Unsolved I'd like to add a voice command command using the Google Assistant module.
@sdetweil Just make it in the recipe folder
Can I use voice commands?
I tried using Reboot-Restart-Shutdown but it doesn’t work
Is there anything else I need to add?
For example, config or main. I don’t know how to configure additional settings. -
@rikan did you add the recipes to the config
@rikan said in I'd like to add a voice command command using the Google Assistant module.:
yes, that is what recipe does
maps the voice sound (transcription)
to something to do (commands) -
@djboob66 Thank you for your help
Can I use Google map api to display the map in a smart mirror in this way? -
@sdetweil Can I display it on the screen using led on off and various api in this way?
For example, YouTube, google map, subway -
@rikan you have to have the thing that does that. some module that displays a map, and will respond to a notification. then you can build a recipe that takes a voice command and sends the notification.
@sdetweil With the method of DJBOOB66, the restart was successful.
But I don’t know how to display YouTube or Google Maps.
I want you to tell me how.
Thank you. -
@rikan You Do have MMM-GoogleassistantV3 and youtube in GA config.
If so command is “Jarvis -Youtube Baby shark” -
@djboob66 Thank you for your answer.
I did npm run to kens because YouTube didn’t work.
I received the token and activated the YouTube Data API v3 api.
Then where should I activate the YouTube module? -
In Magic mirror Config.js GAv3 config.
