    I'd like to add a voice command command using the Google Assistant module.
    15 Posts 3 Posters 4.2k Views 3 Watching
      rikan
      I’d like to add a voice command to turn on Google Map or Led using the Google Assistant module(bugsounet).
      I don’t know which part of the Google Assistant module to customize.
      Please help me.
        sdetweil @rikan
        @rikan you create a recipe
        there are samples in the recipes folder
        basically
        voice sound
        command to execute
        command defintion
        execute a program
        send a notification
        play a sound
          rikan @sdetweil
          @sdetweil Just make it in the recipe folder
          Can I use voice commands?
          I tried using Reboot-Restart-Shutdown but it doesn’t work
          Is there anything else I need to add?
          For example, config or main. I don’t know how to configure additional settings.
          D S 2 Replies Last reply Reply Quote 0
            DJBOOB66 @rikan
              sdetweil @rikan
              @rikan said in I'd like to add a voice command command using the Google Assistant module.:
              yes, that is what recipe does
              maps the voice sound (transcription)
              to something to do (commands)
                rikan @DJBOOB66
                @djboob66 Thank you for your help
                Can I use Google map api to display the map in a smart mirror in this way?
                  rikan @sdetweil
                  @sdetweil Can I display it on the screen using led on off and various api in this way?
                  For example, YouTube, google map, subway
                    sdetweil @rikan
                    @rikan you have to have the thing that does that. some module that displays a map, and will respond to a notification. then you can build a recipe that takes a voice command and sends the notification.
                      rikan @sdetweil
                      @sdetweil With the method of DJBOOB66, the restart was successful.
                      But I don’t know how to display YouTube or Google Maps.
                      I want you to tell me how.
                      Thank you.
                        DJBOOB66 @rikan
                        @rikan You Do have MMM-GoogleassistantV3 and youtube in GA config.
                        If so command is “Jarvis -Youtube Baby shark”
