    Any module I add turns to blank screen.
    29 Posts 2 Posters 10.8k Views 2 Watching
      Socrates @sdetweil
      @sdetweil thanks for your prompt reply. I am running rpi4 OS and then installed MM on it.
      The default out of the box modules (US Holidays calendar, and the
      compliment msgs shows up), but when i add my own google calendar URL that also does not show up.
      Not even a single module i add shows up.
      I am following the instructions as on the modules readme pages. I realize some modules require npm install command even after that i get the same blank screen error.
        Socrates @sdetweil
        Let me give you an example of one of the module I am trying to work with. MMM-DynamicWeather
        See the error logs.
        > magicmirror@2.17.1 start /home/pi/MagicMirror
        [25.10.2021 10:06.30.558] [LOG]   Starting MagicMirror: v2.17.1
        [25.10.2021 10:06.30.570] [LOG]   Loading config ...
        [25.10.2021 10:06.30.577] [LOG]   Loading module helpers ...
        [25.10.2021 10:06.30.579] [LOG]   No helper found for module: alert.
        [25.10.2021 10:06.30.595] [LOG]   Initializing new module helper ...
        [25.10.2021 10:06.30.597] [LOG]   Module helper loaded: updatenotification
        [25.10.2021 10:06.30.598] [LOG]   No helper found for module: clock.
        [25.10.2021 10:06.30.753] [LOG]   Initializing new module helper ...
        [25.10.2021 10:06.30.754] [LOG]   Module helper loaded: calendar
        [25.10.2021 10:06.30.755] [LOG]   No helper found for module: compliments.
        [25.10.2021 10:06.30.758] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
        Require stack:
        - /home/pi/MagicMirror/modules/MMM-DynamicWeather/node_helper.js
        /* Magic Mirror Config Sample
         * By Michael Teeuw https://michaelteeuw.nl
         * MIT Licensed.
         * see https://docs.magicmirror.builders/getting-started/configuration.html#general
         * and https://docs.magicmirror.builders/modules/configuration.html
        let config = {
        	address: "localhost", 	// Address to listen on, can be:
        	port: 8555,
        	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
        	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
        	language: "en",
        	locale: "en-US",
        	timeFormat: 24,
        //	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "iUS Holidays",
        						symbol: "calendar-check",
        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
        						symbol: "Koshy-Family-Calendar",
        						url: "https://calendar.google.com/calendar/ical/luvology%40gmail.com/public/basic.ics"
        			module: "compliments",
        			position: "lower_third"
        //			module: "weather",
        //			position: "top_right",
        //			config: {
        //				weatherProvider: "openweathermap",
        //				type: "current",
        //				location: "Houston",
        //				units: "imperial",
        //				locationID: "2646507", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        //				apiKey: "98dbcccba012ef0fd49c86665a0df584"
        //			module: "weatherforecast",
        //			header: "Weather Forecast",
        //			config: {
        //				locationID: '2646507',
        //				app_id: '98dbcccba012ef0fd49c86665a0df584',
        //				units: 'imperial'
        		module: "MMM-DynamicWeather",
        		position: "fullscreen_above",
        		config: { // See https://github.com/scottcl88/MMM-DynamicWeather for more information.
         			api_key: "98dbcccba012ef0fd49c86665a0df584",
         			effects: [
            					month: "10",
            					day: "25",
            					year: "2021",
            					images: ["heart1.png", "heart2.png"],
            					direction: "up"
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "CNN News",
        						url: "http://rss.cnn.com/rss/cnn_world.rss"
        				showSourceTitle: true,
        				showPublishDate: true,
        				broadcastNewsFeeds: true,
        				broadcastNewsUpdates: true
          Socrates
          More troubleshooting logs as per the link provided in this post.
          pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install request
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          + request@2.88.2
          updated 1 package and audited 48 packages in 2.163s
          found 0 vulnerabilities
          pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install uuid
          + uuid@8.3.2
          added 1 package from 5 contributors, updated 1 package and audited 49 packages in 1.85s
          2 packages are looking for funding
            run `npm fund` for details
          pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm fund
          MMM-Dynamic-Modules@1.0.0
          ├─┬ https://github.com/sponsors/feross
          │ └── safe-buffer@5.2.1
          ├─┬ https://www.patreon.com/feross
          ├─┬ https://feross.org/support
          └─┬ https://github.com/sponsors/epoberezkin
            └── ajv@6.12.6
            sdetweil @Socrates
            @socrates said in Any module I add turns to blank screen.:
            Cannot find module ‘request’
            see the link I gave you in my 1st reply
            but looks like u are moving in the right direction
              Socrates @sdetweil
              @sdetweil thanks see my third post , i have the logs uploaded when i tried to install request using
              npm install request
              and then it shows three more packages that are depreciated.
              Not able to install none of those.
