    help with MMM-Mirror on the wall
    4 Posts 2 Posters 634 Views 2 Watching
      Rmetellus79
      alright so Im still kinda fresh with everything raspberry and coding. I have everything setup with the mirror on the wall alexa module, i can run the “mirror mirror on the wall” commands from my alexa yet nothing shows on my mirror. any help would be appreciated thank you.
      [22.09.2021 18:40.53.598] [LOG]   Starting MagicMirror: v2.16.0
      [22.09.2021 18:40.53.603] [LOG]   Loading config ...
      [22.09.2021 18:40.53.609] [LOG]   Loading module helpers ...
      [22.09.2021 18:40.53.611] [LOG]   No helper found for module: alert.
      [22.09.2021 18:40.53.778] [LOG]   Initializing new module helper ...
      [22.09.2021 18:40.53.779] [LOG]   Module helper loaded: updatenotification
      [22.09.2021 18:40.53.780] [LOG]   No helper found for module: clock.
      [22.09.2021 18:40.53.921] [LOG]   Initializing new module helper ...
      [22.09.2021 18:40.53.922] [LOG]   Module helper loaded: calendar
      [22.09.2021 18:40.53.923] [LOG]   No helper found for module: compliments.
      [22.09.2021 18:40.53.924] [LOG]   No helper found for module: weather.
      [22.09.2021 18:40.53.948] [LOG]   Initializing new module helper ...
      [22.09.2021 18:40.53.948] [LOG]   Module helper loaded: newsfeed
      [22.09.2021 18:40.54.367] [LOG]   Initializing new module helper ...
      [22.09.2021 18:40.54.367] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify
      [22.09.2021 18:40.54.518] [LOG]   Initializing new module helper ...
      [22.09.2021 18:40.54.519] [LOG]   Module helper loaded: MMM-MirrorMirrorOnTheWall
      [22.09.2021 18:40.54.520] [LOG]   No helper found for module: MMM-nyc-transit.
      [22.09.2021 18:40.54.520] [LOG]   All module helpers loaded.
      [22.09.2021 18:40.54.637] [LOG]   Starting server on port 8080 ...
      [22.09.2021 18:40.54.652] [LOG]   Server started ...
      [22.09.2021 18:40.54.653] [LOG]   Connecting socket for: updatenotification
      [22.09.2021 18:40.54.655] [LOG]   Connecting socket for: calendar
      [22.09.2021 18:40.54.656] [LOG]   Starting node helper for: calendar
      [22.09.2021 18:40.54.657] [LOG]   Connecting socket for: newsfeed
      [22.09.2021 18:40.54.658] [LOG]   Starting node helper for: newsfeed
      [22.09.2021 18:40.54.658] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify
      [22.09.2021 18:40.54.659] [LOG]   Connecting socket for: MMM-MirrorMirrorOnTheWall
      [22.09.2021 18:40.54.660] [LOG]   Starting module helper: MMM-MirrorMirrorOnTheWall
      [22.09.2021 18:40.54.660] [LOG]   Sockets connected & modules started ...
      [22.09.2021 18:40.54.933] [LOG]   Launching application.
      [22.09.2021 18:40.58.970] [LOG]   Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      [22.09.2021 18:40.59.166] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      [22.09.2021 18:40.59.353] [LOG]   Attempt to connect to AWS
      [22.09.2021 18:40.59.358] [INFO]  Checking git for module: MMM-NowPlayingOnSpotify
      [22.09.2021 18:40.59.362] [ERROR] (node:7970) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [22.09.2021 18:40.59.447] [INFO]  Checking git for module: MMM-MirrorMirrorOnTheWall
      [22.09.2021 18:40.59.824] [INFO]  Calendar-Fetcher: Broadcasting 5 events.
      [22.09.2021 18:40.59.880] [LOG]   Refreshed access token because it has expired. Expired at: 18:40:59 now is: 18:40:59
      [22.09.2021 18:41.00.007] [LOG]   Refreshed access token because it has expired. Expired at: 19:40:59 now is: 18:41:00
      [22.09.2021 18:41.00.416] [INFO]  Newsfeed-Fetcher: Broadcasting 52 items.
      [22.09.2021 18:41.32.456] [LOG]   Shutting down server...
      [22.09.2021 18:41.32.459] [LOG]   Stopping module helper: updatenotification
      [22.09.2021 18:41.32.461] [LOG]   Stopping module helper: calendar
      [22.09.2021 18:41.32.462] [LOG]   Stopping module helper: newsfeed
      [22.09.2021 18:41.32.463] [LOG]   Stopping module helper: MMM-NowPlayingOnSpotify
      [22.09.2021 18:41.32.463] [LOG]   Stopping module helper: MMM-MirrorMirrorOnTheWall
      heres my logs
        sdetweil @Rmetellus79
        @rmetellus79 haven’t seen anyone successful w this module.
        it’s been 3 yrs since last updated.
        R 1 Reply Last reply
          Rmetellus79 @sdetweil
          @sdetweil are there any other alexa interactive modules that you would recommend instead? Thank you
            @rmetellus79 the only one that works that I am aware of is MMM-Awesome-Alexa, but there is not much MagicMirror control. so not very interactive
            it’s install is tricky. I couldn’t get it right after a few tries. too many commands.
            so I copied the commands to a script that seems to work
            https://www.dropbox.com/s/omrx3vztjp738hf/do-install.sh?dl=0
