    [RPI4][Buster] MM2 do not want to start
    3 Posts 3 Posters 585 Views 3 Watching
    • titithebadT Offline
      titithebad
      Dear all,
      I have this error as I run : npm run start
      magicmirror@2.17.1 start /home/pi/MagicMirror
      electron js/electron.js
      [02.10.2021 21:59.38.107] [LOG] Starting MagicMirror: v2.17.1
      [02.10.2021 21:59.38.115] [LOG] Loading config …
      [02.10.2021 21:59.38.121] [LOG] Loading module helpers …
      [02.10.2021 21:59.38.123] [LOG] No helper found for module: alert.
      [02.10.2021 21:59.38.140] [LOG] Initializing new module helper …
      [02.10.2021 21:59.38.142] [LOG] Module helper loaded: updatenotification
      [02.10.2021 21:59.38.143] [LOG] No helper found for module: clock.
      [02.10.2021 21:59.38.293] [LOG] Initializing new module helper …
      [02.10.2021 21:59.38.294] [LOG] Module helper loaded: calendar
      [02.10.2021 21:59.38.295] [LOG] No helper found for module: compliments.
      [02.10.2021 21:59.38.296] [LOG] No helper found for module: weather.
      [02.10.2021 21:59.38.329] [LOG] Initializing new module helper …
      [02.10.2021 21:59.38.330] [LOG] Module helper loaded: newsfeed
      [02.10.2021 21:59.38.331] [LOG] All module helpers loaded.
      [02.10.2021 21:59.38.421] [LOG] Starting server on port 8080 …
      [02.10.2021 21:59.38.436] [LOG] Server started …
      [02.10.2021 21:59.38.437] [LOG] Connecting socket for: updatenotification
      [02.10.2021 21:59.38.438] [LOG] Connecting socket for: calendar
      [02.10.2021 21:59.38.439] [LOG] Starting node helper for: calendar
      [02.10.2021 21:59.38.440] [LOG] Connecting socket for: newsfeed
      [02.10.2021 21:59.38.440] [LOG] Starting node helper for: newsfeed
      [02.10.2021 21:59.38.441] [LOG] Sockets connected & modules started …
      The futex facility returned an unexpected error code.
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.17.1 start: electron js/electron.js
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.17.1 start script.
      Who know why ?
      Regards
        sdetweil @titithebad
        @titithebad can u show results of
        node -v
        npm -v
        is this a new mm install?
        • karsten13K Offline
          karsten13 @sdetweil
          which raspberry pi os did you install?
          It must be one with desktop
