    Black screen after changing the modules' order in config
    7 Posts 3 Posters 1.3k Views 2 Watching
    • N
      Nicole
      my MMM-Face-Recognition-SMAI module is unable to appear on the screen once added, while zero error was reported.
      I ran the part indepently and it worked successfully. (able to detect, recognize and send out the user’s name)
      so i tried to change its order in the config.js, and once it was on top of every other modules, none were able to be seen and All I got was black screen.
      What’s wrong? Is it a version problem or something? really confused.
      magicmirror@2.17.1 start /home/pi/MagicMirror
      [21.10.2021 18:20.16.308] [LOG] Starting MagicMirror: v2.17.1
      [21.10.2021 18:20.16.316] [LOG] Loading config …
      [21.10.2021 18:20.16.323] [LOG] Loading module helpers …
      [21.10.2021 18:20.16.330] [LOG] Initializing new module helper …
      [21.10.2021 18:20.16.331] [LOG] Module helper loaded: MMM-Face-Recognition-SMAI
      [21.10.2021 18:20.16.334] [LOG] No helper found for module: alert.
      [21.10.2021 18:20.16.350] [LOG] Initializing new module helper …
      [21.10.2021 18:20.16.351] [LOG] Module helper loaded: updatenotification
      [21.10.2021 18:20.16.352] [LOG] No helper found for module: clock.
      [21.10.2021 18:20.16.526] [LOG] Initializing new module helper …
      [21.10.2021 18:20.16.527] [LOG] Module helper loaded: calendar
      [21.10.2021 18:20.16.528] [LOG] No helper found for module: compliments.
      [21.10.2021 18:20.16.529] [LOG] No helper found for module: weather.
      [21.10.2021 18:20.16.529] [LOG] All module helpers loaded.
      [21.10.2021 18:20.16.647] [LOG] Starting server on port 8080 …
      [21.10.2021 18:20.16.664] [LOG] Server started …
      [21.10.2021 18:20.16.665] [LOG] Connecting socket for: MMM-Face-Recognition-SMAI
      [21.10.2021 18:20.16.667] [LOG] Connecting socket for: updatenotification
      [21.10.2021 18:20.16.668] [LOG] Connecting socket for: calendar
      [21.10.2021 18:20.16.669] [LOG] Starting node helper for: calendar
      [21.10.2021 18:20.16.669] [LOG] Sockets connected & modules started …
      [21.10.2021 18:20.17.004] [LOG] Launching application.
      [21.10.2021 18:20.18.769] [LOG] Create new calendarfetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      [21.10.2021 18:20.20.212] [INFO] Calendar-Fetcher: Broadcasting 4 events.
        sdetweil @Nicole
        @nicole open the developers window, ctrl-shift-i, and select the console tab. scroll up to see any errors usually red text
        • N
          Nicole
          @sdetweil it appears that I have 4 errors but I have no idea how to deal with it:confounded_face:
          Refused to apply style from ‘http://0.0.0.0:8080/css/custom.css’ because its MIME type (‘text/html’) is not a supported stylesheet MIME type, and strict MIME checking is enabled.
          loader.js:214 Error on loading stylesheet: css/custom.css
          Uncaught TypeError: Cannot read property ‘appendChild’ of undefined
          at main.js:36
          at Array.forEach ()
          at createDomObjects (main.js:20)
          at Object.modulesStarted (main.js:502)
          at startModules (loader.js:55)
          at loader.js:38
          at HTMLLinkElement.stylesheet.onerror (loader.js:216)
            sdetweil @Nicole
            @nicole custom.css messages are because it doesn’t exist by default
            create an empty one by
            touch ~/MagicMirror/css/custom.css
            the other error is the problem.
            I would move the reco module to the bottom again.
            N 1 Reply Last reply
            • N
              Nicole @sdetweil
              @sdetweil get it. thank u sooo much!
                A Former User
                • N
                  Nicole @Guest
                  @hango oh my gosh
                  sorry for such stupid mistake:person_facepalming_light_skin_tone:
