    Client wont keep Modules up-to-date
    21 Posts 3 Posters 8.5k Views 3 Watching
      codac
      I’m running @karsten13 Docker on my Synology NAS, which runs smooth and nicely.
      As I have configured my MagicMirror to work as client/server, the client runs on a Raspberry Pi feeding the Mirror itself.
      I have figured out that the client wont show the most current data of the modules. It is not frozen, the time is running and other modules like “MMM-DWD-WarnWeather” or “MMM-Traffic” are always up-to-date.
      But the default calendar module as well as the “MMM-SoccerLiveScore” module are always outdated.
      How can that be and what can I do to find the root cause?
      karsten13K S 2 Replies Last reply Reply Quote 0
      • karsten13K Offline
        karsten13 @codac
        @codac
        you are talking about this setup?
        I think all modules are running correctly which have no node_helper.js in their directory.
        Are there any warnings/errors in the logs (client and/or server)?
          sdetweil @codac
          @codac can u ssh into the mirror?
          stop the client and open chromium and point it at your mm server.
          this will do the same thing as the client just use a different browser.
          when I do this for pi0 devices I use this command line
          chromium -noerrdialogs -kiosk -start_maximized  --disable-infobars --app=http://localhost:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
          change the localhost and $port to point to your mm server
            codac
            @karsten13
            yes and using pm2 to start this command:
            DISPLAY=:0 node clientonly --address 192.168.0.13 --port 8080
            And yes I have errors, it seems as if there is a problem using the 127.0.0.1 address and port 8080:
            0|mm       | [13.07.2021 13:19.37.499] [ERROR] Error: listen EADDRINUSE: address        already in use 127.0.0.1:8080
            0|mm       |     at Server.setupListenHandle [as _listen2] (net.js:1313:16)
            0|mm       |     at listenInCluster (net.js:1361:12)
            0|mm       |     at GetAddrInfoReqWrap.doListen [as callback] (net.js:1498:7)
            0|mm       |     at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:68:8) {
            0|mm       |   code: 'EADDRINUSE',
            0|mm       |   errno: 'EADDRINUSE',
            0|mm       |   syscall: 'listen',
            0|mm       |   address: '127.0.0.1',
            0|mm       |   port: 8080
            0|mm       | }
            0|mm       | [13.07.2021 13:19.37.506] [ERROR] MagicMirror will not quit, but it        might be a good idea to check why this happened. Maybe no internet connection?
            0|mm       | [13.07.2021 13:19.37.510] [ERROR] If you think this really is an is        sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/iss        ues
            and I wonder why there is an error catching the newsfeed, as the stated feed is the one from the client, not the server:
            0|mm       | /home/pi/MagicMirror/node_modules/electron/dist/electron exited wit        h signal SIGINT
            0|mm       | [13.07.2021 19:59.53.918] [ERROR] Newsfeed Error. Could not fetch n        ewsfeed:  https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml FetchError:        request to https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml failed, rea        son: getaddrinfo EAI_AGAIN rss.nytimes.com
            0|mm       |     at ClientRequest.<anonymous> (/home/pi/MagicMirror/node_modules        /node-fetch/lib/index.js:1461:11)
            0|mm       |     at ClientRequest.emit (events.js:315:20)
            0|mm       |     at TLSSocket.socketErrorListener (_http_client.js:426:9)
            0|mm       |     at TLSSocket.emit (events.js:315:20)
            0|mm       |     at emitErrorNT (internal/streams/destroy.js:92:8)
            0|mm       |     at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
            0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:8        4:21) {
            0|mm       |   type: 'system',
            0|mm       |   errno: 'EAI_AGAIN',
            0|mm       |   code: 'EAI_AGAIN'
            0|mm       | }
            0|mm       | [13.07.2021 19:59.56.921] [ERROR] Calendar Error. Could not fetch c        alendar:  http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics Fetch        Error: request to http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.i        cs failed, reason: getaddrinfo EAI_AGAIN www.calendarlabs.com
            S karsten13K 2 Replies Last reply Reply Quote 0
              sdetweil @codac
              @codac said in Client wont keep Modules up-to-date:
              EAI_AGAIN
              is a name server problem
              the api request could not resolve the name
              see this a lot with local pihole servers doing DNS filtering
                karsten13 @codac
                @codac
                yes, port 8080 on your client is already in use.
                You can try another port in the client config.js but I don’t know if this works.
                then remove this stuff from the client config …
                I’m not familiar with the clientonly setup and I think this is not used very often and therefore maybe contains some bugs.
                  sdetweil @karsten13
                  @karsten13 said in Client wont keep Modules up-to-date:
                  it just launches electron pointing at the server, same as u would do with chromium.
                  doesn’t use the config.js
                    codac
                    I figured out that is was due to several reasons.
                    1. The reported error messages from the client side were old ones from the time when I set up the client and before I switched to clientonly mode. So they are supposed to be ignored.
                    2. The calendar module was able to receive the events from all calendars except for one calendar that runs on my NAS system where I forgot to add the port number to the calendar url.
                    3. the module MMM-Tankerkoenig is not up to date as there is an error message regarding the identifier that was not found. As far as I can see the code has an error and therefore the module wont update correctly.
                    4. the module MMM-Formula1 (wrongly called it MMM-SocerLiveScore) module has a ReloadInterval which was just wrongly set up and far to long.
                    @karsten13
                    In the Docker on the server side is there anything adequate to the command pm2 logs --lines 300 mm ?
                      sdetweil @codac
                      wouldnt you just
                       docker exec container_id pm2 logs.....
                      to execute the command inside the container?
                      to clear the logs
                      docker exec container_id pm2 flush
                        karsten13 @sdetweil
                        there is no pm2 in the container …
                        The command is docker logs <containername or id>, so if you use my docker-compose setup docker logs mm.
                          sdetweil @karsten13
                          @karsten13 so I have to restart the container after making config changes?
                            codac @sdetweil
                            @sdetweil yes, you should do that.
                              codac
                              I have still not fixed this.
                              Servers IP: 192.168.0.23 (local Port 8036, container-port: 8080)
                              On the client I get the following error:
                              Unable to connect to server: (Error: Unable to read config from server (http://192.168.0.23:8036/config/ (connect ECONNREFUSED 192.168.0.23:8036)
                              The servers config is set to:
                                      address: "0.0.0.0",
                              	port: 8080,
                              	basePath: "/",
                              	ipWhitelist: ['0.0.0.0/0', '127.0.0.1', '::ffff:127.0.0.1', '::1', '192.168.0.0/24', '172.17.0.0/24'],
                              Any ideas why the client wont get the servers config?
                                sdetweil @codac
                                @codac first, remove the ipWhitelist , set to []
                                then try
                                .and the IP address used is the docker host IP address, right.
                                never use the containers direct address for any code not running ON the docker host machine
                                where is client running?
                                if mm rejected the connection due to whitelist you should have seen it in the mm messages
                                i see a message like this
                                Access denied to IP address: 192.168.2.106
                                my config
                                	address: "192.168.2.106", 	// Address to listen on, can be:
                                	port: 8090,
                                	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
                                	ipWhitelist: ["127.0.0.1"],
                                  karsten13 @codac
                                  @codac
                                  may you must open the additional port in the docker setup and add the line with 8036 (untested) in your docker-compose.yml:
                                      ports:
                                        - "8080:8080"
                                        - "8036:8036"
                                    sdetweil @karsten13
                                    ports:
                                      - "8080:8080"
                                      - "8036:8036"
                                    why wouldn’t
                                         ports:
                                               "8036:8080"
                                    be enough?
                                      karsten13 @sdetweil
                                      @sdetweil think you are right …
                                        sdetweil @karsten13
                                        @karsten13 actually I think you were closer…
                                        I know a module that uses the port number in a url it presents…
                                        (MMM-Config in the QR code)
                                        8080 won’t work, but if the mapping was added
                                        so
                                             ports:
                                                   "8036:8080"
                                                   "8080:8080"
                                        would be needed
                                        and if u need to do that, then 8080 on the docker host needs to be used, so then no need for 8036
                                             ports:
                                                   "8080:8080"
                                        but can’t run two container instances
                                          @sdetweil also, my MM uses 8090 not to collide with another app.
                                            karsten13 @sdetweil
                                            @codac
                                            if I read this correctly your setup is
                                            ports:
                                              - "8036:8080"
                                            So mm should be reachable under 192.168.0.23:8036.
                                            If not the client ip is may not white listed, I would try ipWhitelist: [], in the server config for testing.
                                            Another question: Is 192.168.0.23:8036 not reachable in general (e.g. in a browser) or only not reachable running the clientonly command?
