    Electron error since the last MM update
    9 Posts 2 Posters 2.1k Views 2 Watching
    • thymonT
      thymon
      Since 2.16 update my MM does not work…
      I do not understand this log
      What electron version is needed ?
      1|MagicMirror  | Starting MagicMirror: v2.16.0
      1|MagicMirror  | [13.08.2021 14:07.27.380] [ERROR]
      1|MagicMirror  | TypeError: Cannot read property 'on' of undefined
      1|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:98:5)
      1|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:778:30)
      1|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      1|MagicMirror  |     at Module.load (internal/modules/cjs/loader.js:653:32)
      1|MagicMirror  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      1|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      1|MagicMirror  |     at Object.<anonymous> (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:32:23)
      1|MagicMirror  | [13.08.2021 14:07.27.408] [ERROR]
      1|MagicMirror  | Whoops! There was an uncaught exception...
      1|MagicMirror  | [13.08.2021 14:07.27.410] [ERROR] TypeError: Cannot read property 'on' of undefined
      1|MagicMirror  | [13.08.2021 14:07.27.412] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      1|MagicMirror  | [13.08.2021 14:07.27.413] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issu
      • thymonT
        thymon @sdetweil
        I undestood your language. But I didn’t understand what to do :D
        Now It works !!
        I did not know this command :
        npm install request
        You are my man thanks a lot ! And you script is great
          sdetweil @thymon
          @thymon this looks related to pm2., so I would reinstall it.
          u could try my fixuppm2 script from
          last one in the list.
          thymonT 1 Reply Last reply
          • thymonT
            thymon @sdetweil
            Thx for your interest.
            Where can I put this script ?
            sudo ./update.sh
            It appears MagicMirror has not been installed on this system
            please run the installer, raspberry.sh first
            I tried in :
            ~/MagicMirror
            ~/MagicMirror/installers
              sdetweil @thymon
              @thymon said in Electron error since the last MM update:
              Where can put this script ?
              u just run it from the instructions on the github page
              fixuppm2.sh, cut/paste this line into the terminal window on your device
              copy paste the one line
              • thymonT
                thymon @sdetweil
                I am sorry :) It’s my bad english :downcast_face_with_sweat:
                Thx so much !!
                So now it’s a module issue.
                |MagicMirror  | [13.08.2021 16:36.53.743] [ERROR]
                0|MagicMirror  | App threw an error during load
                0|MagicMirror  | [13.08.2021 16:36.53.748] [ERROR] Error: Cannot find module 'rrule-alt'
                0|MagicMirror  | Require stack:
                0|MagicMirror  | - /home/pi/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/node-ical.js
                0|MagicMirror  | - /home/pi/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/index.js
                0|MagicMirror  | - /home/pi/MagicMirror/modules/MMM-MyCalendar/calendarfetcher.js
                0|MagicMirror  | - /home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js
                0|MagicMirror  | - /home/pi/MagicMirror/js/app.js
                0|MagicMirror  | - /home/pi/MagicMirror/js/electron.js
                0|MagicMirror  | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                0|MagicMirror  | -
                0|MagicMirror  |     at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                0|MagicMirror  |     at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                0|MagicMirror  |     at Module._load (internal/modules/cjs/loader.js:848:27)
                0|MagicMirror  |     at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
                0|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:1032:19)
                0|MagicMirror  |     at require (internal/modules/cjs/helpers.js:72:18)
                0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/node-ical.js:20:13)
                0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:1152:30)
                0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
                0|MagicMirror  |     at Module.load (internal/modules/cjs/loader.js:992:32)
                0|MagicMirror  |     at Module._load (internal/modules/cjs/loader.js:885:14)
                0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyCalendar/vendor/ical.js/index.js:3:12)
                0|MagicMirror  | [13.08.2021 16:36.53.752] [ERROR]
                0|MagicMirror  | Whoops! There was an uncaught exception...
                I tried this without success :
                cd ~/MagicMirror/modules/MMM-MyCalendar
                npm init
                npm install valid-url --save
                I followed your answer from another topic
                  sdetweil @thymon
                  @thymon
                  check the messages again, there are 3 libraries we see this with
                  • thymonT
                    thymon @sdetweil
                    I am confused but I don’t understand…
                      sdetweil @thymon
                      @thymon >| [13.08.2021 16:36.53.748] [ERROR] Error: Cannot find module ‘rrule-alt’
                      did u npm install rrule-alt?
                      did u npm install request
                      check the messages, in the same place u saw valid-url and make sure there are no more errors…
                      (use google translate to get my text in your language)
                      • thymonT
                        thymon @sdetweil
                        Now It works !!
                        npm install request
