    Mmm-calendarext
    8 Posts 3 Posters 980 Views 3 Watching
      sdetweil @JPS
      @JPS very complex module, the author has left mm for personal reasons. no one has picked up this or Ext2.
      it takes a lot of config and css to make these look right.
        JPS @sdetweil
        @sdetweil thanks, is their another module that will do what I asked?
          sdetweil @JPS
          @JPS I am not aware of any.
            pastormingle
            I am trying to setup the MMM-CalendarExt module to display my google calendar. I can get it to load but it’s a black screen and when I check the log it is giving me the error;
            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘valid-url’
            Require stack:
            • /home/pi/MagicMirror1/modules/MMM-CalendarExt/node_helper.js
            • /home/pi/MagicMirror1/js/app.jss
            • /home/pi/MagicMirror1/js/electron.js
            • /home/pi/MagicMirror1/node_modules/electron/dist/resources/default_app.asar/main.js
            any help please?
              sdetweil @pastormingle
              @pastormingle valid-url was removed in 2.16,
              and the module didn’t do ument using it.
              so, if the module has a package.json file do, in the module folder
              npm install valid-url
              if no package.json, then
              in the module folder do
              npm init -y
              there are 3 libs we know of
              valid-url
              request
              rrule-alt
