New MM install- Raspberry pi 4 shuts off on its own
4 Posts 2 Posters 539 Views 2 Watching
  • N Offline
    Nneuland
    I recently had a problem with my pi and decided to start fresh.
    Things are looking well, but my pi is shutting off on it’s own after apx 5 minutes.
    I was remoting via VNC and lost connection and froze the screen.
    Is there a default screensaver that I’m forgetting ?
    Nick
    S N 2 Replies Last reply Sep 23, 2021, 1:58 PM Reply Quote 0
    • S Away
      sdetweil @Nneuland
      @nneuland there is screen blanking… in the pi preferences.
      how did u install MM? if you used mys script it would have asked if u wanted to disable screen saver
      see https://github.com/sdetweil/MagicMirror_scripts
      • N Offline
        Nneuland @Nneuland
        @nneuland
        Thank you Sam. I used MichMich’s install.
        https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
        Thank you for the script.
        S 1 Reply Last reply Sep 23, 2021, 2:37 PM Reply Quote 0
        • S Away
          sdetweil @Nneuland
          @nneuland yeh, mine is listed in the ‘alternative’ section below manual
          note that I have a script to disable screensaver down at the bottom too
