    Alexa Lists on Magic Mirror
    12 Posts 2 Posters 2.1k Views 2 Watching
    • N Offline
      ndaphne
      Hello Everyone,
      I’m new here and very much so enjoying magic Mirror.
      I have been adding a module or two with success. I would like to add a way to install a module that will allow an Alexa list to display on Magic Mirror. I have looked at Todoist and Wunderlist but best I can tell neither are rally supported. I did get Todoist install and all set on their website, however when I load magic Mirror all i get is a black screen. I did run the check:config tool and the config file checkes good, no errors.
      Hope someone can help with some advice.
      Thank you in advance
      Nick
        sdetweil @ndaphne
        @ndaphne check the messages at mm startup.
        either nm start or if using pm2, then pm2 logs --lines=100
        more than likely a missing library
        I installed the mmm-todoist module last week as a test, an it worked fine.
        you did the npm install in the module folder as the doc says, right?
        • N Offline
          ndaphne
          Hello Sam,
          Thank you for the response.
          It is installed in the MagicMirror/Modules folder.
          here are the messages after start is executed.
          Its interesting how todoist is not in any of the messages.
          pi@raspberrypi:~/MagicMirror $ npm run start
          > magicmirror@2.16.0 start /home/pi/MagicMirror
          [09.09.2021 22:29.21.454] [LOG]   Starting MagicMirror: v2.16.0
          [09.09.2021 22:29.21.459] [LOG]   Loading config ...
          [09.09.2021 22:29.21.467] [LOG]   Loading module helpers ...
          [09.09.2021 22:29.21.470] [LOG]   No helper found for module: alert.
          [09.09.2021 22:29.21.632] [LOG]   Initializing new module helper ...
          [09.09.2021 22:29.21.633] [LOG]   Module helper loaded: updatenotification
          [09.09.2021 22:29.21.635] [LOG]   No helper found for module: clock.
          [09.09.2021 22:29.21.777] [LOG]   Initializing new module helper ...
          [09.09.2021 22:29.21.778] [LOG]   Module helper loaded: calendar
          [09.09.2021 22:29.22.119] [LOG]   Initializing new module helper ...
          [09.09.2021 22:29.22.121] [LOG]   Module helper loaded: MMM-AirNow
          [09.09.2021 22:29.22.122] [LOG]   No helper found for module: weather.
          [09.09.2021 22:29.22.151] [LOG]   Initializing new module helper ...
          [09.09.2021 22:29.22.152] [LOG]   Module helper loaded: newsfeed
          [09.09.2021 22:29.22.153] [LOG]   All module helpers loaded.
          [09.09.2021 22:29.22.240] [LOG]   Starting server on port 8080 ...
          [09.09.2021 22:29.22.255] [LOG]   Server started ...
          [09.09.2021 22:29.22.257] [LOG]   Connecting socket for: updatenotification
          [09.09.2021 22:29.22.258] [LOG]   Connecting socket for: calendar
          [09.09.2021 22:29.22.260] [LOG]   Starting node helper for: calendar
          [09.09.2021 22:29.22.261] [LOG]   Connecting socket for: MMM-AirNow
          [09.09.2021 22:29.22.262] [LOG]   MMM-AirNow helper, started...
          [09.09.2021 22:29.22.264] [LOG]   Connecting socket for: newsfeed
          [09.09.2021 22:29.22.265] [LOG]   Starting node helper for: newsfeed
          [09.09.2021 22:29.22.266] [LOG]   Sockets connected & modules started ...
          [09.09.2021 22:29.22.534] [LOG]   Launching application.
          S N 2 Replies Last reply Reply Quote 0
            sdetweil @ndaphne
            @ndaphne can u show us the section of config.js for todoist?
