    Change Pages with NumPad
    22 Posts 3 Posters 6.4k Views 2 Watching
      sdetweil @DrKineticPie
      @drkineticpie also u can enable a bit more logging from the module
      edit the node_helper.js
      and uncomment line 69 ( remove the //), and restart mm
      this.evdevReader.on("EV_KEY", (data) => {
                  // console.log("key : ", data.code, data.value);
      and the module will write a message for each key detected
      the messages will be shown in the terminal window where you do npm start
      DrKineticPieD 2 Replies Last reply
      • DrKineticPieD
        DrKineticPie @sdetweil
        Apparently the keypass does not arrive at the mirror
        However, I have to say that the shortcuts of magicmirror work.
        I.mean F11 and Alt and a Key
          @drkineticpie is there a key definition in the test steps defined in the module instructions?
          do u need to use a special device name to read it?
          also found by using the instructions
          • DrKineticPieD
            DrKineticPie
            Please forgive me my English is really not particularly good :D
            If I do the steps 1&2 from the tutorial is called my keyboard mini Keyboard
              @drkineticpie but you should be able to get the key names
              DrKineticPieD 1 Reply Last reply
              • DrKineticPieD
                @sdetweil said in Change Pages with NumPad:
                pi@Dashboard:~ $ evtest /dev/input/event0
                Input driver version is 1.0.1
                Input device ID: bus 0x3 vendor 0x1997 product 0x2433 version 0x111
                Input device name: "  mini keyboard"
                Supported events:
                  Event type 0 (EV_SYN)
                  Event type 1 (EV_KEY)
                    Event code 1 (KEY_ESC)
                    Event code 2 (KEY_1)
                    Event code 3 (KEY_2)
                    Event code 4 (KEY_3)
                    Event code 5 (KEY_4)
                    Event code 6 (KEY_5)
                    Event code 7 (KEY_6)
                    Event code 8 (KEY_7)
                    Event code 9 (KEY_8)
                    Event code 10 (KEY_9)
                    Event code 11 (KEY_0)
                    Event code 12 (KEY_MINUS)
                    Event code 13 (KEY_EQUAL)
                    Event code 14 (KEY_BACKSPACE)
                    Event code 15 (KEY_TAB)
                    Event code 16 (KEY_Q)
                    Event code 17 (KEY_W)
                    Event code 18 (KEY_E)
                    Event code 19 (KEY_R)
                    Event code 20 (KEY_T)
                    Event code 21 (KEY_Y)
                    Event code 22 (KEY_U)
                    Event code 23 (KEY_I)
                    Event code 24 (KEY_O)
                    Event code 25 (KEY_P)
                    Event code 26 (KEY_LEFTBRACE)
                    Event code 27 (KEY_RIGHTBRACE)
                    Event code 28 (KEY_ENTER)
                    Event code 29 (KEY_LEFTCTRL)
                    Event code 30 (KEY_A)
                    Event code 31 (KEY_S)
                    Event code 32 (KEY_D)
                    Event code 33 (KEY_F)
                    Event code 34 (KEY_G)
                    Event code 35 (KEY_H)
                    Event code 36 (KEY_J)
                    Event code 37 (KEY_K)
                    Event code 38 (KEY_L)
                    Event code 39 (KEY_SEMICOLON)
                    Event code 40 (KEY_APOSTROPHE)
                    Event code 41 (KEY_GRAVE)
                    Event code 42 (KEY_LEFTSHIFT)
                    Event code 43 (KEY_BACKSLASH)
                    Event code 44 (KEY_Z)
                    Event code 45 (KEY_X)
                    Event code 46 (KEY_C)
                    Event code 47 (KEY_V)
                    Event code 48 (KEY_B)
                    Event code 49 (KEY_N)
                    Event code 50 (KEY_M)
                    Event code 51 (KEY_COMMA)
                    Event code 52 (KEY_DOT)
                    Event code 53 (KEY_SLASH)
                    Event code 54 (KEY_RIGHTSHIFT)
                    Event code 55 (KEY_KPASTERISK)
                    Event code 56 (KEY_LEFTALT)
                    Event code 57 (KEY_SPACE)
                    Event code 58 (KEY_CAPSLOCK)
                    Event code 59 (KEY_F1)
                    Event code 60 (KEY_F2)
                    Event code 61 (KEY_F3)
                    Event code 62 (KEY_F4)
                    Event code 63 (KEY_F5)
                    Event code 64 (KEY_F6)
                    Event code 65 (KEY_F7)
                    Event code 66 (KEY_F8)
                    Event code 67 (KEY_F9)
                    Event code 68 (KEY_F10)
                    Event code 69 (KEY_NUMLOCK)
                    Event code 70 (KEY_SCROLLLOCK)
