    Start and Stop the MagicMirror
    Scheduled Pinned Locked Moved Forum
    3 Posts 3 Posters 1.0k Views 3 Watching
      Mike 0
      Hello
      My MagicMirror is running on a touch screen, without a keyboard. Is there any way to start and stop the program without running a command in the terminal? I have unfortunately only found a module that stops the whole Raspy.
      Many greetings, Mike
        sdetweil @Mike 0
        @mike-0 no
        but if u ssh from your PC, then u can use a keyboard
        If u set it up for autostart, then u don’t have to do it every time manually
        pm2 ( node process manager) can be used to run at boot.
        my scripts provide a way to setup for that
        see
        (last entry)
          MMRIZE @Mike 0
          @mike-0
          Have you considered this? https://github.com/gfischershaw/MMM-Touch
          It can define your touch gesture then assign jobs even shell scripts execution.
