    Compliments with remote file doesnt work.
    13 Posts 4 Posters 4.2k Views 3 Watching
      sdetweil @codac
      @codac ok, the original post had the module source
      anyhow
      open the developers window on mm
      ctrl-shift-i
      select the tab labeled ‘console’ and add a unique part of the module name to the filter field
      compl
      for example
      see if there are any errors…
      if the module is able to get and parse the contents, it changes the defaults to the remote content
        codac
        @sdetweil yes indeed there is:
        Reason: CORS header ‘Access-Control-Allow-Origin’ missing
        S M ? 4 Replies Last reply Reply Quote 0
          sdetweil @codac
          @codac what is the address: in the mm config
          if “localhost” try “0.0.0.0”
            codac @sdetweil
            @sdetweil I’m using clientonly so on the client itself, the config wont have any affect, right? Furthermore on the server side there already is set 0.0.0.0
              sdetweil @codac
              @codac fun… yeh, client only , what are u using for the client? MM clientonly or chrome?
              if the former, I would try the latter
              this is what I use to start the chrome browser over server where electron doesn’t exist
              chromium  -noerrdialogs -kiosk -start_maximized  --disable-infobars --app=http://$server:$port  --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors 2>/dev/null
              do
              server=    mm server
              port=        mm server port
              then the command above in a terminal window to test
                MMRIZE @codac
                @codac
                Modern browser doesn’t allow cross-originated contents(code, data whatever) by default for security reason. I think there might be an option to turn it off(in browser or electron) I’m in out of my pc, so can’t test it by myself, but definitely exist, I know.
                  MMRIZE @codac
                  @codac
                  In chrome/chromium, it might be --disable-web-security flag on execution.
                    codac
                    @mmrize and @sdetweil
                    Yeah, I’ve seen solutions using a htaccess file and
                    Access-Control-Allow-Origin: https://amazing.site
                    as content.
                    Anyhow, I fixed it now placing the remote file on my server and not a remote web-server.
                    You can enter the local path and filename as stated here.
                    That worked for me.
                      sdetweil @codac
                      @codac good…
                      htaccess is on the server side…
                      this error is server generated, client should NOT be able to 'get around ’ it
                        A Former User @codac
