    Music Player Module
    musichelpnode.jsbuttonplayer
    3 Posts 3 Posters 2.3k Views 3 Watching
      Maukoell
      I am trying to create a module which plays music from a directory. I wanted to use two buttons to control it. One for Pause/Play and one to skip the current song. But unfortunately when I start the MM2 I always get the message that it is not able to find the helper for my module. I’m new to node.js so maybe there are just some basic mistakes.
      My module:
      Module.register("MMM-MusicPlayer",{
      	defaults: {
      		playButtonPIN: 10,
              	nextButtonPIN: 12,
              	clickDelay: 500,
              	musicPath = "/home/pi/MagicMirror/modules/MMM-MusicPlayer/music",
      	start: function() {
      		this.sendSocketNotification("BUTTON_CONFIG", this.config);
      		Log.info('Starting module: ' + this.name);
      My node_helper:
      "use strict";
      const NodeHelper = require("node_helper");
      const gpio = require("onoff");
      var path = require('path');
      var fs = require('fs');
      const { Howl, Howler } = require('howler');
      var sound;
      var musicList = [];
      var index = 0;
      var started;
      var config;
          start: function () {
              started = false;
          // Subclass socketNotificationReceived received.
          socketNotificationReceived: function (notification, payload) {
              const self = this;
              if (notification === 'BUTTON_CONFIG' && started === false) {
                  config = payload;
                  self.fromDir(config.musicPath, "mp3");
                  self.createSound();
                  var GPIO = require('onoff').Gpio;
                  var button1 = new GPIO(config.playButtonPIN, 'in', 'both', { persistentWatch: true, debounceTimeout: config.clickDelay });
                  button1.watch(function (err, state) {
                      // 1 == pressed, 0 == not pressed
                      if (state === 1) {
                          if (sound.playing()) {
                              sound.pause();
                          } else {
                              sound.play();
                  var button2 = new GPIO(config.playButtonPIN, 'in', 'both', { persistentWatch: true, debounceTimeout: config.clickDelay });
                  button2.watch(function (err, state) {
                      if (state === 1) {
                          self.playNext();
                      started = true;
          fromDir: function(startPath, filter) {
              if (!fs.existsSync(startPath)) {
                  Log.info("no dir ", startPath);
                  return;
              var files = fs.readdirSync(startPath);
              var i;
              var fullPath;
              var filename;
              var stat;
              for (i = 0; i < files.length; i+=1) {
                  fullPath = path.join(startPath, files[i]);
                  filename = files[i];
                  stat = fs.lstatSync(fullPath);
                  if (stat.isFile()) {
                      if (filename.indexOf(filter) >= 0) {
                          musicList.push(fullPath);
          playNext: function() {
                  sound.stop();
              index += 1;
              if (index === musicList.length()) {
                  index = 0;
              sound.play(index);
          createSound: function() {
              sound = new Howl({
                  src: musicList
      Maybe someone can help me.
      Thanks in advance
      N K 2 Replies Last reply Reply Quote 0
      • N Offline
        nourimane @Maukoell
        @maukoell said in Music Player Module:
        My module:
        	defaults: {
        		playButtonPIN: 10,
                	nextButtonPIN: 12,
                	clickDelay: 500,
        	start: function() {
        My node_helper:
        "use strict";
        var sound;
        var musicList = [];
        var index = 0;
        var started;
        var config;
                started = false;
                const self = this;
                    config = payload;
                    self.createSound();
                        if (state === 1) {
                                sound.pause();
                            } else {
                                sound.play();
                        if (state === 1) {
                            self.playNext();
                        started = true;
                    return;
                var i;
                var fullPath;
                var filename;
                var stat;
                    sound.stop();
                index += 1;
                    index = 0;
                sound.play(index);
                sound = new Howl({
                    src: musicList
        Thanks in advance
        I don’t think that your code respects helpers as described in official documentarion,
        Or we are not talking about the same helpers Pnr Status.TextNow
        • K Offline
          kabir07 @Maukoell
