    smart home using MMM-TuyaSL
    10 Posts 2 Posters 2.8k Views 2 Watching
    • arora1mayankA Offline
      arora1mayank
      MMM-tuyaSL module showing no data
        raf @arora1mayank
        @arora1mayank
        sometimes it’s slow but it works, just be patient
        arora1mayankA 4 Replies Last reply Reply Quote 0
          arora1mayank @raf
          @raf sir it is showing no data
          I want you to check if I did any mistake
          I need to add app email and pass?
          firstly I was doing by tuya app I also tried by smart life app still showing no data
          I live in India country code should be EN?
          Also any settings to be done from site or just shows app data by app account because my product is in developing mode
            arora1mayank @raf
            [16.09.2021 12:53.24.960] [ERROR] (node:5858) electron: The default of contextIsolation is deprecated and will be changing from false to true in a future release of Electron. See electron/electron#23506 for more information
            [16.09.2021 12:53.28.692] [LOG] MMM-TuyaSL node helper received a socket notification: TUYASL_NETWORK_SEARCH - Payload: [object Object]
            [16.09.2021 12:53.28.695] [LOG] Getting device list…
            [16.09.2021 12:53.28.707] [LOG] ERROR: Error: ENOENT: no such file or directory, open ‘/tmp/mmm-tuyasl-token.txt’
            at Object.openSync (fs.js:466:3)
            at Object.func [as openSync] (electron/js2c/asar_bundle.js:5:1812)
            at Object.readFileSync (fs.js:368:35)
            at Object.e.readFileSync (electron/js2c/asar_bundle.js:5:8592)
            at Class.search (/home/pi/MagicMirror/modules/MMM-TuyaSL/node_helper.js:152:21)
            at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-TuyaSL/node_helper.js:246:12)
            at Socket. (/home/pi/MagicMirror/js/node_helper.js:109:11)
            at Socket.emit (events.js:315:20)
            at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
            at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:428:39
            at processTicksAndRejections (internal/process/task_queues.js:79:11)
            [16.09.2
              arora1mayank @raf
              module: ‘MMM-TuyaSL’,
              position: ‘top_right’,
              header: ‘TuyaSL’,
              userName: ‘email@gmail.com’,
              password: ‘pass’,
              countryCode: ‘en’,
              showOnlyOnline: false,
              showOnlyOn: false,
              colour: false,
              updateInterval: 300 * 1000,
              timeout: 10 * 1000,
                arora1mayank @raf
                @raf @raf
                  raf @arora1mayank
                  @arora1mayank
                  which app do you use on your smartphone, you have to use the same app on the smartphone and register with the same email and password
                  arora1mayankA 1 Reply Last reply Reply Quote 0
                    arora1mayank @raf
                    @raf yes I used the smart life app and gave the same email and password
                      raf @arora1mayank
                      @arora1mayank
                      bizType smart_life
                      if you use the smartlife app and not tuya
                        arora1mayank @raf
                        @raf smart_life is default but no data showing in both apps i tried both