                    Event code 71 (KEY_KP7)
                    Event code 72 (KEY_KP8)
                    Event code 73 (KEY_KP9)
                    Event code 74 (KEY_KPMINUS)
                    Event code 75 (KEY_KP4)
                    Event code 76 (KEY_KP5)
                    Event code 77 (KEY_KP6)
                    Event code 78 (KEY_KPPLUS)
                    Event code 79 (KEY_KP1)
                    Event code 80 (KEY_KP2)
                    Event code 81 (KEY_KP3)
                    Event code 82 (KEY_KP0)
                    Event code 83 (KEY_KPDOT)
                    Event code 85 (KEY_ZENKAKUHANKAKU)
                    Event code 86 (KEY_102ND)
                    Event code 87 (KEY_F11)
                    Event code 88 (KEY_F12)
                    Event code 89 (KEY_RO)
                    Event code 90 (KEY_KATAKANA)
                    Event code 91 (KEY_HIRAGANA)
                    Event code 92 (KEY_HENKAN)
                    Event code 93 (KEY_KATAKANAHIRAGANA)
                    Event code 94 (KEY_MUHENKAN)
                    Event code 95 (KEY_KPJPCOMMA)
                    Event code 96 (KEY_KPENTER)
                    Event code 97 (KEY_RIGHTCTRL)
                    Event code 98 (KEY_KPSLASH)
                    Event code 99 (KEY_SYSRQ)
                    Event code 100 (KEY_RIGHTALT)
                    Event code 102 (KEY_HOME)
                    Event code 103 (KEY_UP)
                    Event code 104 (KEY_PAGEUP)
                    Event code 105 (KEY_LEFT)
                    Event code 106 (KEY_RIGHT)
                    Event code 107 (KEY_END)
                    Event code 108 (KEY_DOWN)
                    Event code 109 (KEY_PAGEDOWN)
                    Event code 110 (KEY_INSERT)
                    Event code 111 (KEY_DELETE)
                    Event code 113 (KEY_MUTE)
                    Event code 114 (KEY_VOLUMEDOWN)
                    Event code 115 (KEY_VOLUMEUP)
                    Event code 116 (KEY_POWER)
                    Event code 117 (KEY_KPEQUAL)
                    Event code 119 (KEY_PAUSE)
                    Event code 121 (KEY_KPCOMMA)
                    Event code 122 (KEY_HANGUEL)
                    Event code 123 (KEY_HANJA)
                    Event code 124 (KEY_YEN)
                    Event code 125 (KEY_LEFTMETA)
                    Event code 126 (KEY_RIGHTMETA)
                    Event code 127 (KEY_COMPOSE)
                    Event code 128 (KEY_STOP)
                    Event code 129 (KEY_AGAIN)
                    Event code 130 (KEY_PROPS)
                    Event code 131 (KEY_UNDO)
                    Event code 132 (KEY_FRONT)
                    Event code 133 (KEY_COPY)
                    Event code 134 (KEY_OPEN)
                    Event code 135 (KEY_PASTE)
                    Event code 136 (KEY_FIND)
                    Event code 137 (KEY_CUT)
                    Event code 138 (KEY_HELP)
                    Event code 140 (KEY_CALC)
                    Event code 142 (KEY_SLEEP)
                    Event code 150 (KEY_WWW)
                    Event code 152 (KEY_SCREENLOCK)
                    Event code 158 (KEY_BACK)
                    Event code 159 (KEY_FORWARD)
                    Event code 161 (KEY_EJECTCD)
                    Event code 163 (KEY_NEXTSONG)
                    Event code 164 (KEY_PLAYPAUSE)
                    Event code 165 (KEY_PREVIOUSSONG)
                    Event code 166 (KEY_STOPCD)
                    Event code 173 (KEY_REFRESH)
                    Event code 176 (KEY_EDIT)
                    Event code 177 (KEY_SCROLLUP)
                    Event code 178 (KEY_SCROLLDOWN)
                    Event code 179 (KEY_KPLEFTPAREN)
                    Event code 180 (KEY_KPRIGHTPAREN)
                    Event code 183 (KEY_F13)
                    Event code 184 (KEY_F14)
                    Event code 185 (KEY_F15)
                    Event code 186 (KEY_F16)
                    Event code 187 (KEY_F17)
                    Event code 188 (KEY_F18)
                    Event code 189 (KEY_F19)
                    Event code 190 (KEY_F20)
                    Event code 191 (KEY_F21)
                    Event code 192 (KEY_F22)
                    Event code 193 (KEY_F23)
                    Event code 194 (KEY_F24)
                    Event code 240 (KEY_UNKNOWN)
                S 2 Replies Last reply
                  @drkineticpie so it should be
                  type 1, code 2, for the numb pad 1 key
                    @drkineticpie looks like u might need to use the evdev method, and eventPath
                    • DrKineticPieD
                      Okay right now I do not understand much but I try :D
                      Is that the reason why in the logs then no keys are detected ?