              S S 2 Replies Last reply Reply Quote 0
                sdetweil @Socrates
                don’t worry about that… one step at a time…
                don’t do npm fund unless u want to contribute money to other developers (outside MM)
                  Socrates @Socrates
                  Do u think i should install MM some other way? I cannot think of anything else.
                    sdetweil @Socrates
                    @socrates well, i would start with one module at a time…
                    save the current config.js
                    copy the config.js.sample to config.js
                    confirm MM runs
                    add one module
                    resolve any missing dependencies
                    i don’t THINK u need to resinstall, but if u want to
                    then use my install script… see
                    it doesn’t look like config.js editing is the problem, but if so, try my MMM-Config module which generates a form for config , see
                    https://github.com/sdetweil/MMM-Config
                    but missing libs are a pain in the rear… just no way to know when it will hit
                    note that the instructions link I posted will load ‘request’ or any other missing lib
                    IN THE MODULE folder
                    so, if u find ANOTHER module with the same problem, then u have to load it THERE TOO
                    over and over
                    you can do it in the MM folder instead, BUT… be warned… if you do an upgrade, the libs will be tossed as they are not referenced by the base, and are considered a security risk (in NPM, not the MM code) so, you could get to do it all over again, …
                    (I am considering making a change to my upgrade script to try and detect this… not sure yet)
                      Socrates @sdetweil
                      @sdetweil Thanks i am gonna follow these steps and let you know.
                      I am literally installing one module at a time, but none of the 3rd party module works. Even if i try to edit the inbuilt module that MM came with for eg:- the calendar, i try to add my own google calendar, it wont work. (meaning my calendar wont show up).
                      Do u have recommendations of which modules i can initially start with so that all the basic pre-requisite libraries get installed?
                        sdetweil @Socrates
                        @socrates the defaults ones work pretty reliably…
                        for mail, the url for the cal ics lnk should download the ics file when used in a browser…
                        that is what the cal modules uses
                        what modules have u been trying over than default?
                          Socrates @sdetweil
                          I have tried todoist, the calander ext2 module, dynamic weather module, several others. I think i might have an installation issue… I will just reformat my card and re-install using your script.
                          So after i install rpi, do i run ur script in terminal, and follow the prompts?
                            sdetweil @Socrates
                            yes, just copy paste the one line for install in a terminal window
                              Socrates @sdetweil
                              So i have installed mm using your script, and i am up and running, havent installed the modules yet, but that is because i am not able to shutdown mm using pm2 command, mm has been started using pm2 via your script.
                              None of these commands work
                              pm2 restart mm
                              pm2 stop mm
                                sdetweil @Socrates
                                pm2 stop mm
                                cause its not called mm…
                                pm2 status
                                will show u the name , you can also use the number
                                or all to stop everything
                                  Socrates
                                  @sdetweil Dear Sir, you are a genius, i finally got it working. Surely it was an install issue. Using your installation script, and in the past 2 hours i have already inculcated 4 third party modules, and all seems to be working. I might have a question or two later tomorrow when i make more progress, but for now, the main issue is resolved.
                                    Socrates
                                    So everything is working out great for me, i have added some great modules, and in the processing of adding more.
                                    The only one thing i am not able to figure out is the measure of unit for the weather.
                                    I am in the US, in texas, and even if i use the imperial unit it wont show it correctly and the weather is totally off.
                                                            module: "MMM-Weather",
                                                            header: "Weather Forecast - Katy, TX",
                                                            configDeepMerge: true,
                                                            debug: false,
                                                            updateInterval: "15m", // 15 minutes
                                                            updateFadeSpeed: 500,
                                                            api: {
                                                              latitude: "29.71490",
                                                              longitude: "95.83688",
                                                              units: "imperial"
                                                            display: {
                                                              CurrentConditions: true,
                                                              ExtraCurrentConditions: true,
                                                              Summary: true,
                                                              ForecastTableColumnHeaderIcons: true,
                                                              HourlyForecast: true,
                                                              DailyForecast: true,
                                                              Precipitation: true,
                                                              Wind: true,
                                                              InlineIcons: true,
                                                              Feels: true,
                                                              SunCondition: true,
                                                              Humidity: true,
                                                              UV: true,
                                                              Beaufort: true
                                                            personalize: {
                                                              hourlyForecastInterval: 3,
                                                              maxHourliesToShow: 3,
                                                              maxDailiesToShow: 3,
                                                              concise: false,
                                                              colored : true,
                                                              forecastLayout: "table",
                                                              forecastHeaderText: ""
                                                            labels: {
                                                            high: "H",
                                                            low: "L",
                                                            timeFormat: "kk[h]"
                                    Have a look a this code.. and the partial screenshot of my magic mirror through vnc viewer
                                      Socrates
                                      alt text
                                        sdetweil @Socrates
                                        we are west of england, so longitude should be negative (right?)… I am in texas too,
                                        so, if u fix that and leave units off, it will take from the top of config
                                          Socrates @sdetweil
                                          Gosh, my parcel got delivered in Europe… :beaming_face_with_smiling_eyes:
                                          The dashboard is starting to take shape.
                                          alt text
                                          A few more important modules and i am set.
                                            sdetweil @Socrates
                                            more like central China!
