    Google Task module
    9 Posts 3 Posters 3.4k Views 3 Watching
      pastormingle
      Re: Google tasks?I am using the google task api with “MMM-GoogleTasks” module. I am tryin to change the line height on the task header but I’ve not been able to move it. I’ve tried using ;
      .MMM-GoogleTasks {
         font-size: 20px;
         line-height: 3.0px;
      Which will change the font size but not able to move the header.!b9af1e85-e41b-4967-9d19-81d8136474ca-image.png
        sdetweil @pastormingle
        @pastormingle read this
        https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1631402927193
        hint
        the module header is NOT in the module content
          pastormingle
          that worked perfectly and i was able to set the header etc all looks great now… But this morning when I started my Google task nothing is showing now… Do you have any tips on trouble shooting modules that use an API ?
            @pastormingle every module uses an API…
            look in the dev window console tab
            see if there is a debug config option
            look for messages where u start mm
            if pm2, then use pm2 logs --lines=100
              pastormingle
              I looked through the log and don’t see anything that would be an issue…
              “loader.js:184 Load script: modules/MMM-GoogleTasks/MMM-GoogleTasks.js
              :8080/modules/MMM-GoogleTasks/MMM-GoogleTasks.js:7 Uncaught SyntaxError: Unexpected identifier
              loader.js:184 Load script: modules/default/updatenotification/updatenotification.js”
                @pastormingle said in Google Task module:
                looks like u might have edited the source, instead of using config.js settings
                NEVER edit the source files, unless u know what you are doing and intend to add function…
                to restore the source file
                cd ~/MagicMirror/modules/MMM-GoogleTasks
                git checkout MMM-GoogleTasks.js
                  pastormingle @sdetweil
                  @sdetweil that was it thanks so much…
                  • bigschucksB
                    bigschucks
                    Decided to update this thread with my comment. Recently started programming and also get all sorts of errors. I already understood that if I can’t edit the style, but need to look at the html … really often this is a mistake
                      @bigschucks what does this contribute to the topic?
