Unsolved Change Pages with NumPad
Apparently the keypass does not arrive at the mirrorHowever, I have to say that the shortcuts of magicmirror work.
I.mean F11 and Alt and a Key -
@drkineticpie is there a key definition in the test steps defined in the module instructions?
do u need to use a special device name to read it?
also found by using the instructions -
Please forgive me my English is really not particularly good :D
If I do the steps 1&2 from the tutorial is called my keyboard mini Keyboard
@drkineticpie but you should be able to get the key names
@sdetweil said in Change Pages with NumPad:
pi@Dashboard:~ $ evtest /dev/input/event0 Input driver version is 1.0.1 Input device ID: bus 0x3 vendor 0x1997 product 0x2433 version 0x111 Input device name: " mini keyboard" Supported events: Event type 0 (EV_SYN) Event type 1 (EV_KEY) Event code 1 (KEY_ESC) Event code 2 (KEY_1) Event code 3 (KEY_2) Event code 4 (KEY_3) Event code 5 (KEY_4) Event code 6 (KEY_5) Event code 7 (KEY_6) Event code 8 (KEY_7) Event code 9 (KEY_8) Event code 10 (KEY_9) Event code 11 (KEY_0) Event code 12 (KEY_MINUS) Event code 13 (KEY_EQUAL) Event code 14 (KEY_BACKSPACE) Event code 15 (KEY_TAB) Event code 16 (KEY_Q) Event code 17 (KEY_W) Event code 18 (KEY_E) Event code 19 (KEY_R) Event code 20 (KEY_T) Event code 21 (KEY_Y) Event code 22 (KEY_U) Event code 23 (KEY_I) Event code 24 (KEY_O) Event code 25 (KEY_P) Event code 26 (KEY_LEFTBRACE) Event code 27 (KEY_RIGHTBRACE) Event code 28 (KEY_ENTER) Event code 29 (KEY_LEFTCTRL) Event code 30 (KEY_A) Event code 31 (KEY_S) Event code 32 (KEY_D) Event code 33 (KEY_F) Event code 34 (KEY_G) Event code 35 (KEY_H) Event code 36 (KEY_J) Event code 37 (KEY_K) Event code 38 (KEY_L) Event code 39 (KEY_SEMICOLON) Event code 40 (KEY_APOSTROPHE) Event code 41 (KEY_GRAVE) Event code 42 (KEY_LEFTSHIFT) Event code 43 (KEY_BACKSLASH) Event code 44 (KEY_Z) Event code 45 (KEY_X) Event code 46 (KEY_C) Event code 47 (KEY_V) Event code 48 (KEY_B) Event code 49 (KEY_N) Event code 50 (KEY_M) Event code 51 (KEY_COMMA) Event code 52 (KEY_DOT) Event code 53 (KEY_SLASH) Event code 54 (KEY_RIGHTSHIFT) Event code 55 (KEY_KPASTERISK) Event code 56 (KEY_LEFTALT) Event code 57 (KEY_SPACE) Event code 58 (KEY_CAPSLOCK) Event code 59 (KEY_F1) Event code 60 (KEY_F2) Event code 61 (KEY_F3) Event code 62 (KEY_F4) Event code 63 (KEY_F5) Event code 64 (KEY_F6) Event code 65 (KEY_F7) Event code 66 (KEY_F8) Event code 67 (KEY_F9) Event code 68 (KEY_F10) Event code 69 (KEY_NUMLOCK) Event code 70 (KEY_SCROLLLOCK) Event code 71 (KEY_KP7) Event code 72 (KEY_KP8) Event code 73 (KEY_KP9) Event code 74 (KEY_KPMINUS) Event code 75 (KEY_KP4) Event code 76 (KEY_KP5) Event code 77 (KEY_KP6) Event code 78 (KEY_KPPLUS) Event code 79 (KEY_KP1) Event code 80 (KEY_KP2) Event code 81 (KEY_KP3) Event code 82 (KEY_KP0) Event code 83 (KEY_KPDOT) Event code 85 (KEY_ZENKAKUHANKAKU) Event code 86 (KEY_102ND) Event code 87 (KEY_F11) Event code 88 (KEY_F12) Event code 89 (KEY_RO) Event code 