    Calendar Event Display start and end date
    7 Posts 2 Posters 1.5k Views 2 Watching
      pastormingle
      Re: How to display start and end times/dates of events in calendarI’ve not been able to set all-day events to display start and end dates. Any guidance here?
        sdetweil @pastormingle
        @pastormingle eh,???
          @pastormingle there is a bug
          edit
          modules/default/calendar/calendar.js
          						timeWrapper.innerHTML += this.capFirst(moment(event.endDate, "x").format(this.config.dateEndFormat));
          					} else    // <---- add this else, line 338
          					// For full day events we use the fullDayEventDateFormat
          					if (event.fullDayEvent) {
          config options
          showEnd: true
          timeFormat: “absolute”
            pastormingle @sdetweil
            @sdetweil Don’t think i am doing this right as it’s not loading the calendar.js file now… Do I just copy this to the bottom of the file the same it?
              @pastormingle now. you add the word ‘else’
              to the line I documented.
              what do u mean not loading?
              did u edit that file like the other one I had u correct?
                @sdetweil if (this.config.timeFormat === “absolute”) {
                // Use dateFormat
                timeWrapper.innerHTML = this.capFirst(moment(event.startDate, “x”).format(this.config.dateFormat));
                // Add end time if showEnd
                if (this.config.showEnd) {
                timeWrapper.innerHTML += “-”;
                timeWrapper.innerHTML += this.capFirst(moment(event.endDate, “x”).format(this.config.dateEndFormat));
                //subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 one the next day
                event.endDate -= oneSecond;
                timeWrapper.innerHTML = this.capFirst(moment(event.startDate, “x”).format(this.config.fullDayEventDateFormat));
                    @sdetweil Ok i think i got it now…
                    } else
