    MagicMirror fails to start
    12 Posts 2 Posters 2.8k Views 2 Watching
      droidus
      I am getting these messages:
      npm ERR!     /home/pi/.npm/_logs/2021-09-18T23_30_42_400Z-debug.log
      Invalid MIT-MAGIC-COOKIE-1 key/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.16.0 start: `./run-start.sh $1`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.16.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2021-09-18T23_30_59_634Z-debug.log
      npm ERR! errno 1
      npm ERR!
        sdetweil @droidus
        @droidus good one, never seen that before.
        tell me more, what pi, how did u install the os, and MagicMirror…
          droidus
          I installed the raspbian OS via copying files to the sd card. Here is the board version: Pi Model 4B V1.1. I installed the program via these instructions: https://docs.magicmirror.builders/getting-started/installation.html#manual-installation.
            sdetweil @droidus
            @droidus and the os is the full version w desktop, right?
            rename the MagicMirror folder to some other name, and use my install script
            see https://github.com/sdetweil/MagicMirror_scripts
              droidus @sdetweil
              @sdetweil OK, I installed it. What web port does it use?
                sdetweil @droidus
                @droidus what port does what use? mm is on port 8080, but you shouldn’t need that
                  droidus @sdetweil
                  Still getting an error message:
                  npm run start
                  > magicmirror@2.16.0 start /home/pi/MagicMirror
                  > ./run-start.sh $1
                  [19.09.2021 13:23.34.576] [LOG]   Starting MagicMirror: v2.16.0
                  [19.09.2021 13:23.34.584] [LOG]   Loading config ...
                  [19.09.2021 13:23.34.595] [LOG]   Loading module helpers ...
                  [19.09.2021 13:23.34.602] [LOG]   No helper found for module: alert.
                  [19.09.2021 13:23.34.803] [LOG]   Initializing new module helper ...
                  [19.09.2021 13:23.34.805] [LOG]   Module helper loaded: updatenotification
                  [19.09.2021 13:23.34.807] [LOG]   No helper found for module: clock.
                  [19.09.2021 13:23.34.981] [LOG]   Initializing new module helper ...
                  [19.09.2021 13:23.34.983] [LOG]   Module helper loaded: calendar
                  [19.09.2021 13:23.34.985] [LOG]   No helper found for module: compliments.
                  [19.09.2021 13:23.34.988] [LOG]   No helper found for module: weather.
                  [19.09.2021 13:23.35.025] [LOG]   Initializing new module helper ...
                  [19.09.2021 13:23.35.027] [LOG]   Module helper loaded: newsfeed
                  [19.09.2021 13:23.35.029] [LOG]   All module helpers loaded.
                  [19.09.2021 13:23.35.143] [LOG]   Starting server on port 8080 ...
                  [19.09.2021 13:23.35.164] [LOG]   Server started ...
                  [19.09.2021 13:23.35.166] [LOG]   Connecting socket for: updatenotification
                  [19.09.2021 13:23.35.168] [LOG]   Connecting socket for: calendar
                  [19.09.2021 13:23.35.170] [LOG]   Starting node helper for: calendar
                  [19.09.2021 13:23.35.172] [LOG]   Connecting socket for: newsfeed
                  [19.09.2021 13:23.35.174] [LOG]   Starting node helper for: newsfeed
                  [19.09.2021 13:23.35.179] [LOG]   Sockets connected & modules started ...
                  npm ERR! errno 1
                  npm ERR!
                  npm ERR!     /home/pi/.npm/_logs/2021-09-19T17_23_35_342Z-debug.log
                    sdetweil @droidus
                    @droidus what display are u using on the pi?
                    must have something, running in graphics mode, not text mode.
                    do u see the temples when u boot the pi?
                    do
                    echo $DISPLAY
                    DISPLAY=
                    then
                    npm start
                      droidus
                      I am using the default one that comes with raspbian os.
                      :0.0
                      I get this error message: no such file or directory, open ‘/home//package.json’.
                        sdetweil @droidus
                        @droidus have to be IN the MagicMirror folder for npm start
                          droidus @sdetweil
                          @sdetweil said in MagicMirror fails to start:
                          I get the same error as before about a magic-cookie.
                            sdetweil @droidus
                            @droidus no idea, did u install as pi and now running as another user?
                            did u install as root (using sudo), now running as pi?
                            see https://askubuntu.com/questions/1238389/invalid-mit-magic-cookie-1-key-message-while-running-a-program-with-the-termin
                            if you used my script (just copy/paste the one line from my github page) , logged on as pi, it should have done everything for you
                            what I do
                            use the OS imager tool, install the latest OS image (full desktop, code name buster) on the sd card
                            boot the sd card,
                            turn on ssh
                            reboot the sd card
                            logon via ssh from windows (or linux) machine
                            copy/paste my install script line into the ssh terminal window
                            wait…
