    Segment fault MMM-GoogleTTS
    googletts grpc fault
    7 Posts 3 Posters 1.5k Views 3 Watching
      sdetweil @jamesarm
      @jamesarm the comments on gprc suggest to move the code to @gprc/gprc.js
      it has helped other code I have worked on
      this module hasn’t been updated in a while, so you never know how much work is required to make it work again.
        MMRIZE @jamesarm
        @jamesarm
        I was the original author of it. I’ll look inside tomorrow. I ran away from the my exmodules for personal reasons for a while.
          sdetweil @MMRIZE
          @mmrize we are glad that you are back! your ideas and expertise are wonderful!
            MMRIZE @jamesarm
            @jamesarm
            Hmmm. In my test, there be no issue.
            Anyway, try these steps;
            1. Update and Upgrade your MM to the latest version. If you can, Upgrade Electron and Node also.
            2. Remove MMM-GoogleTTS then reinstall (without electron-rebuild)
            3. Get credentials and config you need.
            4. Try execution.
            5. Is there an error? what kind of? show me.
            6. IF you are doubting electron-rebuild issue, try server only mode. (Still do not electron-rebuild yet)
            7. in server only mode and browser trial, it works?
            8. If it works, now do electron-rebuild process. Is there any error in process?
              jamesarm @MMRIZE
              @mmrize Looks like it is fixed now, from what I can tell it appears the repo has been updated to support grpc.js instead of the deprecated module.
                MMRIZE @jamesarm
                @jamesarm
                Glad to hear it works for you now.
