    Change Pages with NumPad
    22 Posts 3 Posters 6.2k Views 2 Watching
      sdetweil @DrKineticPie
      @drkineticpie is there a key definition in the test steps defined in the module instructions?
      do u need to use a special device name to read it?
      also found by using the instructions
      • DrKineticPieD Offline
        DrKineticPie
        Please forgive me my English is really not particularly good :D
        If I do the steps 1&2 from the tutorial is called my keyboard mini Keyboard
          @drkineticpie but you should be able to get the key names
          DrKineticPieD 1 Reply Last reply Reply Quote 0
            DrKineticPie @sdetweil
            @sdetweil said in Change Pages with NumPad:
            pi@Dashboard:~ $ evtest /dev/input/event0
            Input driver version is 1.0.1
            Input device ID: bus 0x3 vendor 0x1997 product 0x2433 version 0x111
            Input device name: "  mini keyboard"
            Supported events:
              Event type 0 (EV_SYN)
              Event type 1 (EV_KEY)
                Event code 1 (KEY_ESC)
                Event code 2 (KEY_1)
                Event code 3 (KEY_2)
                Event code 4 (KEY_3)
                Event code 5 (KEY_4)
                Event code 6 (KEY_5)
                Event code 7 (KEY_6)
                Event code 8 (KEY_7)
                Event code 9 (KEY_8)
                Event code 10 (KEY_9)
                Event code 11 (KEY_0)
                Event code 12 (KEY_MINUS)
                Event code 13 (KEY_EQUAL)
                Event code 14 (KEY_BACKSPACE)
                Event code 15 (KEY_TAB)
                Event code 16 (KEY_Q)
                Event code 17 (KEY_W)
                Event code 18 (KEY_E)
                Event code 19 (KEY_R)
                Event code 20 (KEY_T)
                Event code 21 (KEY_Y)
                Event code 22 (KEY_U)
                Event code 23 (KEY_I)
                Event code 24 (KEY_O)
                Event code 25 (KEY_P)
                Event code 26 (KEY_LEFTBRACE)
                Event code 27 (KEY_RIGHTBRACE)
                Event code 28 (KEY_ENTER)
                Event code 29 (KEY_LEFTCTRL)
                Event code 30 (KEY_A)
                Event code 31 (KEY_S)
                Event code 32 (KEY_D)
                Event code 33 (KEY_F)
                Event code 34 (KEY_G)
                Event code 35 (KEY_H)
                Event code 36 (KEY_J)
                Event code 37 (KEY_K)
                Event code 38 (KEY_L)
                Event code 39 (KEY_SEMICOLON)
                Event code 40 (KEY_APOSTROPHE)
                Event code 41 (KEY_GRAVE)
                Event code 42 (KEY_LEFTSHIFT)
                Event code 43 (KEY_BACKSLASH)
                Event code 44 (KEY_Z)
                Event code 45 (KEY_X)
                Event code 46 (KEY_C)
                Event code 47 (KEY_V)
                Event code 48 (KEY_B)
                Event code 49 (KEY_N)
                Event code 50 (KEY_M)
                Event code 51 (KEY_COMMA)
                Event code 52 (KEY_DOT)
                Event code 53 (KEY_SLASH)
                Event code 54 (KEY_RIGHTSHIFT)
                Event code 55 (KEY_KPASTERISK)
                Event code 56 (KEY_LEFTALT)
                Event code 57 (KEY_SPACE)
                Event code 58 (KEY_CAPSLOCK)
                Event code 59 (KEY_F1)
                Event code 60 (KEY_F2)
                Event code 61 (KEY_F3)
                Event code 62 (KEY_F4)
                Event code 63 (KEY_F5)
                Event code 64 (KEY_F6)
                Event code 65 (KEY_F7)
                Event code 66 (KEY_F8)
                Event code 67 (KEY_F9)
                Event code 68 (KEY_F10)
                Event code 69 (KEY_NUMLOCK)
                Event code 70 (KEY_SCROLLLOCK)
                Event code 71 (KEY_KP7)
                Event code 72 (KEY_KP8)
                Event code 73 (KEY_KP9)
                Event code 74 (KEY_KPMINUS)
                Event code 75 (KEY_KP4)
                Event code 76 (KEY_KP5)
                Event code 77 (KEY_KP6)
                Event code 78 (KEY_KPPLUS)
