    Any module I add turns to blank screen.
    29 Posts 2 Posters 8.9k Views 2 Watching
      sdetweil @Socrates
      @socrates also are u doing this with MMOS, or MM installed on a running pi os?
        Socrates @sdetweil
        @sdetweil thanks for your prompt reply. I am running rpi4 OS and then installed MM on it.
        The default out of the box modules (US Holidays calendar, and the
        compliment msgs shows up), but when i add my own google calendar URL that also does not show up.
        Not even a single module i add shows up.
        I am following the instructions as on the modules readme pages. I realize some modules require npm install command even after that i get the same blank screen error.
          Socrates @sdetweil
          Let me give you an example of one of the module I am trying to work with. MMM-DynamicWeather
          See the error logs.
          > magicmirror@2.17.1 start /home/pi/MagicMirror
          [25.10.2021 10:06.30.558] [LOG]   Starting MagicMirror: v2.17.1
          [25.10.2021 10:06.30.570] [LOG]   Loading config ...
          [25.10.2021 10:06.30.577] [LOG]   Loading module helpers ...
          [25.10.2021 10:06.30.579] [LOG]   No helper found for module: alert.
          [25.10.2021 10:06.30.595] [LOG]   Initializing new module helper ...
          [25.10.2021 10:06.30.597] [LOG]   Module helper loaded: updatenotification
          [25.10.2021 10:06.30.598] [LOG]   No helper found for module: clock.
          [25.10.2021 10:06.30.753] [LOG]   Initializing new module helper ...
          [25.10.2021 10:06.30.754] [LOG]   Module helper loaded: calendar
          [25.10.2021 10:06.30.755] [LOG]   No helper found for module: compliments.
          [25.10.2021 10:06.30.758] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
          Require stack:
          - /home/pi/MagicMirror/modules/MMM-DynamicWeather/node_helper.js
          /* Magic Mirror Config Sample
           * By Michael Teeuw https://michaelteeuw.nl
           * MIT Licensed.
           * see https://docs.magicmirror.builders/getting-started/configuration.html#general
           * and https://docs.magicmirror.builders/modules/configuration.html
          let config = {
          	address: "localhost", 	// Address to listen on, can be:
          	port: 8555,
          	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
          	language: "en",
          	locale: "en-US",
          	timeFormat: 24,
          //	units: "metric",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "iUS Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
          						symbol: "Koshy-Family-Calendar",
          						url: "https://calendar.google.com/calendar/ical/luvology%40gmail.com/public/basic.ics"
          			module: "compliments",
          			position: "lower_third"
          //			module: "weather",
          //			position: "top_right",
          //			config: {
          //				weatherProvider: "openweathermap",
          //				type: "current",
          //				location: "Houston",
          //				units: "imperial",
          //				locationID: "2646507", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          //				apiKey: "98dbcccba012ef0fd49c86665a0df584"
          //			module: "weatherforecast",
          //			header: "Weather Forecast",
          //			config: {
          //				locationID: '2646507',
          //				app_id: '98dbcccba012ef0fd49c86665a0df584',
          //				units: 'imperial'
          		module: "MMM-DynamicWeather",
          		position: "fullscreen_above",
          		config: { // See https://github.com/scottcl88/MMM-DynamicWeather for more information.
           			api_key: "98dbcccba012ef0fd49c86665a0df584",
           			effects: [
              					month: "10",
              					day: "25",
              					year: "2021",
              					images: ["heart1.png", "heart2.png"],
              					direction: "up"
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "CNN News",
          						url: "http://rss.cnn.com/rss/cnn_world.rss"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
            Socrates
            More troubleshooting logs as per the link provided in this post.
            pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install request
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            + request@2.88.2
            updated 1 package and audited 48 packages in 2.163s
            found 0 vulnerabilities
            pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install uuid
            + uuid@8.3.2
            added 1 package from 5 contributors, updated 1 package and audited 49 packages in 1.85s
            2 packages are looking for funding
              run `npm fund` for details
            pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm fund
            MMM-Dynamic-Modules@1.0.0
            ├─┬ https://github.com/sponsors/feross
            │ └── safe-buffer@5.2.1
            ├─┬ https://www.patreon.com/feross
            ├─┬ https://feross.org/support
            └─┬ https://github.com/sponsors/epoberezkin
              └── ajv@6.12.6
              sdetweil @Socrates
              @socrates said in Any module I add turns to blank screen.:
              Cannot find module ‘request’
              see the link I gave you in my 1st reply
              but looks like u are moving in the right direction
                Socrates @sdetweil
                @sdetweil thanks see my third post , i have the logs uploaded when i tried to install request using
                npm install request
                and then it shows three more packages that are depreciated.
                Not able to install none of those.
                S S 2 Replies Last reply Reply Quote 0
                  sdetweil @Socrates
                  don’t worry about that… one step at a time…
                  don’t do npm fund unless u want to contribute money to other developers (outside MM)
                    Socrates @Socrates
                    Do u think i should install MM some other way? I cannot think of anything else.
                      sdetweil @Socrates
                      @socrates well, i would start with one module at a time…
                      save the current config.js
                      copy the config.js.sample to config.js
                      confirm MM runs
                      add one module
                      resolve any missing dependencies
                      i don’t THINK u need to resinstall, but if u want to
                      then use my install script… see
                      it doesn’t look like config.js editing is the problem, but if so, try my MMM-Config module which generates a form for config , see
                      https://github.com/sdetweil/MMM-Config
                      but missing libs are a pain in the rear… just no way to know when it will hit
                      note that the instructions link I posted will load ‘request’ or any other missing lib
                      IN THE MODULE folder
                      so, if u find ANOTHER module with the same problem, then u have to load it THERE TOO
                      over and over
                      you can do it in the MM folder instead, BUT… be warned… if you do an upgrade, the libs will be tossed as they are not referenced by the base, and are considered a security risk (in NPM, not the MM code) so, you could get to do it all over again, …
                      (I am considering making a change to my upgrade script to try and detect this… not sure yet)
                        Socrates @sdetweil
                        @sdetweil Thanks i am gonna follow these steps and let you know.
                        I am literally installing one module at a time, but none of the 3rd party module works. Even if i try to edit the inbuilt module that MM came with for eg:- the calendar, i try to add my own google calendar, it wont work. (meaning my calendar wont show up).
                        Do u have recommendations of which modules i can initially start with so that all the basic pre-requisite libraries get installed?