                      And how do I tie this in as you mean?
                      • DrKineticPieD
                        so it should be
                        For the reason that I can see so a change easier I have decided to switch the monitor by button on or off the whole now looks like this:
                              module: 'MMM-KeyBindings',
                                evdev: { enabled: false },
                                enableKeyboard: true,
                        		actions: [
                        				key: '1',
                        				state: 'KEY_LONGPRESSED',
                        				mode: 'DEFAULT',
                        				notification: 'REMOTE_ACTION',
                        				payload: { action: "MONITORTOGGLE" }}]
                          @drkineticpie ok. I think u needed
                          evdev: {enabled:true }
                          and
                          keyboardEnabled:false
                          and probably the dev name and path
                          • DrKineticPieD
                            I would have to deal with even more with that. Let me know in the course of the day if it worked out
                            • DrKineticPieD
                              Hangs now about an hour here already stuck somehow I do not get it set up
                              [11.09.2021 14:48.55.780] [ERROR] Whoops! There was an uncaught exception...
                              [11.09.2021 14:48.55.797] [ERROR] Error: Cannot find module 'evdev'
                              Require stack:
                              - /home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js
                                  at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                                  at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                  at Module._load (internal/modules/cjs/loader.js:848:27)
                                  at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
                                  at Module.require (internal/modules/cjs/loader.js:1032:19)
                                  at require (internal/modules/cjs/helpers.js:72:18)
                                  at Class.startEvdevMonitor (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js:61:17)
                                  at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js:99:22)
                                  at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11) {
                                code: 'MODULE_NOT_FOUND',
                                requireStack: [
                                  '/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js',
                                  '/home/pi/MagicMirror/js/app.js',
                                  '/home/pi/MagicMirror/js/electron.js',
                                  '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                  undefined
                              and :
                              pi@Dashboard:~/MagicMirror/modules/MMM-KeyBindings $ cd ~/MagicMirror/modules/MMM-KeyBindings && npm install  --force
                              npm WARN using --force Recommended protections disabled.
                              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                              npm ERR! code 1
                              npm ERR! git dep preparation failed
                              npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/pi/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                              npm ERR! npm WARN using --force Recommended protections disabled.
                              npm ERR! npm ERR! code ETIMEDOUT
                              npm ERR! npm ERR! syscall connect
                              npm ERR! npm ERR! errno ETIMEDOUT
                              npm ERR! npm ERR! network request to http://10.19.101.12:4873/tar/-/tar-6.1.0.tgz failed, reason: connect ETIMEDOUT 10.19.101.12:4873
                              npm ERR! npm ERR! network This is a problem related to network connectivity.
                              npm ERR! npm ERR! network In most cases you are behind a proxy or have bad network settings.
                              npm ERR! npm ERR! network If you are behind a proxy, please make sure that the
                              npm ERR! npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                              npm ERR!
                              npm ERR! npm ERR! A complete log of this run can be found in:
                              npm ERR! npm ERR!     /home/pi/.npm/_logs/2021-09-11T13_39_06_205Z-debug.log
                              npm ERR!     /home/pi/.npm/_logs/2021-09-11T13_39_11_986Z-debug.log
                                @drkineticpie i see the same. seems module is broken, no updates for 3 years… issues open for the same problems…
                                • DrKineticPieD
                                  @sdetweil I have now also decided to do it differently, unfortunately it does not work :D
                                  I have a python script:
                                  import requests
                                  import keyboard
                                  keyboard.add_hotkey("shift+t", lambda: requests.get('http://127.0.0.1:9000/some/endpoint'))
                                  keyboard.wait()
                                  Then magicmirror is started via nohup…
                                  However, the script does not work