                Event code 79 (KEY_KP1)
                Event code 80 (KEY_KP2)
                Event code 81 (KEY_KP3)
                Event code 82 (KEY_KP0)
                Event code 83 (KEY_KPDOT)
                Event code 85 (KEY_ZENKAKUHANKAKU)
                Event code 86 (KEY_102ND)
                Event code 87 (KEY_F11)
                Event code 88 (KEY_F12)
                Event code 89 (KEY_RO)
                Event code 90 (KEY_KATAKANA)
                Event code 91 (KEY_HIRAGANA)
                Event code 92 (KEY_HENKAN)
                Event code 93 (KEY_KATAKANAHIRAGANA)
                Event code 94 (KEY_MUHENKAN)
                Event code 95 (KEY_KPJPCOMMA)
                Event code 96 (KEY_KPENTER)
                Event code 97 (KEY_RIGHTCTRL)
                Event code 98 (KEY_KPSLASH)
                Event code 99 (KEY_SYSRQ)
                Event code 100 (KEY_RIGHTALT)
                Event code 102 (KEY_HOME)
                Event code 103 (KEY_UP)
                Event code 104 (KEY_PAGEUP)
                Event code 105 (KEY_LEFT)
                Event code 106 (KEY_RIGHT)
                Event code 107 (KEY_END)
                Event code 108 (KEY_DOWN)
                Event code 109 (KEY_PAGEDOWN)
                Event code 110 (KEY_INSERT)
                Event code 111 (KEY_DELETE)
                Event code 113 (KEY_MUTE)
                Event code 114 (KEY_VOLUMEDOWN)
                Event code 115 (KEY_VOLUMEUP)
                Event code 116 (KEY_POWER)
                Event code 117 (KEY_KPEQUAL)
                Event code 119 (KEY_PAUSE)
                Event code 121 (KEY_KPCOMMA)
                Event code 122 (KEY_HANGUEL)
                Event code 123 (KEY_HANJA)
                Event code 124 (KEY_YEN)
                Event code 125 (KEY_LEFTMETA)
                Event code 126 (KEY_RIGHTMETA)
                Event code 127 (KEY_COMPOSE)
                Event code 128 (KEY_STOP)
                Event code 129 (KEY_AGAIN)
                Event code 130 (KEY_PROPS)
                Event code 131 (KEY_UNDO)
                Event code 132 (KEY_FRONT)
                Event code 133 (KEY_COPY)
                Event code 134 (KEY_OPEN)
                Event code 135 (KEY_PASTE)
                Event code 136 (KEY_FIND)
                Event code 137 (KEY_CUT)
                Event code 138 (KEY_HELP)
                Event code 140 (KEY_CALC)
                Event code 142 (KEY_SLEEP)
                Event code 150 (KEY_WWW)
                Event code 152 (KEY_SCREENLOCK)
                Event code 158 (KEY_BACK)
                Event code 159 (KEY_FORWARD)
                Event code 161 (KEY_EJECTCD)
                Event code 163 (KEY_NEXTSONG)
                Event code 164 (KEY_PLAYPAUSE)
                Event code 165 (KEY_PREVIOUSSONG)
                Event code 166 (KEY_STOPCD)
                Event code 173 (KEY_REFRESH)
                Event code 176 (KEY_EDIT)
                Event code 177 (KEY_SCROLLUP)
                Event code 178 (KEY_SCROLLDOWN)
                Event code 179 (KEY_KPLEFTPAREN)
                Event code 180 (KEY_KPRIGHTPAREN)
                Event code 183 (KEY_F13)
                Event code 184 (KEY_F14)
                Event code 185 (KEY_F15)
                Event code 186 (KEY_F16)
                Event code 187 (KEY_F17)
                Event code 188 (KEY_F18)
                Event code 189 (KEY_F19)
                Event code 190 (KEY_F20)
                Event code 191 (KEY_F21)
                Event code 192 (KEY_F22)
                Event code 193 (KEY_F23)
                Event code 194 (KEY_F24)
                Event code 240 (KEY_UNKNOWN)
              @drkineticpie so it should be
              type 1, code 2, for the numb pad 1 key
                @drkineticpie looks like u might need to use the evdev method, and eventPath
                  this.evdevReader.on("EV_KEY", (data) => {
                              // console.log("key : ", data.code, data.value);
                  Okay right now I do not understand much but I try :D
                  Is that the reason why in the logs then no keys are detected ?
