    MagicMirror dual monitor configuration
    10 Posts 2 Posters 2.1k Views 2 Watching
      pastormingle @sdetweil
      @sdetweil freaking genius!.. That worked like a charm… I’ve been beating my head against the wall for 2 days now trying to figure this thing out… Wonderful…
        pastormingle @pastormingle
        @pastormingle Need some help now running two config files for my dual monitor configuration. I have MM directory and a MM1 directory. But it looks like both are reading the same config file… if i go to MM1 and do a DISPLAY=:0 npm start it seem to read the same config files as MM directory. What am i doing wrong here?
          sdetweil @pastormingle
          @pastormingle hm… I do this ALL the time
          two copies of MM, two config files
          have to set two different ports too, right?
          one of 8080 and one on 8090 (thats what I do)
            @sdetweil I’ve been using pm2 to start so not sure how I set up separate ports for that?
              @pastormingle port is in the config.js
              also do pm2 status
              and pm2 info xx
              where xx is the number
              to make sure they are starting different scripts…
              how did u setup the second instance?
                @sdetweil I found it and it’s working great thanks for the help… Now just need to get to start with pm2 and should be good to go…
