    I'd like to add a voice command command using the Google Assistant module.
    15 Posts 3 Posters 5.0k Views 3 Watching
      sdetweil @rikan
      @rikan you create a recipe
      there are samples in the recipes folder
      basically
      voice sound
      command to execute
      command defintion
      execute a program
      send a notification
      play a sound
      R 1 Reply Last reply
        rikan @sdetweil
        @sdetweil Just make it in the recipe folder
        Can I use voice commands?
        I tried using Reboot-Restart-Shutdown but it doesn’t work
        Is there anything else I need to add?
        For example, config or main. I don’t know how to configure additional settings.
        D S 2 Replies Last reply
          DJBOOB66 @rikan
            sdetweil @rikan
            @rikan said in I'd like to add a voice command command using the Google Assistant module.:
            yes, that is what recipe does
            maps the voice sound (transcription)
            to something to do (commands)
              rikan @DJBOOB66
              @djboob66 Thank you for your help
              Can I use Google map api to display the map in a smart mirror in this way?
                rikan @sdetweil
                @sdetweil Can I display it on the screen using led on off and various api in this way?
                For example, YouTube, google map, subway
                  sdetweil @rikan
                  @rikan you have to have the thing that does that. some module that displays a map, and will respond to a notification. then you can build a recipe that takes a voice command and sends the notification.
                    rikan @sdetweil
                    @sdetweil With the method of DJBOOB66, the restart was successful.
                    But I don’t know how to display YouTube or Google Maps.
                    I want you to tell me how.
                    Thank you.
                    D 1 Reply Last reply
                      DJBOOB66 @rikan
                      @rikan You Do have MMM-GoogleassistantV3 and youtube in GA config.
                      If so command is “Jarvis -Youtube Baby shark”
                        rikan @DJBOOB66
                        @djboob66 Thank you for your answer.
                        I did npm run to kens because YouTube didn’t work.
                        I received the token and activated the YouTube Data API v3 api.
                        Then where should I activate the YouTube module?
                          DJBOOB66
                          In Magic mirror Config.js GAv3 config.
                            rikan @DJBOOB66
                            @djboob66 Thank you, but there’s a problem.
                            I played it on YouTube, but it’s not showing on the screen.
                            The cmd window says it’s playing, but it doesn’t show on the screen.
                              DJBOOB66 @rikan
                              @rikan there is a bug in the system thinking it Youtube end mine has stopped working as well (today) and I was helping someone on Bugs site with the same problem mine was working for a few days then stopped then out of the blue worked again. Bugs is on Holidays but I will repost that it not working again he may have a look. keep trying it maybe working tomorrow who knows?
                                rikan @DJBOOB66
                                I’ll keep trying.
                                Can I display it on the Magic Mirror screen using Google Maps api?
                                What I want to do is Google Maps, buses and subways. All use api.
