Solved Update from 2.15 to 2.16
@andyyy just do git stash
or delete them if u don’t know what they are.then try again
@andyyy can u send me the ~/MagiMirror/installers/upgrade.log
| doah, not install , upgrade log… yeesh
my email is the same user ID at gmail
I can recreate the problem in my script
I bet u tried the develop branch. and switched back to master, and these files aren’t in master on 2.15, but the final versions are different than the develop versions.
Solved for now :)
I did:
sudo git fetch --all sudo git reset --hard origin/master sudo git pull origin master
My system is still very fragile. When do npm install after that, the screen turn black after reboot.
@andyyy said in Update from 2.15 to 2.16:
again, this si because libraries in 2.15 were removed in 2.16 and some modules didn’t document their requirements properly…
find the MM startup messages (npm start or pm2 logs)
and look for ‘module not found’I REALLY hate reset --hard…
@andyyy I uploaded fixes to the upgrade script to handle this…
Hi!
I did the upgrade to my system to 2.16Uploading upgrade.log with 600 lines is not possible… because of file format.
After reboot I have only the mouse in the middle of the screen but MM is not working.
Also I’m not able to get a connection wit ma Web-Browser.
Raspberry itself is accessible via SSH.
Any idea?
@bdream yes look at the mm startup messages
we call this the black screen -
@sdetweil does it mean I have to do in MagicMirror folder?
@bdream no. u are probably missing some modules that mm removed
read the startup messages
npm start
or
if using pm2
pm2 logs --lines=100
