    Any module I add turns to blank screen.
    29 Posts 2 Posters 8.8k Views 2 Watching
      sdetweil @Socrates
      @socrates see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/6
      note that blank screen can also be caused by not following the module install instructions
      if the module has a file called package.json, then in the module folder do npm install
      even it the instructions don’t say that , then see the link above
      also see the ‘how to add a module’ link in my signature (I didn’t write it, but its good stuff)
        sdetweil @Socrates
        @socrates also are u doing this with MMOS, or MM installed on a running pi os?
          Socrates @sdetweil
          @sdetweil thanks for your prompt reply. I am running rpi4 OS and then installed MM on it.
          The default out of the box modules (US Holidays calendar, and the
          compliment msgs shows up), but when i add my own google calendar URL that also does not show up.
          Not even a single module i add shows up.
          I am following the instructions as on the modules readme pages. I realize some modules require npm install command even after that i get the same blank screen error.
            Socrates @sdetweil
            Let me give you an example of one of the module I am trying to work with. MMM-DynamicWeather
            See the error logs.
            > magicmirror@2.17.1 start /home/pi/MagicMirror
            [25.10.2021 10:06.30.558] [LOG]   Starting MagicMirror: v2.17.1
            [25.10.2021 10:06.30.570] [LOG]   Loading config ...
            [25.10.2021 10:06.30.577] [LOG]   Loading module helpers ...
            [25.10.2021 10:06.30.579] [LOG]   No helper found for module: alert.
            [25.10.2021 10:06.30.595] [LOG]   Initializing new module helper ...
            [25.10.2021 10:06.30.597] [LOG]   Module helper loaded: updatenotification
            [25.10.2021 10:06.30.598] [LOG]   No helper found for module: clock.
            [25.10.2021 10:06.30.753] [LOG]   Initializing new module helper ...
            [25.10.2021 10:06.30.754] [LOG]   Module helper loaded: calendar
            [25.10.2021 10:06.30.755] [LOG]   No helper found for module: compliments.
            [25.10.2021 10:06.30.758] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'request'
            Require stack:
            - /home/pi/MagicMirror/modules/MMM-DynamicWeather/node_helper.js
            /* Magic Mirror Config Sample
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
             * see https://docs.magicmirror.builders/getting-started/configuration.html#general
             * and https://docs.magicmirror.builders/modules/configuration.html
            let config = {
            	address: "localhost", 	// Address to listen on, can be:
            	port: 8555,
            	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
            	language: "en",
            	locale: "en-US",
            	timeFormat: 24,
            //	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "iUS Holidays",
            						symbol: "calendar-check",
            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
            						symbol: "Koshy-Family-Calendar",
            						url: "https://calendar.google.com/calendar/ical/luvology%40gmail.com/public/basic.ics"
            			module: "compliments",
            			position: "lower_third"
            //			module: "weather",
            //			position: "top_right",
            //			config: {
            //				weatherProvider: "openweathermap",
            //				type: "current",
            //				location: "Houston",
            //				units: "imperial",
            //				locationID: "2646507", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            //				apiKey: "98dbcccba012ef0fd49c86665a0df584"
            //			module: "weatherforecast",
            //			header: "Weather Forecast",
            //			config: {
            //				locationID: '2646507',
            //				app_id: '98dbcccba012ef0fd49c86665a0df584',
            //				units: 'imperial'
            		module: "MMM-DynamicWeather",
            		position: "fullscreen_above",
            		config: { // See https://github.com/scottcl88/MMM-DynamicWeather for more information.
             			api_key: "98dbcccba012ef0fd49c86665a0df584",
             			effects: [
                					month: "10",
                					day: "25",
                					year: "2021",
                					images: ["heart1.png", "heart2.png"],
                					direction: "up"
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "CNN News",
            						url: "http://rss.cnn.com/rss/cnn_world.rss"
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: true,
            				broadcastNewsUpdates: true
              Socrates
              More troubleshooting logs as per the link provided in this post.
              pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install request
              npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
              + request@2.88.2
              updated 1 package and audited 48 packages in 2.163s
              found 0 vulnerabilities
              pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm install uuid
              + uuid@8.3.2
              added 1 package from 5 contributors, updated 1 package and audited 49 packages in 1.85s
              2 packages are looking for funding
                run `npm fund` for details
              pi@raspberrypi:~/MagicMirror/modules/MMM-Dynamic-Modules $ npm fund
              MMM-Dynamic-Modules@1.0.0
              ├─┬ https://github.com/sponsors/feross
              │ └── safe-buffer@5.2.1
              ├─┬ https://www.patreon.com/feross
              ├─┬ https://feross.org/support
              └─┬ https://github.com/sponsors/epoberezkin
                └── ajv@6.12.6
                sdetweil @Socrates
                @socrates said in Any module I add turns to blank screen.:
                Cannot find module ‘request’
                see the link I gave you in my 1st reply
                but looks like u are moving in the right direction
                  Socrates @sdetweil
                  @sdetweil thanks see my third post , i have the logs uploaded when i tried to install request using
                  npm install request
                  and then it shows three more packages that are depreciated.
                  Not able to install none of those.
                  S S 2 Replies Last reply Reply Quote 0
                    sdetweil @Socrates
                    don’t worry about that… one step at a time…
                    don’t do npm fund unless u want to contribute money to other developers (outside MM)
                      Socrates @Socrates
                      Do u think i should install MM some other way? I cannot think of anything else.
                        sdetweil @Socrates
                        @socrates well, i would start with one module at a time…
                        save the current config.js
                        copy the config.js.sample to config.js
                        confirm MM runs
                        add one module
                        resolve any missing dependencies
                        i don’t THINK u need to resinstall, but if u want to
                        then use my install script… see
                        it doesn’t look like config.js editing is the problem, but if so, try my MMM-Config module which generates a form for config , see
                        https://github.com/sdetweil/MMM-Config
                        but missing libs are a pain in the rear… just no way to know when it will hit
                        note that the instructions link I posted will load ‘request’ or any other missing lib
                        IN THE MODULE folder
                        so, if u find ANOTHER module with the same problem, then u have to load it THERE TOO
                        over and over
                        you can do it in the MM folder instead, BUT… be warned… if you do an upgrade, the libs will be tossed as they are not referenced by the base, and are considered a security risk (in NPM, not the MM code) so, you could get to do it all over again, …
                        (I am considering making a change to my upgrade script to try and detect this… not sure yet)