                  And how do I tie this in as you mean?
                    so it should be
                    For the reason that I can see so a change easier I have decided to switch the monitor by button on or off the whole now looks like this:
                          module: 'MMM-KeyBindings',
                            evdev: { enabled: false },
                            enableKeyboard: true,
                    		actions: [
                    				key: '1',
                    				state: 'KEY_LONGPRESSED',
                    				mode: 'DEFAULT',
                    				notification: 'REMOTE_ACTION',
                    				payload: { action: "MONITORTOGGLE" }}]
                      @drkineticpie ok. I think u needed
                      evdev: {enabled:true }
                      and
                      keyboardEnabled:false
                      and probably the dev name and path
                      DrKineticPieD 2 Replies Last reply Reply Quote 0
                        I would have to deal with even more with that. Let me know in the course of the day if it worked out
                          Hangs now about an hour here already stuck somehow I do not get it set up
                          [11.09.2021 14:48.55.780] [ERROR] Whoops! There was an uncaught exception...
                          [11.09.2021 14:48.55.797] [ERROR] Error: Cannot find module 'evdev'
                          Require stack:
                          - /home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js
                              at Module._resolveFilename (internal/modules/cjs/loader.js:972:15)
                              at Function.n._resolveFilename (electron/js2c/browser_init.js:249:921)
                              at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                              at Module._load (internal/modules/cjs/loader.js:848:27)
                              at Function.f._load (electron/js2c/asar_bundle.js:5:12633)
                              at Module.require (internal/modules/cjs/loader.js:1032:19)
                              at require (internal/modules/cjs/helpers.js:72:18)
                              at Class.startEvdevMonitor (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js:61:17)
                              at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js:99:22)
                              at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11) {
                            code: 'MODULE_NOT_FOUND',
                            requireStack: [
                              '/home/pi/MagicMirror/modules/MMM-KeyBindings/node_helper.js',
                              '/home/pi/MagicMirror/js/app.js',
                              '/home/pi/MagicMirror/js/electron.js',
                              '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                              undefined
                          and :
                          pi@Dashboard:~/MagicMirror/modules/MMM-KeyBindings $ cd ~/MagicMirror/modules/MMM-KeyBindings && npm install  --force
                          npm WARN using --force Recommended protections disabled.
                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                          npm ERR! code 1
                          npm ERR! git dep preparation failed
                          npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/pi/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
                          npm ERR! npm WARN using --force Recommended protections disabled.
                          npm ERR! npm ERR! code ETIMEDOUT
                          npm ERR! npm ERR! syscall connect
                          npm ERR! npm ERR! errno ETIMEDOUT
                          npm ERR! npm ERR! network request to http://10.19.101.12:4873/tar/-/tar-6.1.0.tgz failed, reason: connect ETIMEDOUT 10.19.101.12:4873
                          npm ERR! npm ERR! network This is a problem related to network connectivity.
                          npm ERR! npm ERR! network In most cases you are behind a proxy or have bad network settings.
                          npm ERR! npm ERR! network If you are behind a proxy, please make sure that the
                          npm ERR! npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                          npm ERR!
                          npm ERR! npm ERR! A complete log of this run can be found in:
                          npm ERR! npm ERR!     /home/pi/.npm/_logs/2021-09-11T13_39_06_205Z-debug.log
                          npm ERR!     /home/pi/.npm/_logs/2021-09-11T13_39_11_986Z-debug.log
                            @drkineticpie i see the same. seems module is broken, no updates for 3 years… issues open for the same problems…
                              @sdetweil I have now also decided to do it differently, unfortunately it does not work :D
                              I have a python script:
                              import requests
                              import keyboard
                              keyboard.add_hotkey("shift+t", lambda: requests.get('http://127.0.0.1:9000/some/endpoint'))
                              keyboard.wait()
                              Then magicmirror is started via nohup…
                              However, the script does not work