90 (KEY_KATAKANA) Event code 91 (KEY_HIRAGANA) Event code 92 (KEY_HENKAN) Event code 93 (KEY_KATAKANAHIRAGANA) Event code 94 (KEY_MUHENKAN) Event code 95 (KEY_KPJPCOMMA) Event code 96 (KEY_KPENTER) Event code 97 (KEY_RIGHTCTRL) Event code 98 (KEY_KPSLASH) Event code 99 (KEY_SYSRQ) Event code 100 (KEY_RIGHTALT) Event code 102 (KEY_HOME) Event code 103 (KEY_UP) Event code 104 (KEY_PAGEUP) Event code 105 (KEY_LEFT) Event code 106 (KEY_RIGHT) Event code 107 (KEY_END) Event code 108 (KEY_DOWN) Event code 109 (KEY_PAGEDOWN) Event code 110 (KEY_INSERT) Event code 111 (KEY_DELETE) Event code 113 (KEY_MUTE) Event code 114 (KEY_VOLUMEDOWN) Event code 115 (KEY_VOLUMEUP) Event code 116 (KEY_POWER) Event code 117 (KEY_KPEQUAL) Event code 119 (KEY_PAUSE) Event code 121 (KEY_KPCOMMA) Event code 122 (KEY_HANGUEL) Event code 123 (KEY_HANJA) Event code 124 (KEY_YEN) Event code 125 (KEY_LEFTMETA) Event code 126 (KEY_RIGHTMETA) Event code 127 (KEY_COMPOSE) Event code 128 (KEY_STOP) Event code 129 (KEY_AGAIN) Event code 130 (KEY_PROPS) Event code 131 (KEY_UNDO) Event code 132 (KEY_FRONT) Event code 133 (KEY_COPY) Event code 134 (KEY_OPEN) Event code 135 (KEY_PASTE) Event code 136 (KEY_FIND) Event code 137 (KEY_CUT) Event code 138 (KEY_HELP) Event code 140 (KEY_CALC) Event code 142 (KEY_SLEEP) Event code 150 (KEY_WWW) Event code 152 (KEY_SCREENLOCK) Event code 158 (KEY_BACK) Event code 159 (KEY_FORWARD) Event code 161 (KEY_EJECTCD) Event code 163 (KEY_NEXTSONG) Event code 164 (KEY_PLAYPAUSE) Event code 165 (KEY_PREVIOUSSONG) Event code 166 (KEY_STOPCD) Event code 173 (KEY_REFRESH) Event code 176 (KEY_EDIT) Event code 177 (KEY_SCROLLUP) Event code 178 (KEY_SCROLLDOWN) Event code 179 (KEY_KPLEFTPAREN) Event code 180 (KEY_KPRIGHTPAREN) Event code 183 (KEY_F13) Event code 184 (KEY_F14) Event code 185 (KEY_F15) Event code 186 (KEY_F16) Event code 187 (KEY_F17) Event code 188 (KEY_F18) Event code 189 (KEY_F19) Event code 190 (KEY_F20) Event code 191 (KEY_F21) Event code 192 (KEY_F22) Event code 193 (KEY_F23) Event code 194 (KEY_F24) Event code 240 (KEY_UNKNOWN)
@drkineticpie so it should be
type 1, code 2, for the numb pad 1 key
@drkineticpie looks like u might need to use the evdev method, and eventPath
this.evdevReader.on("EV_KEY", (data) => { // console.log("key : ", data.code, data.value);
Okay right now I do not understand much but I try :D
Is that the reason why in the logs then no keys are detected ?
And how do I tie this in as you mean?
so it should be
type 1, code 2, for the numb pad 1 keyFor the reason that I can see so a change easier I have decided to switch the monitor by button on or off the whole now looks like this:
module: 'MMM-KeyBindings', config: { evdev: { enabled: false }, enableKeyboard: true, actions: [ { key: '1', state: 'KEY_LONGPRESSED', mode: 'DEFAULT', notification: 'REMOTE_ACTION', payload: { action: "MONITORTOGGLE" }}] } }
@drkineticpie ok. I think u needed
evdev: {enabled:true }
and
keyboardEnabled:falseand probably the dev name and path
