    Calendar - Syntax for additional config options?
    6 Posts 4 Posters 3.4k Views 3 Watching
    • V Offline
      vogelboy
      Hey! I just set up my calendar and am having trouble figuring out the syntax for the additional config options.
      Specifically, I am trying to change the maximum entries that are displayed. I have added it as shown below and the calendar loads just fine, but it still shows the default of 10 entries. Where am I going wrong?
      Thanks!
      module: ‘calendar’,
      header: ‘H&E’,
      position: ‘top_left’,
      symbol: 'calendar-check-o ',
      url: ‘calendar_url’,
      maxiumumEntries: ‘3’
      • yawnsY Offline
        yawns Moderator
        The maximumEntries needs to be in the config section, not the calendars array
        • V Offline
          vogelboy
          Thanks! Otherwise do I have it correct?
          I have tried the following three ways and none of them seem to work- I still end up with 10.
          • maximumEntries: 3
          • maximumEntries: “3”
          • maximumEntries: ‘3’
          module: ‘calendar’,
          header: ‘H&E’,
          url: ‘myurl’
          maxiumumEntries: “3”
          • brobergB Offline
            broberg Project Sponsor @vogelboy
            @vogelboy you have spelled the maximumEntries wrong in the config file.
            ‘3’ is the correct one, but “3” should also work.
            • V Offline
              vogelboy
              omg haha. Thanks!
              • O Offline
                ottopaulsen
