    CalendarExt2 won't load with Weather Forecast
    5 Posts 2 Posters 765 Views 2 Watching
      aunrea
      The MMM-CalendarExt2 will no longer load when I add the new default weather app set to type forecast. I can use type current, but when I use the forecast type the calendar will not load.
      This is my weather forecast code:
                  module: "weather",
                  header: "Forecast",
                    type: "forecast",
                    weatherProvider: "weathergov",
                    apiBase: "https://api.weather.gov/points/",
                    weatherEndpoint: "/forecast",
                    lat: "42.834",
                    lon: "-71.6618",
                    initialLoadDelay: 1000,
                    ignoreToday: true,
                    fade: false,
                    tableClass: "medium",
                    degreeLabel: true,
      And here is the non-personal part of the calendar code:
                  module: 'MMM-CalendarExt2',
                          updateInterval: 1000 * 60 * 15,
                          defaultSet: {
                            view: {
                              hideOverflow: false,
                              timeFormat: "h:mm A",
                              maxItems: 2000,
                          views: [
                              mode: "month",
                              fromNow: 0,
                              position: "middle_center",
                              className: "monthly-cal",
                              calendars: []
                          scenes: [
                                  views: ["Current Month"],
      When I comment out the weather module code then the calendar loads fine, but otherwise it doesn’t load at all.
        DJBOOB66 @aunrea
        @aunrea said in CalendarExt2 won't load with Weather Forecast:
        No position: in config CalendarExt2 config maybe?
                 disabled: false,
        	   beforeDays: 2,
                   afterDays: 365,
                   calendars : [
          aunrea @DJBOOB66
          @djboob66 The position info is located in the views section of the config.
            DJBOOB66 @aunrea
            @aunrea
            my config has two one for main and one for upcoming try adding it as above
              aunrea @DJBOOB66
              @djboob66 I did that and it doesn’t change anything.