            • N Offline
              ndaphne @ndaphne
              @ndaphne
              Absolutely!
              		module: 'MMM-Todoist',
              		position: 'top_center',	// This can be any of the regions. Best results in left or right regions.
              		header: 'Todoist', // This is optional
              		config: { // See 'Configuration options' for more information.
              			hideWhenEmpty: false,
              			accessToken: 'xxxxxxxx',
              			maximumEntries: 10,
              			updateInterval: 10*1000, // Update every 10 minutes
              			fade: false,
              			//projects and/or labels is mandatory:
              			projects: [ 166564794 ],
              			labels: [ "shopping" ] // Tasks for any projects with these labels will be shown.
                sdetweil @ndaphne
                @ndaphne I added the code wrapper around config
                next time after pasting the text, select it all, then push the button above the editor that looks like </>
                now,
                what are the [ and ] around the module entry
                they should not be there
                  sdetweil @ndaphne
                  @ndaphne a module entry starts with {
                  and ends with }
                  they are in a list
                  modules:[
                     all in here
                          module 1
                          module 2
                  the author might have shown the list wrapper
                  • N Offline
                    ndaphne
                    Ok, got that fixed and now I’m getting some responses in the startup messages. it appears to be looking for a module “showdown” that I cant seem to find.
                    Thank you for the pointers concerning the brackets. little by little I’ll learn.
                    [10.09.2021 13:19.26.299] [LOG]   Starting MagicMirror: v2.16.0
                    [10.09.2021 13:19.26.304] [LOG]   Loading config ...
                    [10.09.2021 13:19.26.312] [LOG]   Loading module helpers ...
                    [10.09.2021 13:19.26.314] [LOG]   No helper found for module: alert.
                    [10.09.2021 13:19.26.478] [LOG]   Initializing new module helper ...
                    [10.09.2021 13:19.26.479] [LOG]   Module helper loaded: updatenotification
                    [10.09.2021 13:19.26.480] [LOG]   No helper found for module: clock.
                    [10.09.2021 13:19.26.626] [LOG]   Initializing new module helper ...
                    [10.09.2021 13:19.26.627] [LOG]   Module helper loaded: calendar
                    [10.09.2021 13:19.26.949] [ERROR] WARNING! Could not load config file. Starting                            with default configuration. Error found: Error: Cannot find module 'showdown'
                    Require stack:
                    - /home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js
                    - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/mai                           n.js
                    [10.09.2021 13:19.26.950] [LOG]   Loading module helpers ...
                    [10.09.2021 13:19.26.951] [LOG]   No helper found for module: alert.
                    [10.09.2021 13:19.26.952] [LOG]   Initializing new module helper ...
                    [10.09.2021 13:19.26.953] [LOG]   Module helper loaded: updatenotification
                    [10.09.2021 13:19.26.954] [LOG]   No helper found for module: clock.
                    [10.09.2021 13:19.26.955] [LOG]   Initializing new module helper ...
                    [10.09.2021 13:19.26.955] [LOG]   Module helper loaded: calendar
                    [10.09.2021 13:19.26.957] [ERROR] App threw an error during load
                    [10.09.2021 13:19.26.959] [ERROR] Error: Cannot find module 'showdown'
                    Require stack:
                        at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                        at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/modul                           e-alias/index.js:49:29)
                        at Module._load (internal/modules/cjs/loader.js:848:27)
                        at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
                        at Module.require (internal/modules/cjs/loader.js:1032:19)
                        at require (internal/modules/cjs/helpers.js:72:18)
                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.                           js:13:18)
                        at Module._compile (internal/modules/cjs/loader.js:1152:30)
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10)
                    [10.09.2021 13:19.26.961] [ERROR] Whoops! There was an uncaught exception...
                    [10.09.2021 13:19.26.966] [ERROR] Error: Cannot find module 'showdown'
                    Require stack:
                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1173:10) {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: [
                        '/home/pi/MagicMirror/modules/MMM-Todoist/node_helper.js',
                        '/home/pi/MagicMirror/js/app.js',
                        '/home/pi/MagicMirror/js/electron.js',
                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/                           main.js',
                        undefined
                    [10.09.2021 13:19.26.969] [ERROR] MagicMirror will not quit, but it might be a g                           ood idea to check why this happened. Maybe no internet connection?
                    [10.09.2021 13:19.26.970] [ERROR] If you think this really is an issue, please o                           pen an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    [10.09.2021 13:19.27.230] [LOG]   Launching application.
                      sdetweil @ndaphne
                      @ndaphne looks like you didn’t do all the installation instructions as listed by the module readme
                      • N Offline
                        ndaphne @sdetweil
                        @sdetweil Boy I’m not sure what I missed
                        I’m certain I ran the installer and the “run install” command to install dependents.
                        Is there something I’m just not seeing?
                        thank you for tolerating my shortcomings here. It’s deeply appreciated.
