                                        0|mm       | [02.08.2021 08:40.09.007] [ERROR] Whoops! There was an uncaught exception...
                                        0|mm       | [02.08.2021 08:40.09.018] [ERROR] Error: Cannot find module 'request'
                                        0|mm       | -
                                        0|mm       |     undefined
                                        0|mm       |   ]
                                        0|mm       | }
                                        0|mm       | [02.08.2021 08:40.09.021] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        0|mm       | [02.08.2021 08:40.09.022] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        0|mm       |
                                        0|mm       | > magicmirror@2.16.0 start
                                        0|mm       | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                                        0|mm       |
                                        0|mm       | [30.07.2021 03:30.08.295] [LOG]   Starting MagicMirror: v2.16.0
                                        0|mm       | [30.07.2021 03:30.08.304] [LOG]   Loading config ...
                                        So it looks to me as MMM-DWD-Pollen will be the problem.
                                        That is faster, than going with disabled: true; and disabled: false; over all my modules :crossed_fingers: even it was a guess with the related module to me.
                                        @Fozi now i have to see how to deal with your statement “When you found the module, that causes issues, contact the developer on github, or look for an alternative fork which seems to be maintained.”
                                        Comment out this module in config and it works again.
                                        Many thanks for your fast help!!!
                                        cheers, bdream
                                          andyyy @sdetweil
                                          I tried it again. Now the electron does not even start.
                                          sh: 1: ./node_modules/.bin/electron: not found
                                          I tried to re-install electron with "sudo npm install electron@latest
                                          ", but no change.
                                            sdetweil @bdream
                                            @bdream so you need to go to the
                                            MMM-DWD-Pollen folder and do
                                            npm install request --save
