Unsolved I'd like to add a voice command command using the Google Assistant module.
@rikan you have to have the thing that does that. some module that displays a map, and will respond to a notification. then you can build a recipe that takes a voice command and sends the notification.
@sdetweil With the method of DJBOOB66, the restart was successful.
But I don’t know how to display YouTube or Google Maps.
I want you to tell me how.
Thank you. -
@rikan You Do have MMM-GoogleassistantV3 and youtube in GA config.
If so command is “Jarvis -Youtube Baby shark” -
@djboob66 Thank you for your answer.
I did npm run to kens because YouTube didn’t work.
I received the token and activated the YouTube Data API v3 api.
Then where should I activate the YouTube module? -
In Magic mirror Config.js GAv3 config.
@djboob66 Thank you, but there’s a problem.
I played it on YouTube, but it’s not showing on the screen.
The cmd window says it’s playing, but it doesn’t show on the screen. -
@rikan there is a bug in the system thinking it Youtube end mine has stopped working as well (today) and I was helping someone on Bugs site with the same problem mine was working for a few days then stopped then out of the blue worked again. Bugs is on Holidays but I will repost that it not working again he may have a look. keep trying it maybe working tomorrow who knows?
I’ll keep trying.
Can I display it on the Magic Mirror screen using Google Maps api?
What I want to do is Google Maps, buses and subways. All use api.
